Go Back   HeliFreak > R/C Helicopters > 3D Printing
3D Printing Discuss 3D printed items and 3D printers as they relate to RC
Old 04-05-2015, 02:39 PM   #1
Ron_R
Default 3D Printer Idea for Receivers
I'm wondering if it would be possible to 3D print a little bracket for the Receivers we use to clip on and hold the Servo/ESC/BEC leads in so they can't pop out.
I'm thinking something that clips over the whole Receiver and the leads over the top, this way once you plug in your leads, you can clip it in place and it presses the leads in tightly so they can't eject. I imagine the dimensions for each FBL unit would be different, but the basic concept would be the same.
I'm OCD and hate the idea of sticky tape or hot glue to hold the leads in place. Sticky, yucky.
Any thoughts?
DX7; Goblin 500; X3
Ron_R is offline        Reply With Quote
Old 04-05-2015, 03:29 PM   #2
myxiplx
It'd probably work, but I love hot glue. No sticky residue or anything, it just peels straight off if you need it to.
Backyard fun: Trex 250 SE with VX1e
At the field: Gaui X3 360mm + Gaui X3 380mm, with VX1n + VX1e | Trex 600N with VX1n
TX + Sims: Jeti DS14 and Realflight (Wireless)
And now a Lynx Team Pilot :-D
myxiplx is offline        Reply With Quote
Old 04-05-2015, 04:26 PM   #3
Skidpad
You could probably do that, Ron, but I envision something as having to clip down from the top of the fbl unit itself, and if this was done, then I couldn't see my pretty little - and necessary - led's on the unit
I'm a hot glue guy myself (peels right off as said above), and when applied correctly, doesn't look bad at all. I fly with a guy who uses gyro tape (the 3M 4010/4011 clear) and then to make it look better he applies a small piece of black electrical tape over it...looks pretty slick...but still hot glue for me.
180CFX, Trex 550E (night), Goblin 570, Goblin 630C, DX8. Team Lynx Heli Innovations Pilot
Skidpad is offline        Reply With Quote
Old 04-05-2015, 05:31 PM   #4
Excalibur3
It could mount on the frame and the gyro could snap into it with a piece to hold the leads In.
Trex700Pro/Trex700LTop/X3/14sgh T$3D
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote
Old 04-05-2015, 05:44 PM   #5
Fauropitotto
Take a look at these guys.
http://blade550xupgrades.com/trex-50...atellite-mount
It's a 3D printed mount for satellites, and I'm sure it could be modified to include a clip to keep the cable in.
Fauropitotto is online now        Reply With Quote
Old 04-05-2015, 05:49 PM   #6
thaddeusthompsonsr
Looks great! i want one
T Thompson
Hammond LA 70401
thaddeusthompsonsr is offline        Reply With Quote
Old 04-05-2015, 06:37 PM   #7
Kasmenu
Hey guys
I am also a bit OCD and hot glue works but is not neat enough for me, I tried different methods and came up with some clear heat-shrink leaving the last pin open for setup.
I figured the combined grip of all the servo plugs would be enough to keep it in place. From the photo you can see it over the plugs, I still need to heat the heat-shrink above the plugs which is why its still loose.
Kasmenu
Kasmenu is online now        Reply With Quote
Old 04-05-2015, 09:20 PM   #8
ddhuans
Hot glue is simpler and cheaper, you can remove the hot glue when needed with 90% alcohol
ddhuans is offline        Reply With Quote
Old 04-05-2015, 10:51 PM   #9
crashcopterman
Hot glue is the cats ass, but if it's too messy for you grab a section of zip tie and apply the glue to the ribbed side of the tie and place on servo leads. It's very secure and when you need to remove it most of the glue will stick to the tie. It's something I came up with a couple of years ago, quick and easy and effective.
Cheers
Steve
Nano CPX || 130x || 450 3D converted to 450X || 360CFX || 550X || ALeeS Rush 750 Evolution 'My flight style, determines my crash style"
crashcopterman is offline        Reply With Quote
Old 04-05-2015, 11:07 PM   #10
DaveHolland
I always just hot glue them and then compress it with my finger so its a clean straight line. Sort of like caulk.
Spartan Vortex, Scorpion Motors, ExperienceRC Batteries, OMG Servos
FrSky Taranis
DaveHolland is offline        Reply With Quote
Old 04-06-2015, 10:01 AM   #11
skunkworx
They make receiver clips. Maybe not for FBL units specifically but they do have different clips available for connectors.
Tim
KBDD TEAM PILOT
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote
Old 04-06-2015, 10:06 AM   #12
Inverted2112
I've been using this for quite some time.
Just roll a "snake" of it and wrap it around. Can easily be removed and immediately reapplied... Never had anything come lose.
Current favorites...
Oxy 3, Goblin 380, Logo 400SE, Logo 480Xx, Goblin 500, TBS Gemini, 250 FPV Quad Racers, bunch o' Planks, etc..
Inverted2112 is offline        Reply With Quote
Old 04-06-2015, 02:52 PM   #13
heli_crasher1
Why would leads eject?
heli_crasher1 is offline        Reply With Quote
Old 04-06-2015, 03:00 PM   #14
LyleT
The can work themselves loose from vibrations and wiggling wires.
LyleT is offline        Reply With Quote
Old 04-06-2015, 07:17 PM   #15
Excalibur3
Famous last words lol
Old 04-06-2015, 08:02 PM   #16
TucsonFlyer
Why won't leads eject?
There, fixed that for ya
I'm a fan of the 3M double sided foam tape. I have tons of it from securing basically everything on my helis and I like that I can size it to cover the edge of the fbl unit and the leads.
Synergy E5s 12S!
Minicopter Diabolo 550
Mikado 480 eXXtreme
GauiX3 350mm 6S
TucsonFlyer is offline        Reply With Quote
Old 04-06-2015, 08:46 PM   #17
Michaelinpr
I use ShoeGoo. It is self levelling so it looks a little cleaner. And as with hot glue it protects the fragile wires. Spektrum sat wires are notorious for broken wires indside the wire casing. With ShooGoo or hot glue the wires can bend and break at the connection point.
Nice ieda though. I get your point.
Spartan Vortex Scorpion Power Systems BK Servo Switch Blades CITIZEN 65
Protos 780 Protos 715 Protos 380
Michaelinpr is online now        Reply With Quote
Old 04-06-2015, 08:52 PM   #18
heli_crasher1
I have never had that happen
Old 04-06-2015, 08:55 PM   #19
Fauropitotto
Many others have.
Wouldn't you rather be safe than sorry?
Old 04-06-2015, 09:26 PM   #20
atomic
Shoe Goo is a fantastic product. I have experimented with so many different adhesives and Shoe Goo is always my go to glue. Invented by a senior executive At Hughes aircraft with a degree in physics, and an extensive background in chemistry. The glue is great for all types of RC. Great on lexan and just about any other material. Also great for waterproofing.
It's a extremely durable flexible adhesive and filler that comes in black or clear.
Sounds like I work for the company? No, but I highly recommend this product.
Also with an ice cube or wet finger you can make awesome looking feathered edges, textures and blends.
This is not your daddy's glue. :-)
Instamorph or Pollycaprolactone is also an awesome product.
http://en.wikipedia.org/wiki/Polycaprolactone
atomic is online now        Reply With Quote
