Old 09-17-2016, 11:01 PM   #1
BLK-HK
Default Skookum 540 Gyro setup
Hi Gents,
Could I have anyone with experience to help me setup this to a scale model?
I intend fitting this gyro to a four blade main rotor Aling trex 600 modified a lower RPM motor 530 Kv and ESC. I am following instruction from the manual and wizards but not getting the expected results and progressing through the setup.
Appreciate your help!
BLK-HK
BLK-HK is offline        Reply With Quote
Old 09-18-2016, 11:41 PM   #2
Block137
Try posting here instead
http://www.helifreak.com/forumdisplay.php?f=118
Make sure you describe the problem you are having
Block137 is offline        Reply With Quote
