Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 09-17-2015, 08:56 AM   #1 (permalink)
Default 700 Comp' 'toilet bowling'!
I'm sure this has been said before but anyway....just built a 700 comp' carbon with HPS head and from the first flight it's had the 'toilet bowl' effect thing going on at lower head speeds. It has now had maybe 30 flights on it so is properly run in now, have added shims twice now to remove the axial play on the head and does this exactly the same as when new.
Once up to speed it's fine and not noticeable, I fly it at 2000 plus but where it's now becoming really annoying is during autos when the head speed bleeds off and the whole heli starts wobbling.
I was wondering if anyone has a cure for this as its starting to get annoying!
George
George J is offline        Reply With Quote Quick reply to this message
Old 09-17-2015, 12:38 PM   #2 (permalink)
What FBL unit? If you have everything setup right mechanically I'd start reviewing your gain values and adjusting them. Only head wobble I get is perhaps around 1000rpm when I'm finishing a baby auto and letting it hover with no power.
Synergy 766, Goblin 700C, Synergy E7 SE, Logo 700, Align 700x, Logo 550sx, Goblin 500, Oxy3 TE, BK Servos, Spartan VX1e, TX - JR XG14 Xbus
rb30cory is offline        Reply With Quote Quick reply to this message
Old 09-17-2015, 01:08 PM   #3 (permalink)
Vbar Neo but its nothing to do with the gains or vbar set up. It's something to do with the head/ dampers/ shimming etc but just trying to find a solution.
Autos is where it's worst and once spooled up and I'm throwing the heli around it's completely gone and it flys great as expected.
George
Old 09-18-2015, 07:24 AM   #4 (permalink)
Is this the HPS2 or HPS 3 head? What head speed are you running when it wobbles? Please share more information about your setup. Blades, Servos, Motor, ESC, Etc. The more info you can provide the better.
SAB USA Factory Pilot/Field Rep. Pulse Battery USA Field Rep. BK Servo Team Pilot. Team Spartan USA. Canomod USA Field Rep.
alexmit is offline        Reply With Quote Quick reply to this message
Old 09-18-2015, 10:10 AM   #5 (permalink)
HPS2 head, Xera 4530-500 motor, Vbar Neo, Futaba/Kingmax HV servos, Kosmik 160 and Align 700mm mains. I've re shimmed the head twice now but was just comparing my 700's head to a friends 630 also with HPS2 head at the field just now and mine is most likely a bit heavy on the preloading as its very rigid in comparison and the 630 autos great and has no such wobble tendencies so I've just come indoors after removing a couple of shims on the head so will see if that improves it, I'm sure it's just down to getting the right balance of shims/dampers etc.
It's worse during autos at the moment though and once spooled up it completely disappears so will report back when I've flown it again.
George
Old 09-20-2015, 12:42 PM   #6 (permalink)
Smile
When you have a heavy preload there is a certain RPM range at which you have that wobble. So if you want to run it like that you need to adjust the RPM to avoid that sector(usually the sector is about 100rpm wide and some times there are 2 sectors 50rpm each at different places). Also if nothing works try loosening up the main blades but then you have to be careful with the 3D. So keep testing and good luck!
Goblin 700 / T-rex 600XN / 150X(killer)
The only source of knowledge is experience.
Vas10 is offline        Reply With Quote Quick reply to this message
Old 09-20-2015, 02:19 PM   #7 (permalink)
I experienced a small wobble today - saw it when coming in to land. After further inspection I found my main gear jesus bolt needed a little snugging up. I could barely wiggle my main gear side to side (bolt is the fulcrum.) I snugged it down and guess what? Next flight wobble was gone. (took about 80 flights to get a little loose)
Give it a fine tooth comb it could be as simple as my example above
Old 09-21-2015, 09:53 AM   #8 (permalink)
In-between rain showers I managed a garden flight and its massively improved by removing a shim from each side, not perfect yet but has made a big difference so am getting close to sorting it.
Anyone know if there is a slightly softer damper I can stick in it? I notice in the damper pack there is 3x different sets of dampers, type A, B & C, are these different hardness?
George
Old 09-21-2015, 10:02 AM   #9 (permalink)
From the HPS 2 Manual:
The new HPS 2 head offers an independent dampening system for each blade grip, there are three dampening settings:
A = Soft for smooth response.
B = Medium.
C = Firm for direct and precise response.
We recommend starting with the medium setting.
For safety reasons we suggest to not exceed 2300 rpm.
Download here:
http://www.goblin-helicopter.com/sho...ay/H0428-K.pdf
Old 09-21-2015, 10:08 AM   #10 (permalink)
B = Medium.
Download here:
Thanks for that, didn't see that. Do you know which ones would've been supplied with the kit by any chance?
George
Old 09-21-2015, 10:10 AM   #11 (permalink)
Off the top of my head, no. I thought you said you were looking at all 3 dampeners, (A,B,C) which I 'think' it ships with all 3.
Old 09-21-2015, 10:24 AM   #12 (permalink)
Sorry I meant I was looking on Fast-Lad site in the spares, my kit only came with the one set but not sure which ones they are but guessing they would all ship with a 'stock' damper wether A B or most likely C maybe?
George
Old 09-21-2015, 10:36 AM   #13 (permalink)
For what i know, the HPS 3 come with "A, B, C" option HPS2 does not.
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 09-21-2015, 11:05 AM   #14 (permalink)
Just ordered the damper pack which has all 3 in so will remove the ones in the head and fit the next softest one when I get them.
Thanks for the help.
George
Old 09-24-2015, 04:38 PM   #15 (permalink)
All seems to be ok now that I've removed a couple of shims so it seems that too much preload was the issue here. Autos were fine and could get the headspeed way lower than I'd ever fly it so all good.
George
Old 09-29-2015, 09:45 AM   #16 (permalink)
TT
Glad you got it sorted! I haven't had this problem with my Goblin 700 / HPS head but I did have the same problem (perhaps more severe) with an Align 700E due to overly stiff dampeners. It is painful to watch a heli eat itself on the ground when all you did was land it. Aggravating to say the least.
TT is offline        Reply With Quote Quick reply to this message
Old 10-04-2015, 03:13 AM   #17 (permalink)
Put some flights through the Goblin yesterday and it was the first session with it where it didn't feel a bit loose and a bit horrible and tbh it is now flying as I want it to.
However, I have to say that this Goblin is the first heli I've had for a long time which has needed so much effort to get flying properly, it was nearly up for sale last week! Even a Trex 700 now will fly spot on straight out the box so was a bit disappointed as was really expecting the HPS head to just work but on mine it is a very fine balance between damping and preload if you want the heli to be more than just a 2300 rpm smack heli!
All good now anyway, thanks for any input
George
Old 10-04-2015, 09:21 AM   #18 (permalink)
Glad you got it worked out. I don't believe your experience is typical. I think a 3 bladed head is a bit more work than a 2 blade setup if you experience setup bugs.
Please close this thread since your issue is resolved. :-)
Old 10-04-2015, 10:13 AM   #19 (permalink)
Funny. My 770 and 570 carbons both maidened flawlessly, but 6 weeks later I'm still struggling to get my 380 to be even sorta flyable. Major tail issues. Go figure...
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
