Old 12-12-2011, 08:16 PM   #21
Warhorse
Originally Posted by pril250 View Post
Crash repairs are a thing of the past
You can still crash, you just have to work at it a little harder. I had one on a Blade 400. It worked well but was no match for a couple of really dumb thumbs!
Trex 450 Pro, Agusta A109 fuselage, Align 3G FBL head, SK720, MKS DS95's, ICE 50
Tarot 450 Pro, Align 430L, ICE 50, FBL w/ SK-720, HS5065MG cyclics, HS5084MG tail
MCPX V2, all stock
Warhorse is offline        Reply With Quote
Old 12-12-2011, 08:30 PM   #22
pril250
FM will never be fast enough to react and be used as a proper 'bail out' system but it does a job of work in assisting in the early steps of learning to get your bird in the air
Blade400
pril250 is offline        Reply With Quote
Old 12-12-2011, 09:10 PM   #23
Warhorse
I found it was a tremendous help in getting me over the forward flight hurdle. Before FM, I couldn't do much more than tail in hover. If I tried anything else I usually ended up panicking and crashing. I just needed that little bit of extra stability until I could get my self confidence up and my nerves settled down enough to think about what I was doing.
MCPX V2, all stock
Old 12-13-2011, 05:08 PM   #24
WyDiablo
Well after reading and watching how the flymentor works. Its seems to me that the Co-Pilot II would be the best "bailout" correct?
Wydiablo
WyDiablo is offline        Reply With Quote
Old 12-13-2011, 05:31 PM   #25
pril250
Yes, CPII is perceived to be the preferable 'bail out' device with its faster reaction times. Also the fact that its artificial horizon is not determined by gyros which tend to get 'confused' and lose track af the helis attitude during fast maneuvers.
Blade400
Old 12-13-2011, 07:40 PM   #26
WyDiablo
I was trying to decide between a Flymentor or another Co-Pilot II, but after see all the crap I would have to tweek and set for the flymentor I'll go with the Co-Pilot. At least thats the easiest to setup and fly without that much hassle.
Old 12-13-2011, 08:35 PM   #27
pril250
Good decision, each to what suites their purpose
Blade400
Old 12-24-2011, 07:45 AM   #28
AussieHoppy
i am waiting for delivery of a HK-500CMT, and have both CoPilotII and FlyMentor sitting on the shelf...
if CoPilot is the choice, could you please tell me what the significant advantages are, over the FM?
Cheers
AussieHoppy is offline        Reply With Quote
Old 12-28-2011, 07:11 PM   #29
Luvmyhelis
Its only significant advantage is that is does have a much quicker response time to self level the heli when it is engaged. As Pril stated above it has the capability to be used as a bailout system, whereas the Flymentor cannot. Its main disadvantage is in flying where you simply do not have a good visible horizon, or one cluttered with obstacles that will obscure its ability to "see" the horizon. Whereas the FM can fly in a totally enclosed area. Plus the Copilot has to have more measuring components hanging off it to measure with than the simple ground sensor of the Flymentor. Each has its own purpose, mostly depending on you. What kind of flying you do and where you fly. And what kind of aid are you looking for?
Roughly 400 helis built over the years. Nuff said.
Luvmyhelis is offline        Reply With Quote
Old 12-31-2011, 12:33 AM   #30
AussieHoppy
Thx LMH
being a 500 size heli, i'm hoping it'll be big enough that the extra components to fit to the heli shouldnt be an issue.
I generally fly open parks & the like
Primarily I'd like to have a good "bail out" system to help me transition from my BladeSR to this 500.
Secondarily I'm hoping to do some fpv and perhaps some amatuer photography from the 500 later, so a flight stabilizer & particularly bail out, would be a real asset for me.
I'm not expecting a miracle system, just an aid
much appreciate your advice guys
Happy New Year!
Cheers
Old 05-25-2016, 09:31 PM   #31
tucker13
Default anything changed since then?
Hello all,
I have a blade 450 3d, but to be honest, I am not looking to be a 3D expert, I just want to be able to fly the heli around at the park, may be at one point do some FPV or add a cam to it. I read this thread and looks like the Co-Pilot II is a better choice for bailout but is that more important for someone doing 3D or any kind of risky, harder flying as compare to what my goal is?
By the way, I am a beginner and would love to get the extra help to learn without crashing much and once in the air feel I can let go the sticks or make it come down safely.
I know this thread is old but hope someone is reading
tucker13 is offline        Reply With Quote
Old 05-30-2016, 01:38 PM   #32
nightflyr
CoPilot will work well either if your a beginner or have some experience.
Not everyone who flies RC helicopters are in it for 3D.
nightflyr is online now        Reply With Quote
Old 06-21-2016, 01:29 PM   #33
FE Boater Arcadia
Originally Posted by tucker13 View Post
Hello all,
I am on the same boat, I can fly comfortably with the Blade 230S, recently I got a 450X for a scale project and am looking for a FBL control that provides "Stability" mode.
I will never be a 3D pilot but sport flying is fun for me.
FE Boater Arcadia is offline        Reply With Quote
