Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Like Tree2Likes
  • 1 Post By Alexatu
  • 1 Post By Luvmyhelis
Old 03-18-2017, 04:54 PM   #1 (permalink)
Default Goblin 700 C motor shaft length
Hi guys
I just bought a Gob 700 Comp kit which I am very excited about!!
I want to use the electronics out of my previous 700 which was a Blade 700 X. The motor is an Eflite Heli 700 520KV. The shaft length from the C clip to the end is about 37mm.
Will this work?
Any info would be greatly appreciated!
Cheers
Goblin 700 Competition, Raw 580, DX9 Black Edition
"I never make mistakes, I thought I did once but I was mistaken"
Chef is offline        Reply With Quote Quick reply to this message
Old 03-19-2017, 08:46 AM   #2 (permalink)
I got it!
It will work.
I looked everywhere but the SAB manual haha should have looked there first. I will just need to cut 3mm off the shaft and grind a flat spot for the set screw.
Cheers
Old 03-19-2017, 06:30 PM   #3 (permalink)
Cut the shaft, easy job, but be sure you wrap around your motor with some tape, you don't want the steel dust resulting from the cut to enter inside the motor and attach to the magnets.
wctest likes this.
Alexatu is offline        Reply With Quote Quick reply to this message
Old 03-20-2017, 06:51 AM   #4 (permalink)
Good point.
Thanks for the advice.
I think I will wrap the motor with plastic wrap.
Old 03-20-2017, 07:00 AM   #5 (permalink)
The extra 3mm wont do any harm, it means the shaft sticks down into the battery compartment. This would be a problem if it were considerably longer than required, but for 3mm not really an issue.
Old 03-22-2017, 10:30 AM   #6 (permalink)
It would be better if you use a dremel or anything else to cut the 3mm otherwise if sometime your battery strap breaks or loosens by any means it wont damage the battery especially when you are not running the battery upper plate
Team Pilot SAB Heli Division.
Team Pilot Scorpion Power Systems.
Team Pilot BK Servos.
Team Pilot KDlipo Batteries.
Helimaster1 is offline        Reply With Quote Quick reply to this message
Old 03-23-2017, 06:25 PM   #7 (permalink)
Use a plastic zip lock, punch the shaft through the plastic and seal up the rest of the motor when cutting the shaft. That boys is the ticket.
wctest likes this.
Old 03-23-2017, 07:54 PM   #8 (permalink)
All good advice guys thanks!
I think I will cut the shaft. It is not difficult to do so and I like precision.
The kit showed up and I am soooo excited for this build!
Cheers
Old 03-23-2017, 07:56 PM   #9 (permalink)
Sacrificial Zip Lock for Sure🚁🚁
