Old 12-08-2015, 08:04 PM   #1
seanh
Default DX7 W/ Pixhawk, APM 2.8 and Trad Heli
I will be trying to return to the heli world after a few year break, wanting to work on a drone/autonomous project and can use some help.
The issue is that I will be wanting to use a conventional heli with a DX7 and going on the cheap, using a Pixhawk or APM 2.8 flight controller. I call it an issue because from what I can tell I need an 8 channel controller to make this happen.
seems I need channel 8 for the throttle and some short of dial on the transmitter...both of which rule out the Dx7
So, the question is, can I make the chosen controller work with the DX7....the bird will be an electric old style trex 600.
Basically I'm trying to make due with what I have instead of selling off stuff and buying a new tx and "drone" type bird. Eventually I'll go the multi-rotor path but for now I simply don't have the funds
any direction would be helpful.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910
seanh is offline        Reply With Quote
Old 03-29-2016, 04:19 PM   #2
flynhawn
I was able to reprogram my DX7 to work and fly my FW550 using a Naza setup. But I can't help you out here with your Pixhawk or APM flight controller.
Hope you find a solution!
Align Trex 450SE V2 and Trex 500, Moded E-flite CX2 and Nano QX, DJI F550 w/Naza M and E330, DX7 Tx,
flynhawn is offline        Reply With Quote
Old 04-16-2016, 04:35 PM   #3
wrightmw
From here: http://ardupilot.org/copter/docs/tra...nd-motors.html
The APM2s input channel mapping is:
Channel 1: Aileron (aka Roll)
Channel 2: Elevator (aka Pitch)
Channel 3: Collective Pitch
Channel 4: Rudder (aka Yaw)
Channel 5: Flight Mode
Channel 6: In-flight tuning knob
Channel 7: Aux function switch (i.e. Camera trigger, Sonar on/off)
Channel 8: Main rotor speed
You could swap CH8 for 7 and you have all you need. Just loose a some camera function.
wrightmw is offline        Reply With Quote
Old 04-16-2016, 06:51 PM   #4
seanh
Flynhawn- How did you reprogram the DX7? I'm not aware of any place to connect to a computer...Did you make a custom interface cable/plug?
I never tried to get the DX7 to work with the APM...I ended up just ordering a Taranis 9D+ Given the difficulty and time available, still haven't messed with the project.
Old 04-25-2016, 12:07 PM   #5
darne
I used my Dx6i with APM and a trad. 550 size.
Had to use some switch-hack to make it work, but I'm getting a new radio for cams and other stuff now.
darne is offline        Reply With Quote
