Go Back   HeliFreak > R/C Helicopters > Speed Helicopters
Speed Helicopters Speed Helicopters. Any brand as long as it goes FASSSSSSSSSTTTTTT!
Old 02-09-2014, 02:34 AM   #1
RJ
Default Blades for Speed Flying
For comments related to blades for speed flying.
RJ is online now        Reply With Quote
Old 02-09-2014, 02:46 AM   #2
RJ
Originally Posted by joliecoeur13 View Post
Would good FB blade be good for speed ?
I'm running some Radix V1 or I think they are FB version , so far the best blades I had on that machine...
Didn't want to get off topic in the Speed X-Blades thread.
It's not so much how a blade is labeled (FB vs FBL) which determines whether it is good for speed, but rather the properties of the blade. Some blades which came out in the flybar era before FBL was popular are still good FBL blades and can be good for speed flying (Rotortech Angled-Tip blades used by Robert Sixt at the Pöting-Speed Cup). But of course now we are seeing blades designed especially for speed flying, so it will be interesting to see what comes up.
The Radix FBL 710mm blades are good for speed, also the Radix V2 710mm (also FBL), which is what was run on SFR1 for the 2012 IRCHA Speed Cup. The Radix FBL and V2 have the chordwise CG in line with the bolt hole. The flybar version, Radix 710mm (Original) has a more rearward chordwise CG, so it will tend to lead and is less desirable for speed flying.
Left image is Radix FBL, middle is Radix V2 (FBL), right is Radix Original (flybar)
ID:	485906   Click image for larger version
ID:	485907   Click image for larger version
Old 02-09-2014, 05:42 AM   #3
NevErSn0w
Awesome! Thanks for the info!
Sent from my GT-I9305 using Tapatalk
Darcy Brown- ZenRC Field Rep
RED! Goblin 500, Quantum 4120-1200, BK Servos, from www.zenrc.com.au
ORANGE! Goblin Speed, Kosmik Kool 200HV, Pyro 850-50L, BK Servos, Brain
NevErSn0w is offline        Reply With Quote
Old 02-10-2014, 11:55 AM   #4
joliecoeur13
thanks for that , do you know the weight of the Radix V2 ? my FB version is 180gr /each
DIABOLO - Spirit
goblin 500 Sport-- Spirit
Rave ballistic 700-- Spirit
Kasama Faifa 700 -- coming soon
joliecoeur13 is offline        Reply With Quote
Old 02-10-2014, 12:44 PM   #5
mkovalcson
Mine are generally right around 200grams each +/- a few grams.
I've got one here that is 198.85g
Mark
2011' Protos 500, 2014' Logo 550SX, 2012' TDR, 2015' Protos Max V2, 2016' TDR2
2013' Jeti DS-16
mkovalcson is online now        Reply With Quote
Old 02-10-2014, 12:57 PM   #6
joliecoeur13
thanks,
I read the top post saying no more then 225Gr to reduce wear on system, but it's not like I'm racing ! so I'm sure a couple packs a week wont matter ?
thinking of getting some SG 720's , they have a thinner chord 60mm I think ..and about 220gr.
DIABOLO - Spirit
Old 02-10-2014, 01:33 PM   #7
mkovalcson
thanks,
thinking of getting some SG 720's , they have a thinner chord 60mm I think ...
I'm not pushing my TDR past 2000 rpm, but the heavy Speed blades are only going on my Banshee which is built for this, and I'll eventually try them out at 2300 rpm.
Mark
2013' Jeti DS-16
Old 02-10-2014, 03:03 PM   #8
firemedic295
I had good results with V2 on my speed TDRs. If you are planning on pushing 2500 rpm and 15 or more of pitch you will have to be very aggressive with maintainance.
firemedic295 is offline        Reply With Quote
Old 02-11-2014, 12:22 AM   #9
RJ
The Radix blades that I have measured (with a sample size of one pair):
Radix Original (FB) 710mm blade = 185.9g
Radix FBL (V1) 710mm blade = 197.2g
Radix V2 (FBL) 710mm blade = 202.0g
Note that the Radix FBL (V1) and the Radix V2 (FBL) blades appear to be from the same mold and are essentially the same weight, so the overall weight doesn't tell the whole story with regard to flight characteristics. The difference is in the position of the CGs, with the Radix FBL spanwise CG being more outward toward the tip, and the Radix V2 being more inward.
The spanwise CG is also an important factor because the equation for centrifugal force has a radius term, so for equal weights, the blade that has a more outward spanwise CG is generating more centrifugal force and more torture on your thrust bearings. The heavier or more outward CG blades tend to be more stable in FFF, but we are limited by the thrust loads, and so we have to balance the blade weight, CG position, RPM, and maximum pitch among other things.
Old 02-11-2014, 12:50 AM   #10
RJ
I think it would be helpful in our study of blades for speed flying if we started to try to quantify the characteristics of the blades we feel work well and maybe those that don't work so well. Some characteristics that I can think of include the following:
Blade name:
Blade length:
Root thickness:
Overall blade weight:
Chord in middle:
Thickness (mm/%) in middle:
Chord at root (if not constant):
Thickness (mm/%) at root (if not constant):
Chord at tip (if not constant):
Thickness (mm/%) at tip (if not constant):
Distance of bolt hole from leading edge:
Distance of chordwise CG from leading edge:
Distance of spanwise CG from bolt hole:
Description:
Comments:
It would be great if everyone can add to the databank with info on blades they have. Especially on blades that have been tried for speed flying.
Old 02-11-2014, 01:01 AM   #11
RJ
Okay, I'll start with the data I have (CGs determined with Koll Rotor Pro balancer).
Blade name: Radix Original (FB)
Blade length: 710mm
Root thickness: 12mm
Overall blade weight: 185.9g
Chord in middle: 64mm
Thickness (mm/%) in middle: 8.7mm/ 13.5%
Distance of bolt hole from leading edge: 16mm
Distance of chordwise CG from leading edge: 18mm
Distance of spanwise CG from bolt hole: 375mm
Description: Symmetrical, constant chord, constant thickness blade, slightly swept tip.
Comments: Rearward chordwise CG less desirable for speed flying.
Blade name: Radix FBL (V1)
Blade length: 710mm
Overall blade weight: 197.2g
Distance of chordwise CG from leading edge: 16mm
Distance of spanwise CG from bolt hole: 381mm
Comments: Good for speed flying, stable.
Blade name: Radix V2 (FBL)
Blade length: 710mm
Overall blade weight: 202.0g
Distance of spanwise CG from bolt hole: 363mm
Comments: Good for speed flying, stable but slightly faster cyclic than Radix FBL (V1).
ID:	486446   Click image for larger version
ID:	486447   Click image for larger version
Old 09-01-2014, 12:08 AM   #12
TheKingPhisher
Has anyone tried the new SAB Blackline 2D blades for speed flying? They're supposed to be more stable than 3D blades but also capable of doing 3D as well so you don't have to swap them out for specialized "speed only" blades.
I'm building a Goblin Speed "770" and will be using the Blackline 2D blades.
I'm not planning to do any type of competition level stuff so it doesn't have to be superfast as long as it can do some 3D without having to change setups.
TheKingPhisher is offline        Reply With Quote
Old 09-15-2014, 11:03 AM   #13
Dyain Frazier
Can any one help me on what blades to buy for speed
Dyain Frazier is offline        Reply With Quote
Old 09-16-2014, 04:13 PM   #14
TheKingPhisher
Why not try the 720mm speed specific blades from SAB?
Old 09-26-2014, 09:03 AM   #15
dude25
I was running on my TDR Radix 710 FBL V2, these are actually my favourite allrounder blades.
Since a couple of flights Im running Radix 710 FAI blades with the golden spikes, the blades are aroung 220gr weight each. These blades are fantastic for speed runs, very locked in, as flying on rails. the center of gravity is around 4cm more outward than the Radix 710 FBL V2 and 2cm compared to DH711 Blades which are also pretty good for speeding.
Saw last week a TDR with the XBlades 713 mounted, incredible wide blades, look fantastic
dude25 is offline        Reply With Quote
