| BeastX FBL System BeastX FBL Flybarless System Software and Hardware Support |
450pro with AR7200BX. 2 layer of 411 tape, DS95i tail, tail gain at 50% (even down to 0% still shake). Tail servo no movement after power up. When full spooled up. I can see the tail servo move back and forward slightly. I think this is where my tail shake is coming from. Virbration is not that bad. I can hardly feel the vib in my hand when spooled up without the main blade. Main blade is tracked and balanced. Even with no blades on the heli. Servo moves after spooling up.
I had no problem before the minor tip over. I pretty much replaced everything on this heli except for the frame just to find out where / or what is causing the tail shake. Parts replaced are not damaged but i replace it anyway to track down the tail shake. main blade main bearing main shaft, complete head assembly tail grip assembly torque tube and shaft tail blade (kbdd) Could it be the AR7200 giving servo movement with slightest vib? Same result with different tail servo. |
#2 | |
Can you explain what you mean about no movement on power up? Like the servo is dead or what?
-Andrew Align Trex 600EFL Pro - BeastX To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Blade 450X - Scorpion 2221-6 motor Blade 130x / mCPx HP05s |
#3 | |
Tail servo wag only after spoolong up. so it is most likely vib related. But why this happen after a minor tip over. |
#4 |
The motor on my Gaui 200 vibrated enough to effect the FBL unit. The motor on my 300 X vibrated enough to cause tail kicks. Is it possible your motor might be causing the issue?
On the 300 X, I switched out the stock motor for a Scorpion and the tail issues are gone.
Ivan There is a very fine line between "hobby" and "mental illness." |
