Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 12-01-2008, 01:52 PM   #21
seatec
Cyclic Servos: S9452
Tail Servo:S9251
Gyro:GY 501
Blades head:SB Radix Blades, 710mm Carbon
Blades tail: Stock
Battery:not decided yet
Engine:OS 91 PD08
Pipe: Hatori SB-18FH
Gov" Stock Align
seatec is offline        Reply With Quote
Old 12-04-2008, 04:55 AM   #22
ncampion
Align Trex 700
Cyclic: ACE 1015 6v
Align Gov
Blades: (CYB 710 standard and V-Blades 690s)
Align 2&1 Regulator
Gyro: GY611
OS SZ-H .91 (with .04 and .08 shims), with Hatori 939 pipe
TT Header
4500 Mah 2s Lipo and extra Align 1900 Mah 2s lipos.
Enya no. 3 (will be trying Enya no. 4 and OS no 8)
Currently running CP 30%
TT header tank
Spectrum 7000 receiver with DX7
Everything else stock
ncampion is offline        Reply With Quote
Old 12-04-2008, 06:36 AM   #23
busterboy
Cyclic Servos: 8915s at 8v
Tail Servo: BLS251
Gyro: Spartan DS760
Blades head: Radix 690mmSB
Blades tail: Align
Battery: ThunderPower 3400mah Lipo
Engine: OS 91HZ
Pipe: Hatori 939
Receiver: AR7100R
Governor: AR7100R Revmax
SwitchGlo
700KSE
700 Black Nitro
570 SAB Goblin
busterboy is offline        Reply With Quote
Old 12-11-2008, 09:47 AM   #24
pilou2
Here is mine:
Cyclic Servos: BLS 253 at 6V and in a near future 6.6V
Tail Servo: BLS251
Gyro: Spartan DS760
Blades tail: Radix 105
Battery: 3700 mAh Lipo + Fromeco Arizona regulator
Engine: OS 91HZ-PS
Pipe: Hatori 938
Receiver: Futaba R5114DPS
Governor: MuliGov Pro + 9551 servo
pilou2 is offline        Reply With Quote
Old 12-12-2008, 05:31 AM   #25
jwilkens
Here is mine:
Cyclic Servos: DS8915 at 6V
Tail Servo: DS8900G
Gyro: JR G770T
Blades head: CY 700 mm
Blades tail: Stock Align
Battery: 3000 mAh Flightpower Lipo + Align 2-in-1
Engine: OS 91SZ-H
Pipe: Hatori SB18
Receiver: Spektrum AR7000
Governor: Align
jwilkens is offline        Reply With Quote
Old 12-19-2008, 05:44 PM   #26
Roy_95
Trex 700N
YS 90SR + Hatori SB946
GY611 + BLS251
Cyclic 3x8915 (Running 6,8V)
Throttle S9254
MultiGov Pro
DSX 9 + AR7100R
SwitchGlo
Radix 690
Funkey Paddle
Radix 105mm Tail
3000mah RX Battery w/ SGP Reactor Regulator
Trex 250, Trex 450 SE V2, Beam E4, Trex 500
Trex 600 NSP, Trex 600 N Pro w/ Kasama Upgrade, Vibe Fifty
Trex 700, Synergy N9, Avant Aurora 90
Roy_95 is offline        Reply With Quote
Old 01-06-2009, 11:01 PM   #27
chosen69
- ALIGN (OS) 91-HP
- Hatori 20SB
- Mavrik 700 G5 pro's
- 4x 8717
- Spartan + JR 8900G
- Multitigov pro
- Spektrum AR7100
- Duralite 7.5 Amps 6V HD regulator
- Mavrik Header tank
- TP 2S2P 4200mah
- etc.
Trex 600EFLpro
Trex 600NSP DFC
Trex 700E DFC
Goblin 700
chosen69 is offline        Reply With Quote
Old 01-09-2009, 01:39 PM   #28
robertckerr
Bob what's your thoughts on using the Futaba 9254 for the throttle on the TREX 700 with:
3x JR8717 CCPM
Solid G Gyro with JR8900G tail servo
Spektrum 7100R reciever
OS 91 HZ-PS Pumped with Hatori SB20
Outrage TXRX 7.4V 5000 mah battery
robertckerr is offline        Reply With Quote
Old 01-11-2009, 10:24 PM   #29
HeliSmith
If you can afford to run a 9254 on throttle do it most will say it is overkill but I would run one there if I could. I will be moving to a 9452 my 3151 is developing slop, big surprise huh..
Updated Power System:
Radix 690 main blades, Radix 4mm Super Stubz, Radix 105mm tail blades
AR7100 + "Rewired" Fromeco Arizona Pin Flag switch.
Lightning Power 5000mah RX pack
8717 @8V, GY611+9256 @5v
YS91SR Long Stroke + Hatori SB19FH
30% Coolpower only from now on, Fuel magnet from now on!
Align governor @ 1900RPM I think might go up or down a little
3151 on throttle for the moment will up this to 9452
13/13 degrees pitch main + 9 cyclic pitch
helism th
HeliSmith is offline        Reply With Quote
Old 01-26-2009, 09:31 PM   #30
psychojon
do you know anything about the align 90 ?
psychojon is offline        Reply With Quote
Old 01-28-2009, 10:18 PM   #31
Phillips942
Planned Setup, Still in the Building Phase
Cyclic Servos: Hitec HS-5965MG's
Tail Servo: JR8900G
Gyro: Spartan DS760
Blades head: 690mm V-Blades
Throttle: HS5965MG (Had extra laying around)
Blades tail: Stock
Battery: Spektrum NiMH 4500mAh 6v
Engine:OS 91HZ
Pipe: Undecided
Gov: Aerospire Multigov Unit
Receiver: AR7100
Onboard glow: Switchglo
M. Phillips US Navy 11 years STRONG
Phillips942 is offline        Reply With Quote
Old 01-30-2009, 09:57 AM   #32
ali_doha
Default Hi
My setup
T-REX 700
91H Engine
GP750+DS620 Head Lock Gyro
ALIGN 90 High Performance Muffler
ALIGN 690D Carbon Fiber Blades
ALIGN DS610 Servo
RCE-G600 Governor
AR7000
ali_doha is offline        Reply With Quote
Old 02-05-2009, 07:47 AM   #33
regiepogi
Here's my setup:
YS 91ST + MP2
Align 2in1 regulator
Duralite 2S1P 2900mah
Align DS620 x4
G-Lock + BLS251
690mm VBlades2
1900 on Idle1
2100 on Idle2
+12 -12 pitch
+-8 on cyclic
30% Tornado
DS721
regiepogi is offline        Reply With Quote
Old 02-05-2009, 08:34 AM   #34
John Cook
Location: Winnebago IL Where the politicians are MORE corrupt-Thanks alot Blago/Burris/Daley etc...
Originally Posted by chosen69 View Post
- ALIGN (OS) 91-HP
- Hatori 20SB
- 4x 8717
- Multitigov pro
- Spektrum AR7100
- TP 2S2P 4200mah
- etc.
I'd recommend the 710 wide cord Mavrikks.
the 700's are the older design
KBDD
MKS Servos
Scorpion Power Systems/Batteries
Spartan RC
John Cook is offline        Reply With Quote
Old 02-15-2009, 03:52 PM   #35
gill4321
heres mine and my signature says the rest
ID:	82391   Click image for larger version
ID:	82392   Click image for larger version
Gill P.
SAB Goblin 700.
SAB Goblin 500.
JR X9303
gill4321 is offline        Reply With Quote
Old 03-05-2009, 01:54 PM   #36
rcnut
Smile
In the build stage,
700N
Align 91 HZ
Outrage muffler (thanks to CoronaL)
AR 9000
Align 610 servos (using stock wheels)
Solid-G w/BLS 251
Align govenor w/S9253
Relion 5200mah w/Sahara reg (will arrive Monday)
Microheli tripple bearing block
Quick UK control link set
Align paddles & tail blades
Radix 710 mains
Canomod - Rossy
Looking forward to flying this monster!
Team Miniature Aircraft
"I love the smell of Nitro/Gas in the morning!"
Citizen 654
rcnut is offline        Reply With Quote
Old 03-11-2009, 11:19 PM   #37
LoveMyTrex
OS 91 HZ
hatori SB-20
spartan 760 with JR8900G
8717HV's
7100r
3500G on throttle
switchglow
outrage RX 3600mah and 5000mah packs.
align 690D blades stock paddles and tails
not flown yet and I don't have my 8717HV's yet but will be getting them tomorrow.
600N 8917HV's spartan 760/8900G OS 55HZ/hatori SAB-55 AR7100r switchglow
700N 8717HV's spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 690 slick V2 V's
90SG 8717HVs spartan 760/8900G OS 91HZ/hatori SB-20 AR7100r switchglow, 710 slick V2 V's
LoveMyTrex is offline        Reply With Quote
Old 03-31-2009, 03:02 AM   #38
cba7824
T-Rex 700 Nitro Pro #1
Engine: YS 91ST (Also have YS 91SR backup)
Muffler: Outrage 90
Cyclic: JR 8717's
Throttle: Align DS620
Tail: JR 8900G
Gyro: Futaba GY611
Governor: Aerospire MultiGov Pro
Main blades: V-Blades 690 TST
Tail blades: Stock Align
Paddles: Stock Align
Receiver: Spektrum AR7100
RX battery: Outrage 5000RX
Transmitter: JR X9303 2.4
T-Rex 700 Nitro Pro #2
Engine: O.S. 91HZ
Muffler: Hatori SB-20
Cyclic: Futaba BLS 253
Throttle: Futaba BLS 451
Tail: Futaba BLS 251
Gyro: Spartan 760
Main blades: Align 690D
Paddles: V-Blade paddles
Glow ignitor: SwitchGlo 8V
RX battery: Thunder Power 2600RX
Charlie (Alaska)
TDR,Pyro30-12,Jive120HV,Mini-Vbar5
Logo600,Xera4025-560,Jive80HV,Vbar5.2Pro
cba7824 is offline        Reply With Quote
Old 03-31-2009, 03:30 PM   #39
LoveMyTrex
all you need to do is move the 8717's over to 700 #2 and it will ROCK!
really, which servos do you like better? 8717's or the 253's
Old 04-06-2009, 09:39 PM   #40
Altec
Thumbs up
Though I'd share my setup as well since so many of you here have help me along the way. (Big shout out to Finless).
700 Kit
ALign 700 Main Baldes
OS 91 HZ w/Outrage Muffler
GY611 w/9256 on Tail
3 JR8717's for Head
DS537 for Throttle
Spektrum AR7100R RX
Carb Smart w/Hitec HS-65HB servo (highly recommend)
5000 Mah RX 2s Lipo
JR9303H 2.4 TX (Awesome radio)
Thanks Guys!!!
Altec is offline        Reply With Quote
