Old 01-23-2017, 11:01 AM   #1 (permalink)
Default Main spindle
Anyone got a source for these, preferably in the US? I have looked as of yesterday and results were nil. MSHUSA had some for a minute, but I stalled and missed out.
Next time I order them I am ordering a dozen If anyone gets them in stock.
-Ben
Old 01-23-2017, 11:16 AM   #2 (permalink)
I'll look around when I get some time but at a glance only saw them in stock in Canada.
You just looking for a spares or do you need one now for a rebuild?
If you need one so you can fly just PM me your address and I'll send you one.
Mini Protos 6s stretch/XK K110/Trex 450sport v2 fbl/Rochobby Nemesis NXT/RareBear funfighter620mm
~Problem Child~
learnedthehardway is offline        Reply With Quote Quick reply to this message
Old 01-23-2017, 11:54 AM   #3 (permalink)
I saw the same in CA, but shipping was almost $9 so I didn't order. I was going to order 6 to sort of offset the cost, but just gave up on it.
I need one to fly. I smacked something so hard it popped the thing in half and didn't even leave a scratch on the mains. Damn trees, lol. Not sure if that is now the result of going to Lynx metal grips.
Thanks for the offer. I found one on ebay. The part number crossed, but will see what I get. I'll let you know.
-Ben
Old 01-23-2017, 04:04 PM   #4 (permalink)
Damn trees always jumping in the way..lol
Could be, one crash in grass the Lynx grips appeared to save my spindle but a tree is a different story
Put a new one in mine for no reason when I put a fresh set of dampers in so have a perfectly fine used one you're more than welcome to have free of charge if you want it.
Pretty sure I have enough to send you the used one plus a nice shiny new one too.
Just let me know
~Problem Child~
Old 01-28-2017, 09:09 AM   #5 (permalink)
Just fyi I have 2 part #'s for Mini P spindles. MSH41096 flybarless spindle kit and MSH41002 which is a 2 pack.
Don't have as many as I thought but still have enough to send you 1 NIP spindle if you need one. Thought I had a bunch but 3 of the bags contained tail shafts not spindles. .lol
~Problem Child~
Old 01-28-2017, 11:22 AM   #6 (permalink)
Check that they are the same length - from memory the twin pack was the old fly-barred spindle
Old 01-28-2017, 04:36 PM   #7 (permalink)
That crossed my mind but they appear to be the same length when lined up. Imagine the fb and fbl spindles would be the same anyway...
~Problem Child~
Old 01-28-2017, 04:45 PM   #8 (permalink)
Thanks. I rcvd one in the mail Wed. Haven't had a chance to start working on her yet. Hopefully tomorrow or maybe later tonight. Hopefully they are back in stock soon. I think I bought the last remaining in the United States, lol. I have to search the other part number.
-Ben
Old 01-28-2017, 05:04 PM   #9 (permalink)
Me too cause Mike has me wondering now....lol
Now that I think about the fb hub on my P50 used different dampers than the fbl so the Mini's probably the same way so maybe they do have 2 different spindles for fb/fbl
~Problem Child~
Old 01-28-2017, 05:12 PM   #10 (permalink)
Good call Mike, 2 pack spindles are just a hair shorter than the one labeled as fbl. Looks like they'll work if you use regular washers instead of the slightly thicker spindle bolt washers that come with the spindle
~Problem Child~
Old 01-29-2017, 12:47 AM   #11 (permalink)
Unfortunately that would mess up the geometry - the longer shaft with deeper washers is needed to line up the balls on the rotor grips.
Old 01-29-2017, 06:18 AM   #12 (permalink)
Crap, figured there would probably be some kind of problem trying to use them. Was thinking they'd make the grips too tight against the dampers causing them to bind or something along those lines, linkage alignment hadn't even crossed my mind.
Have you ever tried to make it work? Looks like it would only be about a 1mm difference on each side.
Was going to play around with it cause I have all the parts to build a spare head/main shaft/swash assembly but if you already tried and it was a no go or looked iffy then I won't even bother.
~Problem Child~
Old 01-29-2017, 07:00 AM   #13 (permalink)
You could be the guinea pig...
-Ben
Old 01-29-2017, 07:06 AM   #14 (permalink)
I'll definitely give it a shot if Mikej hasn't already since I have 2 of the damn things NIP...
Should have enough stripped airframes and various bits laying around to be able to Frankenstein something together. Shim here and/or there and I'm pretty sure I can get em to work with the Lynx grips, not so sure about the plastic grips though
~Problem Child~
Old 01-29-2017, 07:33 AM   #15 (permalink)
I haven't tried it. My understanding is that cyclic movements would not be in the correct orientation, i.e. because the main grip servo ball is not completely in the middle of the mainshaft so for instance an elevator flip would not end up straight but each part of the flip would be slightly off straight, a loop would end up being a slight cork-screw
Old 01-29-2017, 07:41 AM   #16 (permalink)
Well, I just ordered up 6 from the Canadian site. Tried to order more, but that was all they had. $8.50 for shipping But hey, desperate times...
My luck they will be back in stock coast to coast tomorrow. Haven't seen OTS mention anything, though.
-Ben
Old 01-29-2017, 07:42 AM   #17 (permalink)
...a loop would end up being a slight cork-screw
Sounds like a way to pull off some cool moves
-Ben
Old 01-29-2017, 08:12 AM   #18 (permalink)
It wouldn't effect phasing, which is what you are talking about. That is based on the swash ball alignment, but it would effect delta. This is used to effect how a blade reacts when the spindle moves in the dampers and can have effects on reaction of the head in gusty wind as an example.
Delta was used more with FB heads to tune responce, the majority of FBL heads use 0 degrees of delta, I.e. Grip ball in line with the mainshaft. I would just try it and see if it causes you any issues, it may not be enough of a change to upset the Heli, and get the correct ones next time.
//Dennis.
soXos: Strike 8.1 - Strike 7.1 Light - Strike 6.1 : Goosky: RS7 - RS4 - S2 - S1
soXos DB7 nightflyer : Jeti DS-16 & DS-12
I am www.soxosaustralia.com.au | soXos helis | 1st-RC Products | EGODRIFT motors | Goosky helis | Spinblades
Thunder Fighter is offline        Reply With Quote Quick reply to this message
Old 01-29-2017, 09:16 AM   #19 (permalink)
Thanks Dennis - you're right I was thinking of Delta
Old 01-29-2017, 10:19 AM   #20 (permalink)
I'll play around with it sometime when I get bored. I don't know if they even sell these ones anymore since they came with one of the used Mini's I got out of the classifieds. Might as well try and get some use out of them.
Since the balls on the Lynx grips sit parallel to the spindle and use a med length ball, I think I can get things to line up by using a shorter ball. Have a few different lengths laying around that are the right diameter.
Thanks for the info guys
~Problem Child~
