View Poll Results: What power system do you prefer for a 700 size electric?
BEC 37 26.43%
BEC + UPS Backup 41 29.29%
RX Pack 49 35.00%
RX Pack + UPS Backup 12 8.57%
Other 4 2.86%
Multiple Choice Poll. Voters: 140. You may not vote on this poll
Old 01-10-2017, 07:32 AM   #21
Relisys190
So from a weight standpoint. My 2S lipo is 116 grams.
With a BEC type ESC would probably weigh more than my Castle 120 ICE2
I most likely would not notice the difference in flight.
Maybe yes, maybe no
-Markus
*LINKS*
* G660c IKON * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote
Old 01-10-2017, 07:36 AM   #22
Johnny31297
My BEC is 40g, my backup 16g. Go figure.
Jonas
LOGO 690 SX, LOGO 600 SX, Forza 450, Oblivion 300+
(***WARNING*** Stop Spamming Helifreak)
Johnny31297 is online now        Reply With Quote
Old 01-10-2017, 07:56 AM   #23
Ace Dude
Kontronik ESC with integrated BEC and buffer pack. Extremely reliable and neat and clean wiring.
Ace Dude is online now        Reply With Quote
Old 01-10-2017, 08:02 AM   #24
Grumpy_Old_Man
Originally Posted by Thoemse View Post
If it only needs to switch on once it has paid itself many times.
One actually in an indirect way caused my mates Goblin 630 to be wrecked. He had a (quite light) crash and the Rx pack was thrown out on initial impact. Normally that would have killed all power but he had an ultra-Guard fitted which kept the Rx powered and the heli thrashed itself to death (a full re-kit)
Of course if he'd have hit throttle hold he'd have saved it but he froze.
KDS Agile 7.2 | Goblin 770 Carb. Comp | Goblin 630 Comp | Trex 600Pro (626 stretch) | Kasama Dune 600 | Compass 7HV U | Trex 700X | KDS Chase 360 | Blade 180CFX
Grumpy_Old_Man is online now        Reply With Quote
Old 01-10-2017, 08:21 AM   #25
Thoemse
Hehe you can have the same discussion with rescue. I had my heli wrecked by rescue. If used right it would be good though. Crashing made me the master of throttle hold though.
I can't fly well at all but damn am I good with throttle hold!
I got the crashperience!
T-rex 700X, Protos 500, Hughes 500E (450 Pro), T-rex 450 V2 pro
Thoemse is offline        Reply With Quote
Old 01-10-2017, 08:28 AM   #26
BadVad
I run a Castle BEC Pro on my 700 but it's only wired to run on one of the 6s 5000 flight packs.
Not sure I trust any BEC enough to run it on 12s. I'm no electrician, but it just seems like a lot of voltage reduction.
-Proto x, nQX, nano cp s, mCPX BL, 130x, 180cfx, 230s, 200qx, Trex 450 DFC, 450L 6s, 450 Quad, 700x, DX9
-5 year IRCHA vet
-Give a man a helicopter and he flies for a day. Teach a man to fly helicopters and he flies for a lifetime!
BadVad is offline        Reply With Quote
Old 01-10-2017, 08:31 AM   #27
Thoemse
All align combos come with one. It is the Hobbywing 130A V4 ESC and there have been no negative reports about that one.
I would say that BEC is solid. I still went for the Ultraguard because it is cheap and very light. It wouldn't be needed most likely though.
Old 01-10-2017, 09:41 AM   #28
bredler
Thumbs up
The option for ESC with internal BEC seems to be missing? That's what I run most of my big helis on. (Hobbywing ESC's or Align rebranded version)
Point taken, but that is a BEC as far as the function goes. It for sure is a different setup, but mostly I'm looking to differentiate between power from the flight pack and power from a separate power source, as well as who feels the need to back them up.
Thanks for your input!
RCHN #825
Blade 550x, Blade 360 cfx, Blade 180 cfx
bredler is online now        Reply With Quote
Old 01-10-2017, 10:50 AM   #29
Raptorapture
CHC Benefactor
+1 - basically BEC from main power source plus buffer pack
On your question about need to back up, I feel it's an absolute. One needs to ensure maximum possibility of control and ability to remove power to main blades on demand. Without a backup source for RX, FBL and servos that is not possible. Buffer packs are the simplest way to do that with maximum likelihood of being there in the event of most failures. Largest machine I fly without buffer pack is 450 as in 325mm blades.
Raptorapture is offline        Reply With Quote
Old 01-10-2017, 11:12 AM   #30
kpod
My first 600 (Compass 6hvu) had a 2s rx pack. I loved that because I could safely power up everything but the motor for setup and inspection. The charge lasted for the few flights I would do. It was dirt cheap and weight adding was negligible. I liked this route.
My second 600 (Logo 600sx) I went all out and had a Kontronic 80hv pro on it and used that internal bec. It worked great, had clean and easy wiring, but was expensive.
One day when I build a 700, I'll probably go back to a cheaper opto esc and rx pack or get a new hobbywing with bec. Money will be the deciding factor.
I don't typically run backups.
Kory
Qube for sale
kpod is offline        Reply With Quote
Old 01-10-2017, 11:20 AM   #31
Grumpy_Old_Man
Ok, I voted 'BEC' on that basis!
Old 01-10-2017, 11:24 AM   #32
seefest
Kontronik internal BEC and Optiguard backup on my 700's.
GOBLIN 570 12S JIVE 120, BK CYCLIC, BK TAIL, PYRO 650, CYCLONE, SK540
GOBLIN 700 COMP HELIJIVE 120, RJX CYCLIC, BK TAIL, PYRO 750-500, CYCLONE, SK540
LOGO 600SXJIVE 120, MKS SERVOS, SK540, RT MAINS, CYCLONE TAILS
seefest is offline        Reply With Quote
Old 01-10-2017, 11:27 AM   #33
Grumpy_Old_Man
Maybe yes, maybe no
Markus
The Hobbywing 130A with BEC is (based on published data) about 20g heavier than the Castle edge 120, but that includes the ESC to Rx wiring harness which you would have to add to the Rx pack. So to all intents and purposes you save the full weight of the Rx pack (116g in this case).
If you would notice that in flight is debatable, but it's a non-trivial weight saving.
Old 01-10-2017, 11:45 AM   #34
bredler
Markus
Yeah, that's true. You don't shave 100 lbs off a race car by removing 100 lbs from one thing; more like 1/4 lb from 400 things. You see the same thing with ultralight backpacking. Cutting down a Toothbrush handle, using a 1 oz smaller fuel bottle, using an old gatorade bottle instead of a nalgene, etc can seem like a fool's errand until you make a pile of stuff that you cut out and it's like 2 lb. Similarly, I'm building a 3.4 meter RC sailplane, and glue/epoxy weight can seriously add up if you're not careful...the weight game in aircraft building is a tricky one for sure.
But back to the point of the RX pack weight savings, if you haven't taken care to save weight at lots of different points, then the extra 116g (4 oz) is kind of just pouring gas on the fire. Definitely non-trivial at 1/4 lb.
I am slowly acquiring electronics for an X7, and I'm thinking I will go with a Jeti 135. Unclear as to whether it will be opto or BEC. It's quite a lightweight and powerful piece of kit either way, so the BEC is looking pretty attractive.
RCHN #825
Old 01-10-2017, 12:06 PM   #35
Slyster
I assume "BEC" means built in BEC and not external right?
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 01-10-2017, 12:12 PM   #36
TheBum
I'm not making that assumption. A RX pack is always an external power source, so an external BEC should count too.
HeliFreak Support
DT520Ev2 (VBar), Protos Max Evo 700 (Brain), Protos Max V2 770 (Brain2; under construction)
TheBum is offline        Reply With Quote
Old 01-10-2017, 12:21 PM   #37
bredler
Nah, a BEC is a BEC as far as where the juice is coming from is concerned. Whether you've put it on a board in your ESC or on a board in a separate housing doesn't matter for the poll. If you use internal, and/or want to elaborate on your setup with a post, please do!
RCHN #825
Old 01-10-2017, 12:28 PM   #38
Steve_JR
Would you guys say the likelihood of a bec or main pack failure is higher than the bec being overloaded and frying the electronics?
Working on a non-heli setup and cannot fit an R2 buffer unit. It gets obnoxiously expensive to have both the bec guard and optiguard.
Steve_JR is online now        Reply With Quote
Old 01-10-2017, 12:32 PM   #39
TheBum
Perfect Regulators ProGuard +. It combines the functions of an Ultraguard and BEC Guard and it's only a little more expensive than an Ultraguard. It is BYOB, but batteries in that cell count and capacity are dirt cheap.
HeliFreak Support
Old 01-10-2017, 12:45 PM   #40
Ace Dude
Not only does it get expensive, but you also significantly increase your number of points of failure.
Sure, lots of folks complain about the initial purchase price of Kontronik, but when you add the cost of an external BEC and any other gizmos deemed necessary I'm not sure you're saving anything and now you have additional wiring and significantly more points of failure.
I never thought I'd own a Kontronik either, but after researching the alternatives and considering the total cost of ownership (TCO), wiring simplicity, reliability, quality of the internal governor, and ease of use, it was a no brainer and my Kontronik ESCs have never let me down.
