Blade 450 Blade 450 Helicopters Information and Help |
10-20-2011, 07:51 AM | #1 (permalink) |
Converting to 450 X
OMG, I'm sooo happy i waited on FBL..
Here's what i'll order: FBL Blade grips (8$) FBL Spindle (5$) FBL Head (28$) FBL arms (18$) FBL Main shaft (10$) AR7200BX FBL controller / receiver (240$) Total for the conversion: 309$....... |
10-20-2011, 08:04 AM | #2 (permalink) |
Throw in another $34.00 for CF main blades and you're so close to $350.00 At that point just buy a 450X outright and keep the FB as a spare.
That's my plan. Jake
Blade MSR, B450 3D 300X 130X MCPX Blade Inductrix, Convergence, X-Vert Yuneec Typhoon 500+, 500G DJI Mavic Pro |
10-20-2011, 08:05 AM | #3 (permalink) |
450 X is 500$.... And mine has all the upgrades already!
10-20-2011, 09:48 AM | #4 (permalink) |
So I am better off to sell my 450 fb for about $200.00 and then buy this. It may be cheaper.
Blade MCPX, Blade 450 3D,UMX Sbach 342 UMX Beast, Parkzone Extra 300, Parkzone T 28D |
10-20-2011, 11:29 AM | #5 (permalink) |
If you had a bad crash and needed many of the head parts and blades anyway, a conversion may make good sense.... step by step.
Of course buying part by part is never going to have the same value as buying the whole.... Try buying a Lexus part by part. Have Fun, David
Horizon Hobby Product Development |
10-20-2011, 02:57 PM | #6 (permalink) | |
10-20-2011, 03:25 PM | #7 (permalink) |
On a Lexus?? I feel for you!
10-20-2011, 07:23 PM | #8 (permalink) |
Makes me feel a lot more comfortable going FBL. At least you know the parts will fit.
Goblin 700, Goblin 380, Gaui NX7, T-Rex 700N, T-Rex 450 iKon, because I am connected to my heli. Are you connected to yours? RCHN #15 |
10-20-2011, 10:48 PM | #9 (permalink) |
David, do you know if main shaft diameter is same as B450 3D? That way i don't have to replace my bearings..
10-20-2011, 11:58 PM | #10 (permalink) |
Yes, the mainshaft diameter is the same.
Have fun M |
10-21-2011, 11:24 AM | #11 (permalink) |
Scrapped the 3gx from my 600e Pro for a BX. I plan on giving the 3gx one last shot on my 450 x conversion... Saves a ton of money.
--- I am here: http://maps.google.com/maps?ll=39.758316,-104.830119
Blade 450X, 360cfx 6s, Trex 500 EFL Pro |
10-21-2011, 03:21 PM | #12 (permalink) | |
AR7200BX 7CH DSMX Flybarless Control System
So, if it's like a normal microbeast, I can just use it like a tail gyro like a normal microbeast on a flybarred bird? Also now, a difficult question: how would you compare this if used as a receiver + tail gyro combo to the current flybarred blade 450 tail gyro? Just exploring options and confirming what I am assuming. Might go for a slower upgrade. Also to be honest, have been thinking a lot. Would probably want to keep my current flybarred bird, if it's definitely a better tail and saves weight, and leaves the option open for FBL conversion, I might consider buying the unit for it
10-22-2011, 08:47 AM | #13 (permalink) |
any chance of "a kit" for those of us that wish to convert ?
10-22-2011, 12:02 PM | #14 (permalink) |
Hi Thalios.
you need to add the digital servos to the list. not everyone have upgraded there servos yet
Blade 450 3D RTF |
10-22-2011, 01:26 PM | #15 (permalink) |
Wow, you're right...
Forgot that you need digital servos.. I guess i might have to give the stockers a run while i wait on the spektrum digitals. That's the route i want to try.. |
10-22-2011, 02:10 PM | #16 (permalink) |
Are the new digital servos a requirement, or will the beastx work with the stock servos?
Current fleet is getting smaller. Blackout Mini-H, WarpQuad 230, Blade 200qx, Nano QX, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX6 radio. Previous fleet: mcpx, 300x, 350qx,450x, qav400, DX7s |
10-22-2011, 02:17 PM | #17 (permalink) |
Stock are digital i'm pretty sure.
10-22-2011, 03:42 PM | #18 (permalink) |
Ds76 are fine with beastx
200hz cyclic 270hz tail. T Ds75h would be like 50hz and not working real well. (b400)
10-22-2011, 10:13 PM | #19 (permalink) |
Guess DS stands for digital servos.
