Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 02-17-2016, 05:30 PM   #1
Brunswickbmech
Angry New blades
I recently purchased an X Cell Graphite 46. Other then a few missing linkages all it needs are new blades. What would be a good replacement for my helicopter. I'm new to helicopters and not looking for top of the line, just some ok training blades
Brunswickbmech is offline        Reply With Quote
Old 06-07-2016, 01:55 PM   #2
HELI_FUN
Default Blades
I have a x-cell ion and it came with PRO 3D blades, they look good but are fairly cheap. I will be upgrading to halo blades. also you can find a good amount of different blades at hobby king
HELI_FUN is offline        Reply With Quote
Old 06-18-2016, 07:21 PM   #3
Dennis P
It really depends on what you are putting in it for power. If it is a OS46FXH or something like that from the time period I may go with something like a Rotor Tech 560mm rather than a 600 size blade. I used to run 550s and 600s on my FXH46 in a TSK Mystar46 , pitch had to be limited some on the 600s and todays blades may load it even more. If you are running a newer 55 size motor no worries but check for tail blade clearance as I cannot remember if they would fit anything past 600s or not.
Team Renegade R/C Heli Flyers
Dennis P is offline        Reply With Quote
