Old 08-26-2015, 07:46 PM   #21 (permalink)
gears will strip
best advice metal gears and plastic servo horns
as someone else said, break away servo arms
something like these
http://www.hawk-rc.com/index.php?rou...roduct_id=1425
4 x Rush 750/stretched V-bar KDE 700XF-495 HV servos Greys reactor CC 160-HV
Trex 600EFL V2 V-Bar ds610 ds650 CC bec/pro Scorpion 130a HV KDE 600XF-530
450L KDE 1750 cc50 4xDS215MG k-bar
X-8 FPV Wing, TBS Discovery FPV, TBS Caipirinha FPV
satgod is offline        Reply With Quote Quick reply to this message
Old 08-27-2015, 10:22 PM   #22 (permalink)
my LHS had some Dubro red servo horns for the Hitec 5065mg. I purchased them and they are quite flexible one way, but not so flexible the other way (in a rotational arc) I've had one light crash on them back when I was flybar and they did the job. I'm still on the same servo's and gears now that I am flying with BeastX and a DFC head. These servo horns are literally 1mm thin.
These are it. Just cut to size. Another plus for these is that they are thin enough to use a nut behind the ball.
T-Rex 450 Pro DFC
xrayray is offline        Reply With Quote Quick reply to this message
Old 09-02-2015, 09:47 PM   #23 (permalink)
You might think those breakaway servo arms will flex in flight but I watched a video of a guy that mounted a camera under his heli to where you can see the servo arms react in flight and there wasn't any amount of bending or flexing that I could see... and I believe he was "tossing it around"
Goblin 380 (Spirit), X3 (VBAR), DX9
(I.Y.A.O.Y.A.S.)
alyon187 is offline        Reply With Quote Quick reply to this message
Old 09-06-2015, 11:25 AM   #24 (permalink)
They dont flex in flight. Super fast tic tocs can be done with these servo horns and still feel locked in.
T-Rex 450 Pro DFC
Old 09-12-2015, 08:46 AM   #25 (permalink)
I've used every brand of micro servo out there. Trust me, higher cost doesn't mean they're going to perform or last any better just because you spent more on them (95s are nice but vastly overpriced). I still crash on a very regular basis (always trying to push the limits) and using breakaway servo horns is probably the best thing I've invested money in. Add them to your machine and you'll see a sharp reduction in the damage to your servos.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote Quick reply to this message
Old 09-12-2015, 10:48 AM   #26 (permalink)
I have found that the kst main srevo gear snaps very easy...
I run the tgy306hv's and the stock main gear is much stronger than any replacement I have found....I was using metal servo arms and the stock 306's gears lasted over two dozen crashes...
They don't make replacement gears for them but the KST gear set is a perfect fit....Problem is the main gear shaft breaks on at least one servo in every crash now..
so I am now using the breakaway servo arms..
PTFlyer is offline        Reply With Quote Quick reply to this message
Old 09-12-2015, 11:01 AM   #27 (permalink)
I have the same exact experience!
I purchased a bunch of KST replacement gear sets only to use the one main output shaft gear as that always seems to shear off in a crash. Sometimes, the output shaft bearing gets destroyed as well so I am forced to replace the entire servo.
Walkera 4#3B, 4G6
Align 250SE, Gaui 200
Tarot 450PRO
Align 550L Dominator
Steve Joblin is offline        Reply With Quote Quick reply to this message
