Go Back   HeliFreak > R/C Helicopters > Speed Helicopters
Speed Helicopters Speed Helicopters. Any brand as long as it goes FASSSSSSSSSTTTTTT!
Old 11-11-2016, 09:00 PM   #1
slikwrik
Default 500 class speed - cyclic servo torque requirements
Would appreciate your advice.
What is the minimum/ideal torque required for a 500cm blade class speed heli - I have CL5180 cyclics, but my power jive has a 6V max BEC.
At 6v those cyclics provide:
90 oz-in (6.5 kg-cm)
At 7.4v it's 110 on-in (7.9 kg-cm), but I'm trying to avoid an external BEC for weight.
Is it enough at 6v? Will the servos be okay?
Thanks!!
slikwrik is offline        Reply With Quote
Old 11-11-2016, 11:15 PM   #2
Vinger
They should work at 6V for speed flying. Try them and if they are not enough you will experience porpoising flight, then you can just fit a 8.0V power supply.
Gaui R5, Henseleit TDR +TDR2, Banshee
Kontronik ESC, iChargers, VBar, VControl, JR XG11
Old hand at Planks
Vinger is offline        Reply With Quote
Old 11-14-2016, 10:35 AM   #3
Justin Pucci
There's not a lot of collective experience out there on this size yet, but I'm running my 3-bladed Goblin 500 speed machine on full-size coreless MKS HV1230/1250's and it works wonderfully. I'd guess anything at/above 100 in-ounces is probably sufficient.
Justin Pucci is online now        Reply With Quote
Old 11-14-2016, 11:15 AM   #4
slikwrik
thank you guys, really appreciate the help.
Justin, since the power jive supplies max 6v so I only get 90oz-in, do you suggest I bypass any BEC and just go with a 2s Rx lipo pack to achieve the higher V & torque?
Old 11-14-2016, 04:19 PM   #5
iscripter
Here is some info on the specs For the KST BLS815 servos I ran this year at the IRCHA Speedcup in my GAUI X5 Formula. I am not saying you need to get KST servos but I just wanted to add some more information for this size class of heli and speed runs. I ran mine at 7.4v and they perfomed great.
Specifications:
Operating Voltage: DC6.0V-8.4V
Dimensions: 40.5*20*39.5mm
Torque:
14Kg.cm@6.0V
17Kg.cm@7.4V
20Kg.cm@8.4V
speed:
0.09sec/60@6.0V
0.08sec/60@7.4V
0.07sec/60@8.4V
weight:68g(with box:132g)
working frequency:
1520us/333Hz
Citizen 682 | Gaui X3-Spartan VX1n | Gaui X5-Spartan VX1e | Goblin 700 Speed-Spartan VX1n
JETI DS-14
iscripter is offline        Reply With Quote
Old 11-15-2016, 01:14 AM   #6
slikwrik
thanks for the input - looks like you get as much torque as you could possibly need from a full size servo. I'm wondering if my mini size CL5180s are pushing it.
