Old 03-12-2010, 08:37 AM   #1 (permalink)
Default Computer power supply +12v 30amps
HI,
I thought i would share with you a great little power supply that can supply 12v at 30Amps. It also does not need any load to keep it running and will give you a ripple free voltage with over voltage and over current regulation. i have seen these supplies going for $65 or in my case Free !
Here are a few photos of the supply :
Rear view:
compaq model number label.
Shorted Pins required, just 2 !!
voltage and Amperage rating..i think it is impressive.
Once jumpered as shown you can just connect the power and the voltages are ready to use. You could like i have, replace the blue jumper shown with a switch and this will cut all outputs and thus save you switching on and off the mains power, thus reducing the strain on the components etc..
Enjoy..As Bob would say..
ID:	144703   Click image for larger version
ID:	144704   Click image for larger version
ID:	144705   Click image for larger version
Protos 500, Trex 600N, Trex 450, Trex 250, DX7
Apache64 is offline        Reply With Quote Quick reply to this message
Old 03-12-2010, 10:58 AM   #2 (permalink)
where can we buy them?
06graphite is offline        Reply With Quote Quick reply to this message
Old 03-12-2010, 02:22 PM   #3 (permalink)
Hi, it all depends where you live, a good place to start would be e-bay in your country, and then just google it for a local supplier. I had one guy looking to get his working and when i gave him the solution, he mentioned that thy were available there for around $65 Australian dollers. So sorry i dont have any direct outlet for them but if you look for the model number ESP115 you should get quite a lot of hits, good luck
Old 03-12-2010, 11:09 PM   #4 (permalink)
Cain't beat the price but server power supplies are out there for cheap.
Just picked up one of these 12.7v 74amp supplies for $35. Uses a non standard power plug but I just soldered on a proper one. Accepts 110-240vac, nice.
http://www.trademoon.com/Product378593.aspx
Fans are a bit noisy because I think the fan speed control input was from the server and without that connection it just runs full speed. Not a problem though, I'm going to make some sort of charging box for my three chargers and the supply.
Lots of this sort of information on Rc groups.
http://www.rcgroups.com/forums/showt...r+power+supply
Mentalic is offline        Reply With Quote Quick reply to this message
Old 03-13-2010, 05:10 AM   #5 (permalink)
Hi, this info is invaluble, and when i need 100amps i will know where to go to build one, thanks for your input
Old 08-09-2010, 09:17 AM   #6 (permalink)
At last!
I got a HP/Compaq ESP-115 power supply and some googling around provided the solution for the pins, but not being an electrician, I'm not too sure where to solder the wires at the back to provide one red and one black cable to feed the charger...
I just stumbled on this thread and I'm glad to see someone already achieved that with this specific power supply.
Would you have any diagram or pictures of how you soldered the wires at the back? From what I understood, the 5th and 6th tabs from the left are 12V and the last four are grounds.
cron is offline        Reply With Quote Quick reply to this message
Old 08-26-2010, 04:18 PM   #7 (permalink)
See my signature for links to threads showing how to convert PC power supplies.
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote Quick reply to this message
Old 08-29-2010, 11:50 PM   #8 (permalink)
I'm running two power supplies I got on eBay for $16 bucks each They get you on shipping though so it was 56 total for two shipped. I rigged them up in series for 24v and I have reached 14.5 amps on all 4 ports simultaneously on two hyperion 615 duo3. It takes a little modification to the power supplies, but it was well worth it.
ckirschman is offline        Reply With Quote Quick reply to this message
Old 09-03-2010, 07:10 AM   #9 (permalink)
Default Two 12V Power Supply to make one 24V
ckirschman, can you share that infor about hooking up two power supply. I have one 13.8 DC volt 12 Amps and the other is 13.8V and 3 amps, I like to know how to hooks these together and make one 24 volt. Also I do have an 12V computer power supply, I'm not sure if you can hook up all three. Can you show a wire diagram. I to have hyperion 615 duo3 and the one bigger power supply ( 12amps) it get hot when charging two battery at once. Thanks for your help Roncx2
RONCX2 is offline        Reply With Quote Quick reply to this message
Old 09-10-2010, 07:44 AM   #10 (permalink)
Default PSU $25.00
I make my own too for only $25.00 500W/30A I am sorry for the Spanish video but I am from PR you know that.......
[ame]http://www.youtube.com/watch?v=RfaB4dXzydc[/ame]
KS
ID:	179186   Click image for larger version
ID:	179187   Click image for larger version
ID:	179188   Click image for larger version
ID:	179189   Click image for larger version
ID:	179191   Click image for larger version
ID:	179192   Click image for larger version
ID:	179193   Click image for larger version
ID:	179366   Click image for larger version
kdsalas is offline        Reply With Quote Quick reply to this message
Old 09-13-2010, 03:24 PM   #11 (permalink)
go to www.wikihow.com or youtube look for psu and there is a very explained way to do it. I´m just finished mine, cheap and easy.
Rc_Collector is offline        Reply With Quote Quick reply to this message
Old 09-22-2010, 10:16 PM   #12 (permalink)
Default I make another one...
I just make another ATX Power Supply, this time is smaller and I believe is better construction I can see inside, came with so many futures but is only 10A 200W, but that will be no problem, my iCharger is 10A up to 250W on 13.8V, that mean I can charger only two lipos 3000 6s in series with no problem.......
KS
ID:	181559   Click image for larger version
ID:	181560   Click image for larger version
ID:	181561   Click image for larger version
ID:	181565   Click image for larger version
Old 05-05-2013, 08:32 AM   #13 (permalink)
Default ESP 115 Power Supply
This post
https://www.helifreak.com/showthread.php?t=198568
refer to how to short some PIN to use the ESP 115 Power Supply out of Server
does any one knows where I can get a full schematic circuity of the ESP 115 main board ?
I need to repair a blown up one
alainbastien@gmail.com
alainbastien is offline        Reply With Quote Quick reply to this message
Old 06-11-2016, 02:21 AM   #14 (permalink)
Default Compaq ESP 115 in series for 24v
Hi, i tried to rigg my 2 ESP 115 in series , individualy they work fine , but one of them refused to work ( led off) once in series. could you help me please
JPM
Neyam is offline        Reply With Quote Quick reply to this message
