Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 06-17-2014, 02:37 AM   #1 (permalink)
We seem to be having quite a few issues so how about putting them all in one place? It could make it easier to find information and make a good resource.
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 06-17-2014, 02:41 AM   #2 (permalink)
Default Tail Issues Modifications General Tail Chat
Good idea ! I am a bit dissatisfied with the tail ATM, at neutral position of around 8' of right rudder, the slider is way off centre thus limiting amount of right rudder. I think this May be a factor in occasional tail blowout. I am going to try shortening the slider-grip ball links to give a bit more right rudder and enable tail blade track adjustment.
John
Old 06-17-2014, 03:02 AM   #3 (permalink)
I found 4-6 degrees pretty good at neutral, 8 may be a tad high.
Old 06-17-2014, 03:58 AM   #4 (permalink)
Fair enough, but there does seem a large inequality in movement for the slider, my HC end stops are around 20 different!
John
Old 06-17-2014, 04:30 AM   #5 (permalink)
I found a little trick, the tail hub can slide up and down the tail shaft a bit by loosening the grub screw. This can allow some adjustment of the tail pitch neutral and end points. I don't worry about the numbers so much these days. I fly it and see, more of a practical approach. Less headache and not run into issues....so far
Old 06-17-2014, 07:53 AM   #6 (permalink)
Well its a beautiful day and I thought I'd get a few flights in this afternoon.
Spooled up, hovered, punched the collective and BAMM!! out of control piro,
Got it down with no damage.
The rod must have cracked during transit. Oh well. No harm done. I have spare rods at home. I'll put a brass sleeve over the end this time.
Name:	Image 17.06.2014 13.31.54 0201.jpg
Old 06-17-2014, 12:20 PM   #7 (permalink)
Good save! I think some sort of support to the CF helpful as the fibres in the rod poorly resistant to lateral movement. I might try whipping, like on the old fashioned fishing rods
John
Old 06-17-2014, 12:48 PM   #8 (permalink)
For tail control pushrods I always use the central hobbies inserts and also bond a brass or aluminum tube over the outside at the ends to prevent splitting of the tube.
Another option that looks good but I haven't tried yet is the new Mikado tail control pushrod ends, they bond over the outside of the tube rather than the inside.
Minicopter Diabolo - BD Axon, Kosmik 200, Xnova XTS 4530-480, 14S 4500, BLS255HV/BLS256HV
Bergen Magnum 44 -
BD Axon, Wren MW44 turbine, BLS156HV/BLS256HV
Jeti DC-16
Kiba is offline        Reply With Quote Quick reply to this message
Old 06-17-2014, 04:24 PM   #9 (permalink)
http://www.fblrotors.com/FBLROTORS-T...rod_p_442.html
Try these
Diabolo S #6
Diabolo
TDR
N7
crash at 42 is offline        Reply With Quote Quick reply to this message
Old 06-17-2014, 06:22 PM   #10 (permalink)
Originally Posted by crash at 42 View Post
Those are nice. What size pushrod are they for, and what size is the threads for the rod end?
Bergen Magnum 44 -
Jeti DC-16
Old 06-17-2014, 09:34 PM   #11 (permalink)
The rod size is the same, I didnt measure the thread but will, cant see much of a difference and wont fracture the CF when adjusting
Diabolo S #6
Diabolo
TDR
N7
Old 06-18-2014, 01:31 AM   #12 (permalink)
Very elegant!
Old 06-18-2014, 09:17 PM   #13 (permalink)
I confirmed part number 441 "FBLROTORS Titanium rod ends with links for tail control rod" is for a 4mm carbon rod with a link that has a 3mm thread.
Old 06-19-2014, 12:19 AM   #14 (permalink)
Hmm, tail options? Should that include the new RcTek tri rotor tail assy I am field testing? Or the Kbdd dual slider control I am fitting into my Triabolo?
Old 06-19-2014, 12:31 AM   #15 (permalink)
We should sticky the tail setup posts - e.g. the one Gerd did on the hanging method, plus other useful posts on tension and setup. There are also some good posts on the tail control rod too.
thefrog is offline        Reply With Quote Quick reply to this message
Old 06-19-2014, 12:34 AM   #16 (permalink)
Absolutely
Any modifications from anywhere would be good to see.
Old 06-19-2014, 12:54 AM   #17 (permalink)
Maybe they could be merged into here?
Old 06-19-2014, 01:07 AM   #18 (permalink)
Exactly - I think a lot of that discussion is in the 'what did you do with' thread but there are a couple of other sources.
Old 06-19-2014, 03:36 PM   #19 (permalink)
Here is what I have come up with to strengthen the end of the CF push rod, not too different from the Brass insert from a tail rotor.Its from a connector. I drilled through the top and cut away the extra brass to make a flat surface and this left me with a nice end that covers the cut end of the CF rod as well.
Old 06-19-2014, 05:16 PM   #20 (permalink)
Very neat Satnam
John
