Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 12-01-2016, 07:29 PM   #21
Squier250
My kit just got dilivered at my door. The box have a red circle sticker that says "lengthen shaft" so I'm guessing inside I will find the longer tail shaft, but I don't know if it will have the older shorter one. I ordered mine through the trex store. I'll have to see if my motor has a flat spot on the motor shaft. Too bad I don't get to build it until after Christmas since it's my girlfriends gift to me for xmas.
Squier250 is offline        Reply With Quote
Old 12-02-2016, 12:11 AM   #22
Dipweed
Red face Red Sticker Kits
Originally Posted by DJG24 View Post
Are you sure both shafts are the Same size? My kit also came with an extra shaft in the box but it was longer. It's not much longer but was for sure the longer one.
Yes
The shaft installed and the extra shaft are the longer:
470L Tail Belt Feathering Shaft H47T008AX $6.99
The tail blades are the longer:
74 Tail Blade HQ0743A $7.99
My 470Lp kit box has a red sticker w tex Lengthen Shaft.
Align&HK450 L/470L/150 DFC/Blade stuff
DJI/AR Drone
Dipweed is offline        Reply With Quote
Old 12-02-2016, 11:50 AM   #23
Dipweed
Red face 470LP KIT Build Parts
More 470L parts on order:
470L Counter Thread Main Linkage Rod Set H47H004AX $5.99
470L Swashplate Leveler H47H010XX $10.99
Also
A few extra 2150mAh and 2100mAh 6S LiPo
I was supersize I do not have a 6mm swash Leveler. One good thing this Leveler uses a sleve so it can be adapted for 470L, 450L, and can be sleved for all my smaller Heli.
DJI/AR Drone
Old 12-02-2016, 09:28 PM   #24
DJG24
Originally Posted by Dipweed View Post
More 470L part on order:
Also
I forgot to order a swash leveler when I got my kit but lucked out when the one for my old X3 worked on the 470 perfectly.
DJG24 is offline        Reply With Quote
Old 12-05-2016, 08:13 AM   #25
Dipweed
Default 470L LiPo
Measured 470Lp LiPo Box
40.5x53.5x150mm and that 150mm can easily be extended to +200mm if needed.
Have on order
LiPo Low Voltage Alarm (2s~6s)
Battery Harness 10AWG For two 3s LiPo Packs In Series
and
The two 2200mAh 3s LiPo that I have will fit my 470Lp but will update post if any issues come up.
ID:	683122   Click image for larger version
ID:	683123   Click image for larger version
DJI/AR Drone
Old 12-05-2016, 08:18 AM   #26
Number
Why are you using XT90s?
Number is offline        Reply With Quote
Old 12-05-2016, 09:21 AM   #27
Dipweed
Red face Power to Choose
They have series harness w
XT60, Deans, EC3, or XT90.
So
It is your choice on what connector you use for your 470L series harness.
Last
As you know the two 3s w series harness the voltage will be kicked up to 6s but the amps will stay the same or limited to one of the 3s LiPo amp rating (V=IR stuff).
DJI/AR Drone
Old 12-05-2016, 12:06 PM   #28
Dipweed
Red face Trex 600 Low $ LiPo
$15 and $12 6s LiPo
Align Trex Store.com has Trex 600 6s LiPo that fit the Trex 470Lp. I have these two LiPo in hand and they easily fit in my 470Lp.
2150mAh 6s 25C LiPo $15.00 w JST
2100mAh 6s 20C LiPo $12.50 w TP (no JST)
Question?
Align Trex 470Lp manual limits the 470L to 1,400mAh to 1,900mAh Why?
DJI/AR Drone
Old 12-05-2016, 12:08 PM   #29
Number
Because that's a reasonable size. There's no reason to run a battery 2100mAh or so. Also those old Align batteries are on sale/blowout because they are outdated and performance is not good compared to newer ones. Please note, those are only 20-25C--not enough for a helicopter this powerful.
Old 12-05-2016, 12:25 PM   #30
Dipweed
Red face 20C 25C 65C
Thx
They were super super cheep so I picked them up just for a test drive.
So
Trex 600 $12 and $15 6s LiPo will fly sport but will bog down in 3D.
Ok
I also have on order 1500mAh 6S 65C LiPo that should do the trick.
DJI/AR Drone
Old 12-06-2016, 03:19 PM   #31
Dipweed
Red face 470L Belt
Belt Setup
Tight enough that turning the head by hand and holding the tail it doesn't skip easily, not much tighter (still fairly loose). It's a trade-off; you can also do it quite tight, but you will notice the mechanics won't spin so freely.
Also
Tight enough not to skip in the air.
New belts stretch a little and on some heli the boom can slip, so do a check on boom and tension after a couple of flights.
Temperature does not effect the belt but an aluminum boom will contract and expand in the cold and hot weather.
470L Storage
You could reduce the belt tension but just like in your Ferrari or McLaren (I'm a Honda SUV guy) it is not necessary.
Align 470L Possible Upgrade
Auto tensioner Kit $2
DJI/AR Drone
Old 12-06-2016, 03:25 PM   #32
Number
No need to change the tension for storage. The tension won't change noticeably.
Old 12-07-2016, 01:17 AM   #33
Dipweed
Red face Tail Shaft w Set Screw
New longer shaft and set screw setup.
470L Metal Tail Rotor Shaft Assembly H47T021XX $9.99
I will bet there will be higher tooth count part coming out very soon. This will make it super easy to replace the belt.
ID:	683312   Click image for larger version
DJI/AR Drone
Old 12-07-2016, 08:27 PM   #34
Dipweed
Red face Metal Crash Kit
New Metal Upgrade or Crash kit.
470LM Metal Upgrade Kit H47H015XXW $82.99
Lp to Lm in one broad stroke w this low cost metal kit.
ID:	683415   Click image for larger version
DJI/AR Drone
Old 12-08-2016, 08:27 AM   #35
chan
Great product. but only at aligntrexstore..
Shipping fee outside USA is tremendous so have to wait other stores.
chan is offline        Reply With Quote
Old 12-08-2016, 08:44 AM   #36
learnedthehardway
Not uncommon for storing over the winter. Sometimes it gets a hard lump where it was wrapped around the pulley on the tail shaft for a long period of time that can cause vibe issues. Totally unnecessary for short term storage of course.
Have heard of it anyway, never experienced it. I fly all winter and never had it happen on airframes that sat for months but some ppl have had it happen.
x2 Mini Protos 6s stretch-SK540/KDS Chase 360-SK540/180cfx/UMX Pitts
I'm a rocker, I'm a roller, I'm a right out of controller, I'm a wheeler, I'm a dealer, I'm a wicked woman stealer, I'm a boozer, I'm a user....I'm a rock and rollin man...
learnedthehardway is online now        Reply With Quote
Old 12-11-2016, 01:52 PM   #37
Dipweed
Red face 470L Speed Fuselage
When compared to std 470L $32 40g canopy this low cost aerodynamic Speed Canopy is a winner
470L Speed Fuselage HF4701 $87.99
Specs
●Body length:700mm
●Body width:100mm
●Body high:132mm
●Weight:Approx. 132g
ID:	683774   Click image for larger version
ID:	683775   Click image for larger version
DJI/AR Drone
Old 12-14-2016, 08:24 PM   #38
Dipweed
Red face Align's 470L part $.
Tail servo with out any brace. I like it!
470L Carbon Fiber Tail Linkage Rod H47T002XX $9.99
Question?
What is the diameter of the Align 470L CF rod?
DJI/AR Drone
Old 12-17-2016, 07:48 AM   #39
Dipweed
Red face Tail Drive Belt
470L use a spring loaded pully system to tension the tail dive belt.
To reduce all tail drive belt tension you screw in the 2 socket screws all the way.
Belt Setup
Bottom out (tighten) the 2 socket screws This compresses the tension spring,
Then back out the 2 socket screws 1.5-2 turns.
ID:	684579   Click image for larger version
DJI/AR Drone
Old 12-18-2016, 02:01 PM   #40
Dipweed
Default Auto Belt Tension System
I would like to see a Auto Belt Tension System.
Maybe a new tail block with new hardware.
Hopefully Align has one in the works.
DJI/AR Drone
