Old 05-03-2012, 10:57 AM   #1 (permalink)
Default 2 crashes with weird heli behavior
Hy guys,
I would like you to check out this photo and tell me what could get better in this beastx installation!! Besides the stock tape that I will change for the 3M one. I had 2 consecutive crashes and I think that was because the heli tried to something that I did not want! I have flown this heli (Trex 500 EFL PRO) about 20 flights with no problem. Than I started to check my tail beastx setup like the stick post of nwmtech and I had to do a lot of piros to check it out! In the first crash I did all the piros and when I was in a hover to land the heli lost control and hit the ground (I thought that could be some short circuit! All the thing were very quickly! Without blades I turned the motor on and checked all the wires and everything was OK. Rebuild the heli and went to the field again! I flew the first pack with a few piros during FFF and everything was OK. The second pack, in the middle of the flight I started to make some piros in a hover and change direction quickly then the heli lost control and hitted the ground! Seemed that she tried to tip over!!! I don´t know!! What could it be!!!!????
Alexandre Najar is offline        Reply With Quote Quick reply to this message
Old 05-04-2012, 03:47 PM   #2 (permalink)
Try the harder pad, they are better when hard mounted. You need just enough to dampen vibrations. IME the 3mm pad allows the unit move enough to give false sensor readings.
PlaneHazza is offline        Reply With Quote Quick reply to this message
Old 05-04-2012, 04:10 PM   #3 (permalink)
probably just your radio set up' everyone and their brother is doiin the same thing. Trims memorized by comp radios@! Also a 30 second check but what are manuals for anyway;s dont read then ignore the rest. 99 percent of all of you having problems obviously have trim stored on your tx. Maybe the next tx will come out with no trim available for dummies
So sorry if I have offended you but this is and alway's been the bottom line and getting so old it is nonsence
scott s is offline        Reply With Quote Quick reply to this message
Old 05-04-2012, 04:17 PM   #4 (permalink)
Change the pad for sure..I can already tell its too soft by looking at the one you have on it..You need the thin/gray color 3M tape..
Team Align
flyinghigh450 is offline        Reply With Quote Quick reply to this message
Old 05-05-2012, 10:29 AM   #5 (permalink)
Thanks guys. It is so nice to have people with much more experience helping us! I have already changed my pad to the 3M gray one! What about my wires? They are not tight and my receiver is installed with some hook and loop tape at the side of the heli. Is it OK!? Another thing that I would like to ask is about the beastx N menu setup "pirouette optimization". I confess that I am a little confused with this. For a Trex 500 EFL Pro with the beastx mounted at the gyro tray I found, reading the manual and holding the heli....bla bla bla, that it shoul be in (reversed) -blue light! Am I correct?!
Old 05-05-2012, 10:37 AM   #6 (permalink)
The point about step N is that whichever way it tilts when you go into that step, moving the heli will have no effect on that tilt, with reference to the rest of the universe, lol. Try this, go into step N and pick up your heli by the head button, and then spin the heli around underneath the button and look at the swash. The swash should appear to be stationary in space, even though the servos are moving all over the place. If it is set incorrectly, then it will wobble around like crazy.
Stable swash, when you spin the heli, is what you need to look for. When you see it like this it will be obvious you have it right.
Cheers
Sutty
Regards, Sutty
Old 05-08-2012, 04:21 PM   #7 (permalink)
Wow your a barrel of laughs with an attitude like that! How do you know he has any trim in the TX? More likely as mentioned above point N being set wrong.
MCPX V2
Tarot 450 pro V2 FBL Zyx gyro
Blade 450X FBL
retired to the black bin bag!!
Flying_Amp is offline        Reply With Quote Quick reply to this message
Old 05-08-2012, 09:10 PM   #8 (permalink)
WOW !
I will have to make a note not to ask you for help. Whatever happened to the "love" and helping each other. If you can't say anything positive why bother replying? Sorry if I have offended you but your reply was really out of place
Have a nice day
Wizzard is offline        Reply With Quote Quick reply to this message
Old 05-09-2012, 07:26 AM   #9 (permalink)
Any luck with your issue by the way? Did you have chance to re-visit piro comp at set-up menu step N? You did ask how do you know how to set this correctly. Hopefully you have been able to verify this step now.
Cheers
Sutty
Regards, Sutty
