Old 09-21-2013, 10:53 AM   #1 (permalink)
Default Best esc/motor combo?
Hey guys like the title states what's the best esc motor combo for the 450x? Looking for reliability and power.
Thanks again.
Mcpx, mcpx BL, 450X and 3D, Trex 250, Nano Cpx BL, 350QX, 230S and 180CFx
lenix38 is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 11:41 AM   #2 (permalink)
The Airetic
CC Edge 50 Lite/Eflite H450 or Scorpion 2221-8
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 12:05 PM   #3 (permalink)
+1 on the Eflite H450. Loads of power/torque. I'm using the stock ESC and have had zero problems with it.
taildragon is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 12:36 PM   #4 (permalink)
Are Savoxx motors any good on the 450x?
Old 09-21-2013, 06:44 PM   #5 (permalink)
motor Scorpion 2221-8
ESC: Scorpion 45
I have the Scorpion combo in 1 of my heli's and a Viper 450 motor with YEP in the other. Best to me is the Scorpion however the lower costing Viper & YEP performs quite well.
Gaui X3, Warp 360, Atom 500, 7HV, SK720BE's, Scorpion's, DX8
Vladconnery is offline        Reply With Quote Quick reply to this message
Old 09-21-2013, 07:18 PM   #6 (permalink)
Just a word of caution on the YEP 45A - mine won't recognize my batteries as 3S (it thinks they are 4S) unless I undercharge them (4.18V/cell).
MCPX BL, 130X, 450X, Nano QX, ProtoX
Spektrum DX7S
spiff72 is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 04:55 AM   #7 (permalink)
Maybe check your setup via the progam card. Sounds like you have selected life instead of lipo.
Cheers,
TomC
Blade nQX,mCPX-BL,450x,500x Bell 222(bd3sx),550x(bd3sx)
TT X50E, 10s, bd3sx
Ion-x, Actro 32-3, SS, 10:1, PJazz esc, 10s
Now also a FPV addict; Quads and Planes (soon to try heli's!)
TomC is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 06:04 AM   #8 (permalink)
You asked for the best so...
Scorpion 2221-2010
CC Ice Lite 50/Edge
MKS DS92A+/DS95i combo + SBEC (someone threw in servos - these are the best)
Rock solid and very powerful. You won't get sick of your 450 anytime soon!
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional
FailureToFly is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 07:04 AM   #9 (permalink)
Just got a used 450x with scorpion motor been trying to program the esc following the instruction and using another rx. Battery without any success. Would somebody help me
setup throtle of ESC
pasantia is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 07:06 AM   #10 (permalink)
Scorpion 2221-2010
CC Ice Lite 50/Edge
+1 on the servos
I am only using the D95i tail servo but it is definitely an excellent servo the best of the best.
Old 09-22-2013, 07:42 AM   #11 (permalink)
Can I use the stock pinion from eflite 440? What pinion to get for h450?
torch8 is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 08:55 AM   #12 (permalink)
I forget who came up with this list, but here's your pinions:
EFLM60452 Pinion Gear, 10T 0.5 Module 1/8”mm ID x 12mm L
EFLM60453 Pinion Gear, 11T 0.5 Module 1/8”mm ID x 12mm L
EFLM60454 Pinion Gear, 12T 0.5 Module 1/8”mm ID x 12mm L
EFLM60455 Pinion Gear, 13T 0.5 Module 1/8”mm ID x 12mm L
EFLM60456 Pinion Gear, 14T 0.5 Module 1/8”mm ID x 12mm L
EFLM60457 Pinion Gear, 15T 0.5 Module 1/8”mm ID x 12mm L
mCPx BL2, Blade 450x, KDS Innova 550 v2, Kraken 700
Syko is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 09:04 AM   #13 (permalink)
I use 12t straight gears.
vronny is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 09:25 AM   #14 (permalink)
What ESC are you using?
Old 09-22-2013, 09:27 AM   #15 (permalink)
YGE+Scorp=ftw
YEP+Scorp=ummm... ftw ... mostly
I don't run anything else tbh.
spykez is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 09:32 AM   #16 (permalink)
The Airetic
Scorpion 2221-2010
CC Ice Lite 50/Edge
+1 on this setup, mine is the same except I use the H450 motor. I don't see myself needing anything different on it, probably ever.
Eflite H450/14t pinion
Lynx Slant gear
CC Edge Lite 50
MKS DS92A+/DS95i combo + Gyphon Polaris 10A BEC
Old 09-23-2013, 10:22 AM   #17 (permalink)
Just want to make sure I am getting right part number for Eflite 450 motor and 12T pinion.
Elfte 450 Outrunner Motor 3600kv part number is EFLM60450A
Old 09-23-2013, 10:26 AM   #18 (permalink)
EFLM60454 Pinion Gear coming up as 1/2 ID instead of 1/8 ID?
Old 09-23-2013, 10:36 AM   #19 (permalink)
The Airetic
That is the correct motor. I can't help with the pinions, I run a lynx slant. FWIW, I think it is worth every penny of the additional $25 or so to get the lynx slant main gear and pinion while you do this upgrade. It will blow your mind how much more smooth and how much better the heli sounds. Not to mention how much more durable they are. Oh and with zero wobble like the stockers. It is just a WAY better part than the stocker. Now is the time. Pull the trigger! Only buy pinions once!
Gear:
http://www.amainhobbies.com/product_...Main-Gear-136T
Pinion to go with the H450:
http://www.amainhobbies.com/product_...de-300-X-450-X
Old 09-23-2013, 12:03 PM   #20 (permalink)
I going to stick to regular pinion as I only fly my 450 on the weekends and wish to save extra $ for spare parts. Can anyone share information on the pinion they used on Eflite H450? My 450 is grounded until new motor/pinion.
