| mCP X Blade Micro CPx Helicopters Information and Help |
New batteries, new motor and lubed everything, new main shaft and gear. Zero pitch at mid stick but still having a hard time doing 3D with out waiting every flip for altitude. When inverted I get faster pumps, but lifting off the ground or even trying to pitch pump it takes forever to get even 10 feet off the ground. But give it negative pitch it drops like a rocket. I've run out of ideas anyone else have this problem? I get even pitch measuring the blades at full positive and full negative. I'm ready to give up and go bl but feel this bird should be performing better than it is.
One thing it might be its all the mh upgrades, swash, blade grips and hub. Is my bird too heavy?
Align 700e, ar7200bx, cc120hv, ds610 Align 550e, 550mm blades, ar7200bx, cc 100hv, ds610, ds650 Align 450 pro v1, zyx, cc 50hv, tarot dfc, ds410, ds520 300x - 130x - Mcpx - Nano Cpx - Msrx - Phoenix v4 - Spektrum Dx7 |
Weighed a fully "blinged" out MH bird and it weighed 50g compared to my stock 47g. Should not be a big deal. The one thing that I've noticed is that you do have to drop the swash connecting rods by two or three turns after installing a MH swashplate in order to regain positive pitch much like the stock setup.
Beating the air into submission... one Blade® at a time! Lynx Heli Innovations Team Pilot SilentDRC.net -The Order of Brushless Witnesses |
#3 | |
#4 | ||
my stock brushed was like 41g but that was with monokote trim on canopy and tail and cat 5 wire on the boom my now converted to BL one is only 38.1 this is w/o batterys
,B450 w.HS65MG,ZYX Tarrot Head FBL, Billowy Batterys ,MCPX BLack dragon oversky 10a, Blade CP pro BL |
#5 |
Yes sir, that is with batteries, KBDD blades, KBDD skids, KBDD tail rotor, MicroHeli swash plate and everything else stock and the stock e-flite batteries too.
#6 |
[QUOTE=Epoweredrc;4015963]what blades are you running, and have you weigh it, would guess it is heavy this is a stock brushed heli?
ya stock brushed motor. Ive tried the stock blades and the kbdd pink blades. Flys the exact same.
#7 | |
Then that is only mine ,my son's and numerious others who have flown both brands enough flights to be able to see the difference. I will give credit to KBDD on a couple of points. THey have the brighest colors and they track the best if the feathing shaft is slightly bent. |
#8 | |
#9 |
Take a look in the travel adjust menu. I don't have a DX7 but there must be arrows indicating stick direction like on a DX6i.
Just in case, Take a look and make sure that you have 75 both ways in the pitch menu. collective full up and full down. 75 below mid stick and 75 above mid stick position. Just maybe it got missed in setup.
Ron Petrolia Ontario CX2,MCX2,MSR,120SR,Rescue Heli,MCPX,MCPX-bl, B450 DX6i Now building a Hirobo shuttle 30 size To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#10 |
I just weighed my mcpx and its 39.7g with all the mh upgrades and extended boom with wire. Is this heavy?
