Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 08-27-2014, 10:44 PM   #1 (permalink)
Default new to the Diabolo club
he guys, I pulled the trigger (wife said go for it) on a second hand diabolo. Its got all the goodies - kosmic 160, mks x8, pyro 800-48, spartan vortex, I'm really stoked! Got a new white canopy w green decal coming, just got 2 glacier 12s 5300 stick packs,
Ive been flying a logo 600sx and this thing looks like a beast sitting next to the logo, I'm debating on doing a complete teardown but i wanna fly it a bit first. It's got 690 vblades on currently and I was thnking 1800 rpm to start out (mild 3d).
Any tips or things to check or watch out for would be much appreciated.
Mark
MS60 is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 10:48 PM   #2 (permalink)
HF MR Support
Just make sure you get the belt tension right and the main gear meshed correctly.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 03:55 AM   #3 (permalink)
I would say to do at least a partial rebuild. Remember, birds of this size are lethal so safety first!
I purchased my Triabolo used and although the original owner did a great job building the bird, I did find a few screws where the loctite was not holding (happens to all of us). I basically tore mine down to the core frame elements, leaving the gears in and simply removed/cleaned and "re-loctited" all the screws and ensured all the bearings where ok. This also gave me the opportunity to set it up according to the manual and ensure everything is right. Now if it crashed due to a mechanical failure, its my fault not someone elses... I can deal with that better. :-)
MadMatt986 is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 06:13 AM   #4 (permalink)
Default Diabolo club
Congrats! Depending on what you've been flying before, well actually almost regardless of what you've been flying, it will be a treat.
I have the same ESC and motor, only rewound for lower KV. It's a really nice combo. I'm also using the Vortex and (for me anyway) it's spot-on.
HD Cell 750, RJX Vector, TDR, TDSF, Kasama Dune and Faifa, Minicopter Triabolo 700, Beam Avantgarde, JR E8 leggero, Suzi Laos, Shape 9, Shape S8, Rave 450, TRex 500, Raptor E700, Compass Warp, Steam 700, Spirit, Spartan, Jeti.
trillian is online now        Reply With Quote Quick reply to this message
Old 08-28-2014, 07:04 AM   #5 (permalink)
As suggested above I would do a tear down. Even if you trust the person who built it 100% I would still at least go around and check everything
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 07:12 AM   #6 (permalink)
Congrats! And welcome to the best addiction you'll ever have. They are addictive.. Now you are gonna want them all.
Diabolo S #41
TDR 2
The others come and go..
craigdieselmac is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 09:19 AM   #7 (permalink)
i'm using also the vortex and mks x8 on my diabolo.
the only thing i would change are the 690 vblades.
the great thing about the diabolo is that you're able to use longer blades than on other 700size helis.
get some 710 or 715 mm blades and it will be great
i can post my vortex setup tomorrow if you want it
michalp is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 10:04 AM   #8 (permalink)
I think new main and tail blade are in order, I'm flying mild 3D, any suggestions? (710 / 115mm?) (I've got Rails on my 600sx and like em) Also, yes on the Vortex setup - that would be awesome. Now if I can get this new canopy set up perfect without schmucking up the decals I'll be off to a good start.
Old 08-28-2014, 10:18 AM   #9 (permalink)
i'm 3d guy so basically i don't like blades which are too,soft when it comes to cyclic and collective response. i'm using ms composit rapid 710
but for your purpose the rails 716 are a pretty good blades.
they're very precise and track extremely good and they are not so aggressive on cyclic and collective .
they are great for big air flying in my opinion.
rails 116 are by far the best tail blades I have ever used on my tail
this is a flight with 1800 headspeed and a pretty heavy setup (5,7kg)
Old 08-28-2014, 12:01 PM   #10 (permalink)
Thanks for the vid. Nice
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 01:03 PM   #11 (permalink)
For lower headspeed with the silver pulley they are great but for around 2000-2100 they become too much. gain has to go way down. I use the rail 106's at that headspeed and are excellent very crisp stops and nice high tail gain.
Richard Zappe
Old 08-28-2014, 01:08 PM   #12 (permalink)
I'm using them also with 2300 headspeed and the silver pulley without Problems.
Depends also on which servo you are using. I'm able to use much higher gains with my hbl 880 than with a savox or jr tail servos.
30% tail gain on my vortex with the 18,5 hole and it works just great. Probably it will be even better with a 17mm hole ^^
Old 08-28-2014, 01:47 PM   #13 (permalink)
Im talking about running gain up at around 55% with a Futaba BLS 256HV forget the mm from center the horn on the servo.
Richard Zappe
Old 08-28-2014, 01:49 PM   #14 (permalink)
The gain depends also on the fbl unit....
The gains with spartan gyros are much lower compared to beast or vbar so it isn't uncommon to run gains arround 30%
Old 08-28-2014, 02:44 PM   #15 (permalink)
this is with a cgy 750 so probably on the higher side but with 116's i was down around 40% above 2000 hs
Richard Zappe
Old 08-28-2014, 10:39 PM   #16 (permalink)
well Ive got Rail 716 and 116 on the way, new boom and a few links also, Tail pulley has 2 set screws at 90 deg. mut be the newer style. do these blades on this heli require washers/shims?
Old 08-29-2014, 03:45 AM   #17 (permalink)
if they have a 12mm root then yes. (2 x 1mm shims per blade)
Old 08-29-2014, 03:36 PM   #18 (permalink)
Here is the Setup with the 18,5 mm holes on all servos.
Agility 55%
Style 65%
Gain 45% / 42% /40%
Mid Stick Agility 28%
Collective Boost 0%
Pitch Up Comp 70%
Ele Precomp 0%
Cyclic Response 40%
Cyclic Rate 100%
Cyclic Symmetry 0%
Cyclic Decay 10%
Cyclic Expo -15%
I Gain 42%
P Gain 42%
Feed Forward 6.2 °
D Elevator 85%
D Aileron 5%
Tail:
Piro Rate 530°
30% Gain
Max Pos Collective 100%
Max neg. Coll. 99%
Ail 8° = 101%
Ele 8° = 99%
Cyclic Limit 10,0°
Cyclic Ring taper 32%
Old 08-29-2014, 10:50 PM   #19 (permalink)
Thanks so much for the setup, I'll compare to what's on the unit now. I.ve got the boom and tail mechanics set up, This tail is the smoothest I've seen and the clamp to the boom is so cool. Blades due in tomorrow. Maybe a maiden this weekend!
Old 09-21-2014, 05:28 PM   #20 (permalink)
Well here it is, didn't get the windshield decal on perfect, but it will do for now. I've just got to get some flights (5 currently) under my belt and get used to the size and power of this beast. The Spartan seems pretty solid.
ID:	537507   Click image for larger version
ID:	537508   Click image for larger version
