bavarianDEMON/HeliCommand Factory Sponsored Bavarian DEMON and HeliCommand Support |
05-02-2014, 10:26 AM | #1 (permalink) |
DX9 move bind switch to gear loc
Just like with the DX8, where the momentary bind switch is swapped with the gear switch, has anyone successfully done this with a DX9? I have a friend who was attempting to, but the pot on the slider was getting in the way.
I've been considering getting a DX9 myself, but I really like the momentary switch in the lower-left corner.
DX9, Mostro 700N 120SRX, HD Cell 500, Blade 450xl 6S, 180 CFX and 130x. |
05-02-2014, 01:13 PM | #2 (permalink) |
I have switched around A and I. It's a while since I did it, but I can't remember any problems doing it.
05-02-2014, 02:11 PM | #3 (permalink) |
Did you remove the grip pot that is in the way? As is stands if the pot int he grip stays, there's no room for the momentary switch….at all.
180cfx, Align 450L, Goblin 500, Rush 750, Avant Mostro Lynx Team Pilot |
05-02-2014, 02:14 PM | #4 (permalink) |
I switched mine with no issues. I do seem to recall removing the grip pot and reinstalling it after the switch swap. Fits fine
05-02-2014, 02:23 PM | #5 (permalink) | |
The momentary has leads with wires soldered to it that are in the way of the pot.
05-02-2014, 02:41 PM | #6 (permalink) |
You have to turn the switch 90 degrees around, so the wide part points in/out.
05-02-2014, 06:16 PM | #7 (permalink) |
That was the issue. For some reason I wasn't smart enough to see the simple solution right in front of my eyes. Thanks guys.
05-03-2014, 04:57 AM | #8 (permalink) |
Been there... Some times the brain gets in the way of the thinking.
10-12-2014, 06:22 AM | #9 (permalink) |
I swapped the bind switch on DX9 with Switch B using micro servo leads so you can still open the Tx for servicing and access.
Worked well - but I have long fingers so that works for me. not sure whether to use Switch A as single SL switch or Switch C as two step SL - is two alternative SL levels worth it ? Then I am stuck working on head gain during BD setup - should I be using a pot type switch so I can adjust head gain during set up flight - Right Knob or Left / Right Lever - which is best choice ? |
