Go Back   HeliFreak > R/C Helicopter Support > 470 Class Electric Helicopters
Old 01-09-2017, 11:36 PM   #1
Necroscope
Default Is anyone using a Brain2 FBL
Just woundering if anyone is using a Brain2 fly barless unit on their 470L?
If so which unit did you use and where did you mount it.
I am thinking of using one so I can utilize the Jeti intergration and just woundering if I should go with a unit with top connections or front connections.
Bob1 6s with SK-720BE & GPS-1.
Bob 2 with SK-720BE
Bob 3 with SK-720BE & GPS-1.
Jeti DS-16. Whovian.
Necroscope is online now        Reply With Quote
Old 01-10-2017, 12:18 AM   #2
Number
I'm using a regular Brain. Rear mounted with wires front.
Number is offline        Reply With Quote
Old 01-10-2017, 12:51 AM   #3
Necroscope
Ok, that looks sweet. Can't see plug or wires. I think that has just answered my question.
Thanks very much.
Bob 2 with SK-720BE
Old 01-10-2017, 12:53 AM   #4
Number
Do be aware I trim and crimp all my wires. Would be somewhat difficult for it to be that clean without doing that. FYI just leave the canopy posts finger tight and you can remove them by hand and pull the AR bracket out to get to the plugs (might still need to use pliers though).
Old 01-10-2017, 01:11 AM   #5
Squier250
I am using an ikon 2 Bluetooth. I am using the bottom gyro mount. I have 1 sat reciver under there as swell and I'm getting a second gyro mount to hide some wires that are around the top gyro mount and I will be mounting the second sat reciver on the top gyro mount.
Squier250 is offline        Reply With Quote
Old 01-10-2017, 01:13 AM   #6
OnTheSnap
MiniBrain2 is prob a perfect fit.
MSH USA
Xnova
Xpert
OnTheSnap is online now        Reply With Quote
Old 01-10-2017, 01:31 AM   #7
Necroscope
Ok, that sounds good as well. I will probably use th bottom mount as well, and will probably mount my Jeti Rex3 receiver on the top mount. Also I think I will probably cut and fit new plugs on the servo leads to help keep the wiring clean.
Bob 2 with SK-720BE
Old 01-10-2017, 01:38 AM   #8
Necroscope
Would the top plugs be an issue if I used bottom gyro bracket?
Just thinking about clearance and wires getting caught in the main gear.
Bob 2 with SK-720BE
Old 01-10-2017, 02:33 AM   #9
OnTheSnap
What's the height available? It's very compact.
MSH USA
Xnova
Xpert
Old 01-10-2017, 08:20 AM   #10
Number
I'd probably put it on the CF bottom plate if I used the mini. But Idk how you'd get to the USB there... the Bluetooth is cool but way too unreliable for me to, say, do an entire setup. Fine for a setting or two. But it freezes up way too much and I'd probably die before I got the full setup done. And remote USB is laughably expensive.
Old 01-10-2017, 09:21 AM   #11
OnTheSnap
It comes with the remote USB. So you can put it anywhere that's accessible.
MSH USA
Xnova
Xpert
Old 01-10-2017, 10:25 AM   #12
Squier250
Like I said, I have the ikon2 Bluetooth version using the bottom mount, what i did is installed the 2 sat recivers, used a bind plug to bind to my transmitter. Then used the supplied USB cable to set up the ikon on the computer after downloading the software and doing all the nesesary updates. Now I use the Bluetooth to do minor adjustments if I need to.
If using a mini, I don't see how you could use the bottom gyro mount but maybe you could just install it in the bottom plate. I say use the ikon Bluetooth version or install it on the top mount with the wires facing forward so that the USB port is facing back and you have access to it.
However since I have mine on the bottom gyro and wires facing back, the usb is facing forward, if I want to, I can just remove the battery and I can still get the USB port. Or I can just remove the 6 bottom plate screws which take seconds, then the whole plate and landing gear comes off and I can get the usb that way.
Old 01-10-2017, 10:44 AM   #13
OnTheSnap
MiniBrain2 has a remote USB port natively so it solves the problem.
MSH USA
Xnova
Xpert
Old 01-10-2017, 12:27 PM   #14
Number
Ok then lol. I guess only the Mini and Micro come with it?
Old 01-10-2017, 01:08 PM   #15
Squier250
What is the remote port? Is it like a USB extension wire?
Old 01-10-2017, 01:12 PM   #16
OnTheSnap
uBrain2 and miniBrain2 both don't have USB port inside the main case and use remote USB. Included.
For miniBrain2 it was the first Brain2 we built and all testing was done on 700/770 setups. It's the smallest fully capable and electrically robust unitnout there. Zero compromise. The top pins shrink the foot print and allow it to fit in very tight spots with the remote USB fully accessible. BT module and be freely swapped with the USB module.
MSH USA
Xnova
Xpert
Old 01-10-2017, 01:18 PM   #17
OnTheSnap
It's a tiny light module that plugs into a side port on MiniBrain2. You can mount it permanently or just easily it in when you need to. Port is on the side of miniBrain2 and easy to access.
Note that the remote USB is also sold separate and can be used on the units that don't have integrated Bluetooth.
MSH USA
Xnova
Xpert
Old 01-10-2017, 03:04 PM   #18
markpimmy
I have just put a Neuron fbl in my 470 on the lower mount with no probs and its a top plug connection. I just had to make sure the connector ports were pointing to the back of the heli. Plenty of clearance there. Same for the Brain I imagine.
Goblin 500 sport BD, Goblin 420 BD, Trex 500l BD, Trex 470l Dominator Neuron, Blade 230s, Blade Nano CPX. DX9 Black Edition. Aurora 9x, Maxima SL
markpimmy is offline        Reply With Quote
