Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 05-09-2014, 08:58 PM   #1 (permalink)
Default Between engine and muffler
What should be between the engine and the muffler? A gasket or some type of sealant? Mine just just metal to metal and wonder if it is affecting my low flight times. I have a os37 and hatori pipe
DanFL is offline        Reply With Quote Quick reply to this message
Old 05-10-2014, 08:12 AM   #2 (permalink)
You can use a gasket or some epoxy just a thin layer. I have some gasket sealant on mine.
Sent from my XT1052 using Tapatalk
Synergy N5c,OS55HZr, Opti fuel, Msh Brain
Gaui X3, sk720, gensace power
Lynx team pilot
pugdavey is offline        Reply With Quote Quick reply to this message
Old 05-10-2014, 08:33 AM   #3 (permalink)
I haven't seen a gasket anywhere for it, any suggestions on where to find one
Old 05-10-2014, 08:54 AM   #4 (permalink)
I use a thin film of black rtv. Permatex makes it and its available at any local auto parts store. I just put a dab on my finger and spread it very thin on the pipe.
-Phillip Johnson, AMA #954735
LegndarySaiyan is offline        Reply With Quote Quick reply to this message
Old 05-10-2014, 08:55 AM   #5 (permalink)
A lot people, myself included, use a high temp silicone gasket. It comes in a tube that you apply yourself. When I apply it I put on a very thin layer. It doesn't take much and you want to avoid build up as it could break loose and foul your glow plug.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar
Voodoo 400 SK540
ChadL is offline        Reply With Quote Quick reply to this message
Old 05-10-2014, 11:11 AM   #6 (permalink)
Use nothing if a piece of what ever you use get in and fowl your plug then you know the rest, that happened to me about 15 years ago.
Blade3d is offline        Reply With Quote Quick reply to this message
Old 05-11-2014, 06:57 AM   #7 (permalink)
On the os37 and GAUI pipe, I don't use gasket material. I use a lock washer and just go out and fly and tighten as soon as I land (while it's hot) after 3-4 flights it'll stay tight. Been doing this for a year without an issue. Occasionally I'll check the bolts and they will take a quarter turn or so. You could also put some RTV or green threadlock in the threads.
There would be nothing wrong with using some high temp sealant. Just use it sparingly for the reasons listed above.
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote Quick reply to this message
Old 08-18-2015, 10:40 AM   #8 (permalink)
Default Gasket
I use gasket making material from a auto part store.it comes in a roll and just make your own with a razor blade..
hawk3011 is offline        Reply With Quote Quick reply to this message
Old 08-19-2015, 04:57 PM   #9 (permalink)
I use a very thin layer of regular JB weld. And let it rest/cure for a day
And after the holes in the exhaust pipe get stripped out, I get a set of the hatori nuts that sit into the aluminum that are used on the larger pipes,
AMAIN Heli Team
u8at711 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 06:15 AM   #10 (permalink)
I used to use Araldite (Epoxy resin) but now I just use automotive high-temp gasket sealant. Much easier to wipe off and never had a dodgy joint since.
Mike
Goblin 770, Goblin Nitro, Goblin 420 Many come and gone but all V-bar'ed!
hydev is offline        Reply With Quote Quick reply to this message
