Old 04-22-2016, 08:50 PM   #1
Troy1
Default Microbeast Plus headaches
Hello all,
I recently purchased a Trex 500L Dominator equipped with the Microbeast Plus. I have gone through everything imaginable for the setup. The system still does not work correctly. This is my first experience with a microbeast, so I'm not sure I'm setting it up correctly. I have set up in the past several other types of flybarless systems. I think this unit is defective. Everything is set up correctly with the Servos, confirmed through receiver, when connecting it to the microbeast it goes crazy and will not move correctly. I have fall owed the manual to no avail. HELP
Troy1 is offline        Reply With Quote
Old 10-22-2016, 03:39 AM   #2
ChasCS
Originally Posted by Troy1 View Post
Hello all,
Did you find a solution to your question? As you never posted a follow up. Perhaps posting this in the BeastX section, http://helifreak.com/forumdisplay.php?f=239, would bring you some replies. Best wishes.
Chas
Align TRex 700E DFC HV~Spektrum DX8 MAAC 91236
Blade mCPX BL Blade mQX DJI Phantom 3 Pro'~iPad Air 2 Cellular
Heli-Max Voltage 500 3D Heli-Max 1SQ~Spektrum DX6i
Parrot AR Drone 2.0 Traxxas QR-1 RealFlight Drone 6.5
ChasCS is offline        Reply With Quote
