JR and Spektrum Radios and Electronics JR and Spektrum Radios, Gyros, Servos, Etc. |
03-03-2008, 07:17 PM | #81 (permalink) |
Nope
Never heard of flight log, Unless........ You are talking about the Flight log for the 9**** range of JR/Spectrum RX's that let you know about fades on each receiver/satellite RX?
Alfred Radios: JR DSX9, Mikado VControl Helies: 2xTRex450, TT30, TT50SE, RJX50, X-Cell60, Fury Expert, Stratus, Kasama ECO (under construction), Goblin 770 |
05-20-2008, 07:27 AM | #82 (permalink) |
How do I copy one model to another, I cannot find this anywhere
SPEkTRUM DX8 TREX600NSP VStabi V5.3 / 55HZ TREX700N DFC/3Gx/ 105 HZ-R |
05-20-2008, 08:35 AM | #83 (permalink) |
before turning on the radio, hold down the function button ( top left) then turn on radio, this will take you to the same screen that you select which model you are going to fly. in this screen you can copy models.
05-20-2008, 09:18 AM | #84 (permalink) |
Regarding the flightlog, Spectrum sells a logger that connects to the receiver and logs your rx power, misses etc.
The Eagletree logger is also capable of logging your rx. You will need to buy the correct cable that connects the rx to the eagletree. |
05-20-2008, 01:00 PM | #85 (permalink) |
thanks, that was easy
02-26-2009, 08:37 AM | #86 (permalink) |
Hi People..
Does anyone know if the JRP A310 Data Transfer cable can also be used as sim/joystick cable, or is it data transfer only? Need a new USB sim cable, but would prefer a solution that lets me map all 9 channels (or at least six) in X9303, instead of the four channels supported by most standard TX-usb dongles.... Would be nice if the A310 cable could do both, and definately make a stronger argument for paying 50 bucks for a usb dongle.... Othervise IŽd like to see suggestion for USB cables for JR that support at least 6 channels for sim or joystick mapping. Thanks in advance Jussi |
