Old 08-27-2016, 12:05 PM   #1
TR450ZS
Default Swash bearing replacement
I picked up a used swash plate for a trex 500 and although there is absolutely no slop in the bearing at all, it doesn't feel smooth when I rotate it.
Is it possible to disassemble the swash and replace the bearing? Has anybody done this before?
Allan
TREX 250 PRO,Talon15, GPRO, Zeal ----TREX 500 EFL PRO, GPRO, RAILS ----2x TREX 450PRO V2, 1xGPRO&1xBRAIN, Talon35, RAIL , Zeal ---- SAVOX powered TREX500 EFL in Roban scale UH1-N ---- TREX 600 EFL PRO, GPRO, RAILS ---- DX9 ----
TR450ZS is online now        Reply With Quote
Old 12-08-2016, 12:07 PM   #2
zzyzx_cm
ive tried, not successfully. the top and bottom halves are threaded together. after that is taken apart you can press the bearing out the bottom. i damaged it trying to unscrew it, whatever they use to fix the pieces together works well. i don't think i tried heating it which probably would help.
zzyzx_cm is offline        Reply With Quote
