Old 11-17-2013, 06:26 PM   #101
Michaelpowell
Default Silence?
Why did this thread die just as it was getting somewhere?
FIRST HELICOPTERS Schluter Huey Cobra + Simprop 5 channel + HP61 engine,Schluter Enstrom,Kalt Cobra
LATEST HELICOPTERS Ikarus ECO8 + Hughes 500 fuselage, Raptor 550E + Hughes 500 fuselage, HK450 x 3
Michaelpowell is offline        Reply With Quote
Old 11-17-2013, 07:08 PM   #102
jolyboy
Default Re: Breakthrough!! Flymentor w/ FBL
Probably because there are now plenty systems with self level available that dont need as much wiring.
jolyboy is offline        Reply With Quote
Old 11-18-2013, 04:28 AM   #103
Paris
Can we have some self level brands please since i have flybar heli with flymentor but i want to go flybarless with a self level system ( cost is also an issue too )
Thanks in advance
Paris is offline        Reply With Quote
Old 11-18-2013, 02:44 PM   #104
jolyboy
Arducopter
Some DJI products
Align APS
Helicommand products
Barbarian demon
Msh brain / ikon, only can be used as a bailout since it does drift
Old 11-19-2013, 09:43 AM   #105
R_Lefebvre
Also because the Flymentor was a horrible system.
-Rob
Managing Director
NOVAerial Robotics Inc.
R_Lefebvre is offline        Reply With Quote
Old 11-19-2013, 11:06 AM   #106
Paris
I must confess that for a $70 system, the flymentor is ok for a 450 heli for a non 3d pilot as it is very affortable.
The other systems are more than $400, so for now i will stick to flymentor for my 450 heli.
If however i had a 600 or 700 heli, i would be nowhere near flymentor.
Its like having an Aston Martin and using cheap Chinese tires.
So i quess it all depends which size of heli each one of us uses
Old 11-23-2013, 03:10 AM   #107
Michaelpowell
Default Thaks
Thanks for the explanation.
I cannot agree that Flymentor was horrible. It's been fine for lots of people, including me.
But it's an old piece of equipment and I can see that the industry has newer components to use, and newer software algorithms to exploit.
As it's a hobby, a pastime, it doesn't seem right to spend hundreds on a relatively minor part of the equipment. I already spend far too much!
Old 11-23-2013, 08:12 AM   #108
R_Lefebvre
That would be true if the controls weren't so bad that it caused the heli to crash. That gets expensive fast. That's what happened to me when I used it.
-Rob
Managing Director
Old 11-23-2013, 12:02 PM   #109
bionicbone
I think it is great and had one linked into a FBL controller. However, its worth noting that if the nose is pointing straight down when you centre the sticks the self leveling can go either way ( normal or inverted ). Hence, defo not for 3D. But for learning and a basic comfort blacket then its very good, just dont allow yourself to get too attached or it takes away a lot of your skill.
CPX450, HobbyWing 35A ESC, Scorpion 2221-8, HS65MG's, HK401B, InoLabs D401HB
Trex450 Sport Combo - All Stock
Trex600ESP Combo, converted to belt drive.
HK600 Stock Build Project
bionicbone is offline        Reply With Quote
Old 11-23-2013, 06:42 PM   #110
Ivor Hill
I have been using Flymentor for 4-5 years my original one is still operating fine.
I now have about 7 of them and well as several Helicommands and Naza's.
I would not buy any more but also would not part with the ones I have, most of them are in scale heli's and work very well
It's cheap and does what it is supposed to do stabilise the heli provided the heli is in good mechanical condition and both the heli and Flymentor are set up correctly.
The forum shows that most of the problems with it are down to the user.
But of course there are better systems out there.
Ivor Hill is offline        Reply With Quote
Old 11-25-2013, 11:16 AM   #111
R_Lefebvre
I dunno, maybe mine was defective. I don't think it's just that I'm too stupid to figure it out, because after giving up on it, I joined a group who have developed our own flight controller from scratch which is far superior so... <shrug>
I can't remember, does the unit have accelerometers built in, or *just* a 3 axis gyro?
-Rob
Managing Director
Old 12-22-2015, 08:06 AM   #112
julian_laxton
Default T-Rex 450 Flybarless using Flymentor in position mode.
I have found it quite easy to set up flymentor in position mode and it works.
It works better than V-Bar...more stable.
julian_laxton is offline        Reply With Quote
Old 01-03-2017, 04:23 AM   #113
Michaelpowell
Default Time marches on
Yes, the Flymentor flies well. It's normal for those on forums to be the ones with problems. And it's clear who they are because they tell you something is hopeless, and then ask the basic questions that show they haven't studied the device at all.
Or they must have bought a duff one. Why must they? It might just be you...
Anyway for me the Flymentor was very good. It flew for five minutes at a time hands-off, and that should be enough for anyone unless you never want to fly circuits. Mine has flown so much (and with a big 3S5000 battery) that my HK450 has worn out. It needs a strip down and refurbishment.
But nothing needs to be changed on the Flymentor, it must be almost four years since I plugged it into a computer for a tune up.
Good stuff, and reliable too. It makes my 450 more stable than my Raptor 550e, and if it were not for the flybarless systems that I now use, I'd be taking it out more often.
Old 01-05-2017, 03:02 PM   #114
helibeli
I can't criticise the Flymentor either,used it for years on a flybarred 450.I fly fbl exclusively now.simple set-up.I've yet to convert my turbine to fbl.
helibeli is offline        Reply With Quote
