Old 09-12-2016, 10:18 AM   #1
rmorse99
Default Blade 450/ Flymentor- Servo's won't center
I have the installation complete, servo's going correct direction for Transmitter lever inputs and correct response from Flymentor when tilting the Heli. When attempting to center the servo neutral, there is no response from the servo for positive or negative values, servo lever doesn't move. This happens for Ail, Pitch and Elev. servos. I got out a new servo and installed on bench, again no response when trying to center servo neutral. Any ideas?
rmorse99 is offline        Reply With Quote
Old 12-01-2016, 09:51 PM   #2
pril250
It is a long time since I messed with FM are you trying to do this whil FM is active, meaning turned on?
Blade400
pril250 is online now        Reply With Quote
