Go Back   HeliFreak > R/C Helicopter Support > Henseleit
Henseleit Henseleit Helicopters
Old 04-23-2016, 10:24 AM   #21 (permalink)
I use Optipower Ultra 4400 7S!
Great batteries!
TDR-maniac is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 10:36 AM   #22 (permalink)
Originally Posted by aterren View Post
Please note the new packs from TP will be split packs (i.e. A 7 cell pack will have a connector). I requested a photo from TP late last night. From some research this morning, it seems this is due to the new 100 WH limit for air shipping. A 7 cell 4400mAH pack is 114 WH so it must be sent as 2 packs.
Does anyone know if this has come up in the German TDR II forums?
TP has been doing this for long time, It is 1 pack with very short "Series" connector in front of pack. I tape it to front of batt with packaging tape . it's as if inside shrink wrap. No need to ever disconnect. Single charge /bal. lead on newer style packs. Overall with jump lead taped, Pack length is 170mm
Rick,
Team pilot ,
EGODRIFT, KST, Helidirect, Lynx/Oxy
crickr1 is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 12:23 PM   #23 (permalink)
Per the manual, that is 10mm too long. Have you tried fitting them into the TDR II?
aterren is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 01:48 PM   #24 (permalink)
10 mm is definitely too long
The criterium is a combination of length AND heigth AND brand/type of ESC.
Regards,
Belgo
belgoheli is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 03:19 PM   #25 (permalink)
OPTIPOWER ULTRA
5000 7S 50C Size 160mm * 60mm * 45mm. Weight 950g.
this is the max that fit in
2 x TDRII, 3 x TDR's, 2 X Logo's
OptiPower www.optipower.ch
Team pilot: Optipower, Bavarian Demon, Kontronik , Xblades, DryFluid
Paulice is offline        Reply With Quote Quick reply to this message
Old 04-23-2016, 06:22 PM   #26 (permalink)
Old 04-24-2016, 10:48 AM   #27 (permalink)
Originally Posted by Steve_JR View Post
Progressive RC has them now. He discontinued his Spyder brand of batteries.
They have no 7S batteries
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
Old 04-24-2016, 11:17 AM   #28 (permalink)
That is a generous measure, I did test fit on tray. The series lead can be moved toward top of pack so it clears front of tray
Rick,
Team pilot ,
Old 04-24-2016, 06:20 PM   #29 (permalink)
Thanks for the information.
Old 04-29-2016, 01:54 PM   #30 (permalink)
Anyone consider these
Rovolectrix
The blend 435 7s 5000 dimensions
Weight: 870g
- Dimensions: 58T * 49W * 155L mm
- Balance Plug: JST-XH
- Discharge Plug: You choose
Diabolo Black Edition/Triabolo/Diabolo 600/Logo 700
SMANN55 is offline        Reply With Quote Quick reply to this message
Old 04-29-2016, 05:22 PM   #31 (permalink)
Actual dimensions are, 155/54/45.
And 806 gr. This is the Magna 70c
The lightening 55c are a slight bit smaller at 50mm instead of 54
Rick,
Team pilot ,
Old 05-07-2016, 09:41 PM   #32 (permalink)
Hey guys,
For those of you looking for OptiPower 4400 7S packs. Experience RC finally got some in stock. I just ordered 4. Their supplies are limited and they're running a 10 percent off Mother's Day sale:
http://www.experiencerc.com/store/op...0-p-16904.html
Mike Padron is offline        Reply With Quote Quick reply to this message
Old 09-07-2016, 10:50 PM   #33 (permalink)
Updating an old thread. I received six pulse 4500mAh 7s 45c today for my Goblin BT and wanted to see if they will fit in the TDR2. I've been using optipower 4400mAh and wanted to buy lighter packs. As you can see from the pictures the pulse fits fine in the tray and I don't have to force the canopy to close.
The optipower are 835 to 840gm while the pulse 750gm.
http://www.helidirect.com/batteries/...25-9v-45c.html
ID:	670525   Click image for larger version
ID:	670526   Click image for larger version
ID:	670527   Click image for larger version
ID:	670528   Click image for larger version
ID:	670530   Click image for larger version
ID:	670531   Click image for larger version
ID:	670532   Click image for larger version
ID:	670533   Click image for larger version
ID:	670535   Click image for larger version
firemedic295 is online now        Reply With Quote Quick reply to this message
Old 09-07-2016, 11:38 PM   #34 (permalink)
How did your CG turn out?
Old 09-12-2016, 01:04 PM   #35 (permalink)
Pulse 4500MAh 7s fit perfect. I just received mine. Installed connectors and they're in place. Don't bother canopy at all.
otavon is offline        Reply With Quote Quick reply to this message
Old 09-12-2016, 02:35 PM   #36 (permalink)
They may be a little light for CG. You may have add a bit of weight to the front to get good balance.
Mark
Old 09-13-2016, 06:20 PM   #37 (permalink)
The Pulse 4500 7s fit perfectly.
Old 09-14-2016, 05:36 AM   #38 (permalink)
The batteries can fit perfectly and still leave the TDR2 tail heavy. You still might need a bit of weight at the nose of your heli to get it to balance since you can't shift the batteries for and aft like you can on the original TDR.
Mark
Old 09-14-2016, 02:54 PM   #39 (permalink)
Yep. I believe I need around 3 ozs for good balance.
