Old 08-19-2016, 09:31 AM   #1
jwellsy
Default Would You Buy A Used Gyro?
I'm wondering how you guys feel about buying used gyro systems?
I no longer buy used ESC's, been burned too many times even with ones that claimed to be NIB and sold by guys that have great feedback. So for greater reliability and confidence I just buy ESC's from distributors, and I stopped having ESC problems.
Now, I'm faced with buying my first gyro system (probably a BeastX for programing simplicity). But, I'm not really sure how good of an idea buying used is, and how much buying used would increase the odds of crashing.
jwellsy is offline        Reply With Quote
Old 08-20-2016, 09:43 PM   #2
nightflyr
There will always be some risk in buying used equipment.
That being said, using PayPal offers a recourse if the item is defective.
Might also suggest you avoid items that say sold "as is".
Also if purchasing through the sales forum, you can check the sellers feed back rating.
nightflyr is online now        Reply With Quote
Old 08-20-2016, 11:00 PM   #3
Epoweredrc
I have purchased a few FBL gryos and only had one time that got a bad one but the guy was super great and sent me another and it seemed to work. but it was cheap anyways... i have gotten many many old FB gyros never any issues. and same with my father. i think as anything you buy used just make sure you feel the person is honest, look at how long they been a member how often they post and there feedback.
XK252,K120,Cpx450 ZYX,,Trex600 Beastx, Gremlin,POD Racer, GLH,Whipit,Z-84, Elelctric Shock AMA 27 yrs.
Epoweredrc is online now        Reply With Quote
Old 08-21-2016, 03:29 AM   #4
HEXAHYDRATE
No problem buying used. Accept for an older Ikon. They were known to just die especially after crashes.
Goblin 770 Comp, Raptor E700, T Rex 450-600-700 DFC, 600N, Blade NCPx-130-180. Citizen 778
HEXAHYDRATE is offline        Reply With Quote
Old 08-21-2016, 08:41 AM   #5
guyguerra
All but two of my Helis have Demons on them, which is probably eleven? Of those, I only purchased one new and that was when they first came out. I haven't had one go bad. I suspect it's because there's nothing in it that moves, and that the firmware is upgradeable. I even have a couple that were sold under the old name, and they are fine. The old versions prior to firmware 2.0 have to be sent back to the factory to update them, so be careful with that. You might want to Google that version as I don't remember the exact version.
We are all different though, and experiance can vary, causing opinions to be different between all of us. I also have bought several used Kontronik ESC's and really when a problem occurs, it's usually not weather I bought it used, but some other reason for the failure.
Logo 800 // Logo 700 12S/14S// Logo 690 // Logo 400 // Mostro 700E's// Whiplash 700E// Gaui NX7 // Gaui NX4 // Gaui X4 // Gaui X3 //Goblin 570 // Trex 250 // TBS Discovery /Naza M2 // Jeti DS-16 // V Control // Jlog // BD3SX// VBar Neo// Lifetime AMA
guyguerra is offline        Reply With Quote
Old 08-21-2016, 11:43 AM   #6
Grumpy_Old_Man
Most of my FBL units are used. Vbars especially are bargains right now as the Mikado faithful are all moved over to the Neo. I've never had any issues at all.
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 09-26-2016, 09:39 AM   #7
yohto34
If the difference of price is few..i suggest you to buy new equipment
yohto34 is offline        Reply With Quote
