Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > ELY.Q - Vision 50
ELY.Q - Vision 50 ELY.Q Vision 50 Helicopter Support
Old 12-25-2008, 09:59 AM   #1 (permalink)
Default Weird Swash movement????
OK,
So, I've completed the build and JC was nice enough to come over and help me understand eCCPM set ups. I've got things set up pretty good, but my linkages weren't all at 90 degrees because I can't see a straight line to save my life. After JC helped getting those set up we worked on looking at any interactions. Without a bubble level I wasn't able to tell for sure, but things look pretty good.
JC was playing with the controls and noticed that the swash plate goes up for negative pitch and down for positive pitch. He thought it was backwards. I looked at the directions again and the pictures posted on ElyQs website and the build looks good. When the swash goes down, pitch increases on the blade grips. The blades have trailing edge control, meaning the grip arms are behind the leading edge.
Does anyone know if this is OK and if there is something that could mess up control? Doesn't this sound weird? On then Bergen with leading edge control the swash goes up and the pitch goes up. The other difference is the ElyQ has the flybar on top, although I wouldn't think that would be the cause.
Let me know what you think,
Lou
Vector 550 Quad/Octo Multirotors
DJI WooKong Multirotor Controllers
Twin Bergen 44 Magnum Turbines - KERO Start FBL
www.circlecityhelis.com
lperagallo is offline        Reply With Quote Quick reply to this message
Old 12-25-2008, 04:11 PM   #2 (permalink)
Some helis are designed that way, the Blade 400 and the Raptor 60/90 are a couple that I know of.
John Barta
Michigan Whirlybirds Heli Club
http://www.michiganwhirlybirds.com
j bomb is offline        Reply With Quote Quick reply to this message
Old 12-25-2008, 06:20 PM   #3 (permalink)
j bomb,
Thanks. I can't find anything I've done wrong from the directions or pictures I've seen. It just looks weird.
Lou
Old 12-29-2008, 11:14 AM   #4 (permalink)
You are correct with the build. When the swash moves up you get negative pitch and vice versa.
Team Align
Marcus Kim is offline        Reply With Quote Quick reply to this message
Old 12-29-2008, 09:57 PM   #5 (permalink)
Marcus,
Thanks. Did you notice that the heli is tail heavy with a standard build?
Also, I ended up making the distance on the eccpm servo arms 16.5MM instead of 13.5MM as indicated in teh manual so as to avoid binding at full negative collective and full elevator. Do you think this is OK.
What are your pitch ranges for collective, elevator and aileron?
Thanks,
Lou
Old 12-31-2008, 11:09 AM   #6 (permalink)
JC
Yea since I've only looked at a "Raptor" from a distance, I didn't know some helis were set-up this way. Pitch was correct, but... well you know the rest of the story.
It flies so all is good.
Jeff
Where are we going and why am I in this handbasket?
JC is offline        Reply With Quote Quick reply to this message
Old 06-07-2009, 10:56 AM   #7 (permalink)
Default please help
just bulding a elyq and found the swash backwards to normal, also does the swash tilt left for left turn and visa versa or is this backwards
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
rapidgaz is offline        Reply With Quote Quick reply to this message
Old 06-07-2009, 04:18 PM   #8 (permalink)
JC
That also all depends on what's considered normal. On the Vision and the Raptor it would be considered normal.
Swash tilt right, left, forward, and backwards are all the same as normal... and not backwards.
Jeff
Old 06-11-2009, 10:22 AM   #9 (permalink)
ok cheers. are there any weird things with this heli
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
Old 06-11-2009, 10:50 AM   #10 (permalink)
The only weird thing about this Heli is how well it flies considering its price
Lou
Old 06-16-2009, 07:24 AM   #11 (permalink)
cheers will test it soon. are people using cyclocks on these to help
Trex 700 LE
Trex 600 LE FBL
Trex 550E FBL
Trex 250SE/MCPX
