Go Back   HeliFreak > R/C Helicopter Support > 550 Class Electric Helicopters
550 Class Electric Helicopters 550 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 03-18-2012, 11:05 PM   #1
backburner1955
Default Post your Chaos 550E Pictures Here
OK, now I am sure most of the Chaos fans know, the Chaos 550E Black Widow Flybarless Helicopter will be released to the public soon. These pics are of an early release to Chaos Forum Members who got on the list. It was a pretty solid build, no different than any of the Align Helicopters that I have built. Some reported some quality control issues, I saw a couple but nothing that a few minutes finessing couldn't take care of...
I picked this first release model up as a gift for my co-worker and friend, heli freak user Jesse T. It was a "Thank You" for giving me the idea to make the "No-Neck Transmitter Suspension Harness". It was given to him mostly assembled as a Bind & Fly, he had to go through everything to loctite it, then bind to his DX7 and setup the BeastX.
This build went together real nice, this model offers some "Upgrades" from the factory like, 2.0mm Carbon Fiber Frames, Triple Main Shaft Bearing Blocks, Aluminum Vertical Stabilizer Mount, all aluminum tail pitch parts and CF tail pushrod. This model also came with 85mm CF tail blades, 550mm Carbon Fiber Main Blades and a real Carbon Fiber Tail Boom. The blades only required 1 piece of clear packaging tape 3/8" x 1 1/2" at the root of one blade to make them static balance and CG balance perfectly.
Build includes;
1- Chaos 550E Flybarless Super Combo w/ Black Widow Head
1- PhoenixTech 1100kv Outrunner
1- PhoenixTech 100A 6S ESC
3x- PhoenixTech 601M Cyclic Servos
1- PhoenixTech 602M Tail Servo
1- Castle Creations 20A BEC Pro
1- MicroBeastX V3.0
1- Spektrum AR7000 Receiver
4x- Turnigy 5000mah 6S 25C LiPos
1 Set- 550mm Carbon Fiber Main Blades
1 Set- 85mm Carbon Fiber Tail Blades
I added a few custom Touches, but only for my own needs...
Quick UK 700 Nitro Thumb Screw Canopy Pins
T-Rex 600e Rear Frame Stiffener
A couple extra 600e Frame stiffeners in the frame
Custom made ABS Battery Tray / ESC mount to support heavier batteries
Custom Carbon Fiber Receiver platform
T-Rex 600 Boom Support Clamp
Align 600EFL Servo Arms w/ Long balls for added rod to canopy clearance
Bryan AMA# 982814
"No-Neck R/C"
backburner1955 is offline        Reply With Quote
Old 04-05-2012, 11:08 PM   #2
backburner1955
Really?... nobody has a 550E to post pics of?...
Bryan AMA# 982814
"No-Neck R/C"
Old 04-29-2012, 10:24 AM   #3
jchen
Why do I see an Align 550 clone ?
jchen is offline        Reply With Quote
Old 04-29-2012, 01:57 PM   #4
mattox
try it! you will love it!
Sponsored By:
MingDa Tech Helicopters, Astroid Designs
MKS Servos USA, Haiyin Lipos,
Scorpion Power packs USA
mattox is offline        Reply With Quote
Old 06-22-2012, 10:16 PM   #5
Dr. Evil
+1
Blade mcpX + Erazor 450 + EXI 450 + Chaos 450 + Chaos 550
Chaos 600 + Chaos 700
Dr. Evil is offline        Reply With Quote
Old 06-23-2012, 06:34 PM   #6
LowSpark
Clones wouldn't have Align parts on them <g>.
There's a very fine line between "hobby" and "mental iIlness".
LowSpark is offline        Reply With Quote
Old 06-23-2012, 07:47 PM   #7
backburner1955
If you are referring to my pics, this IS an RCAerodyne Chaos 550E, it just has a few Align 600E frame supports and Align servo arms, that is all. It has a wider frame than the Align 550E.
Bryan AMA# 982814
"No-Neck R/C"
Old 06-24-2012, 07:20 AM   #8
ady
where do ya buy these chaos 550`s from please
ady is offline        Reply With Quote
Old 06-28-2012, 04:26 PM   #9
twentyafter
They are not currently available, there was a pre release several months ago. As I understand it the kits are on the slow boat and should be available for sale soon.
http://www.scaleflying.com/
Team Lynx Heli
Warp 360 / Chaos 550 / 130X
AMA # 971952
twentyafter is offline        Reply With Quote
Old 06-28-2012, 04:31 PM   #10
twentyafter
Here is mine. All stock except for a ICE 100, Lynx Heli orange tail fin, and Lynx Heli boom bridge.
Some may wonder why the rear landing skid is white, well I had a crash a few weeks ago and only one of the skids was broken so I took the white one off of my 600 that no longer flies.
Team Lynx Heli
AMA # 971952
Old 06-29-2012, 02:18 PM   #11
ady
thank you , i`ll keep a look out
Old 07-19-2012, 02:44 PM   #12
jamiejap77
Thats a really slow boat.....
jamiejap77 is offline        Reply With Quote
Old 08-13-2012, 01:17 PM   #13
Dajavu*Xion
Im starting to think rca may have ditched the 550 from their line-up..Was this time last year the talk was out on the upcoming model.
Dajavu*Xion is offline        Reply With Quote
Old 08-14-2012, 08:53 PM   #14
mattox
We actually have not. The 550 sold out so quick to the Chaos lounge members that none were left. We were having some problems with the owner of the factory we get out kits from. As far as i know the Factory is back up and running again. But the 550 are defitnly staying with us!
Sponsored By:
Old 08-14-2012, 08:59 PM   #15
backburner1955
I think that Slow Boat from China is a dingy paddled by one Chinaman with a tiny oar going in circles...
Bryan AMA# 982814
"No-Neck R/C"
Old 08-15-2012, 12:06 AM   #16
Dajavu*Xion
E.T.A ??
Old 08-15-2012, 02:35 AM   #17
1004ron
This looks like a clone of the Align 550 V1 - how does the predicted price compare to the Align 550?
SAB Goblin 700 - CCHV120 - BEC Pro - AR7200BX - TM1000 / 450 Pro - GT5 - Tarot head / T-Rex 550 V2.1 - CC100 - BEC Pro - AR7200BX - TM1000 /
1004ron is offline        Reply With Quote
Old 08-15-2012, 02:39 AM   #18
1004ron
Delete double post.
Old 08-15-2012, 08:49 AM   #19
mattox
It was modeled after the v1 yes. we however made a few changes to the model. As far as thicker main frames, wider main frames for the bigger motors and not have to cut the frames and comprimising them. A tail servo mount to represent the Chaos 700. and a dfc 7075 alu fbl head. Full carbon tail boom, and the kit comes with full carbon main and tail blades. This is one of my favorites of the Chaos helis.. As far as price i believe the kit with blades is in the 200-300$ range
Sponsored By:
Old 08-15-2012, 08:50 AM   #20
mattox
Originally Posted by Blueram View Post
E.T.A ??
Im sorry Blueram I do not have a eta on the kits, RCA is workign very hard on getting kits over here in the states as soon as they can. As soon as I or any Chaos member heres anything HF will be the first to know!
Sponsored By:
