Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 630/700/770
SAB Goblin 630/700/770 SAB Heli Division 630/700/770 - Goblin Helicopters Factory Support
Old 06-19-2015, 10:42 PM   #1 (permalink)
Cool So who will get KSE 700 - Please share your power set up
Let me start this thread with my set up :
ESC : Kosmik 160
Motor: Scor 4525-520KV
Servo : BK BLS 8002 for cyclic and 8005 for tail
FBL : Spartan VX1E
Pulse 6S-5000mAh-35C x 2
Target HS : 1950 at 85% flat throttle with 20T motor pulley,13 pitch!
Pls share yours!
huanbuihd is offline        Reply With Quote Quick reply to this message
Old 06-19-2015, 10:55 PM   #2 (permalink)
Woohoooooo!!!
ESC: Kosmik 200
Motor: Pyro Competition 800-48
Servo: Mks x8 HBL850 cyclic HBL880 tail
FBL: Skookum 540
Target HS 2050 at 80-85% with 22t Pinion
This is gonna be hardcoreeee!!!
SAB Factory Team -Team MKS - Team Jeti
Team Optipower - Team Canomod
ugoferri is offline        Reply With Quote Quick reply to this message
Old 06-20-2015, 08:54 AM   #3 (permalink)
Kosmik 160
Xnova xts 4530-480kv
Bk brushless
Vbar neo
Thunder power 4400 55c 7s x 2
My target hs is 1950ish with 19t pulley
Specter 700 x 2--Diabolo UL--Compass 6hvu--Logo 600--oxy5+, oxy5, Oxy3, oxy2, SAB Mini Comet
Cajun Aircraft
B.Ewing is offline        Reply With Quote Quick reply to this message
Old 06-20-2015, 11:55 AM   #4 (permalink)
Flight Style: (Sport / 3D)
FBL System: bavarianDEMON BD3sx
Motor: Pyro 750-56c
Pinion: 20T
Target Headspeed(s): HS 1900-2150
ESC: Kosmik 160
Governor: Kosmik 160
BEC: Kosmik 160 / 7.4V
RX: Spektrum AR8000 + SAT dsmx
Cyclic Servos: Torq 9180
Tail Servo: Torq 9188
Main Blades: ZEAL ENERGY 3-Blade Carbon Fiber Main Blades 690mm (Neon Orange)
Tail Blades: ZEAL 3-Blade Carbon Fiber Tail Blades 115mm (Neon Orange)
Lipos: Pulse 45C 6S 4500 mAh 12S
Upgrade´s / Mod´s: Spaniard - FULL CARBON (XLC), LynX - ULTRA MAIN GEAR SET, SHS Canopy mount, KDE Performance Tail Control
........................20T
Throttle 60%: 1545
Throttle 65%: 1674
Throttle 70%: 1802
Throttle 75%: 1931
Throttle 80%: 2060
Throttle 85%: 2189
Throttle 90%: 2318
Diabolo 550 / Diabolo 700BE /Triabolo 700 / Srimok 90N
Goblin-700/700C/KSE/BlackNitro/380/Logo700/Trex600NSP
Jeti DS-14 Edition
Grittner is offline        Reply With Quote Quick reply to this message
Old 06-20-2015, 12:44 PM   #5 (permalink)
Mine will have.....
Scorpion HKIII 4525 520 kv
19 tooth motor pulley
Castle 160 hv esc with fan
Hercules super bec pro
Micro BeastX
BK hv 8001 on cyclics
BK hv 8002 on tail
Pulse 5500mah 45c 12s stick
Being a carbon machine....
Spektrum AR 9310 carbon fuse receiver
2 x 9646 carbon fuse sats
DX 18 tx
Upgrades.....
Booya canopy mounts
Lynx ultra main gear
Sab Urukay upper esc mount
Flight style...
sport / mild 3d
FAI
Scale
High speed
Velos 880/Sab Urukay, KSE, Carbon Speed/Mikado Uvular/RCA Blackshark/Chaos 500 Evo, 550, 600, 700/Trex 500, 600, 600 Pro, 700/Roban 470 Cobra, 700 Apache, Cobra, 429, Jayhawk, 800 Airwolf/TFM 800 Blue Thunder, Seahawk, Jayhawk/ DX8 DX18QQ
treotraveler is offline        Reply With Quote Quick reply to this message
Old 06-20-2015, 02:33 PM   #6 (permalink)
Order canceled!
Goblin 700C Red Carbon, Kosmik 200 Cool, Pyro 800-48, MKS X8 HBL 950/980, Spirit-Pro, Jlog2.6, GPS-Logger2
Jeti DS-16 Red Carbon + REX7
buell47 is offline        Reply With Quote Quick reply to this message
Old 06-21-2015, 12:47 AM   #7 (permalink)
ESC : Kosmik 160 w/Bec @ 8V
Motor : Scorpion 4530-540LE & 18T
Servo : MKS X8 380 & 880
FBL : MSH Brain
Batteries : Pulse 6s 5000 45c (x2) 12s
Targer HS : 1950 +/- 13.0* Pitch
Kraken700/Raw700/Kraken580
REDLS2 is offline        Reply With Quote Quick reply to this message
Old 06-25-2015, 09:39 AM   #8 (permalink)
Kit arrived on Monday hopefully will be built for the weekend...
ESC : Scorpion Commander V 160A
Motor: KDE 700XF - 535KV
Servo : BK BLS 8002 cyclic and MKS 880 tail
FBL : Bavarian Demon 3X
Batteries : Optipower 5000MAH 6s x2
Targer HS : c1900 at with 18T motor pulley,12.5 pitch....
john-yates is offline        Reply With Quote Quick reply to this message
Old 07-01-2015, 10:33 PM   #9 (permalink)
Originally Posted by buell47 View Post
Order canceled!
Why?????
Old 07-01-2015, 11:10 PM   #10 (permalink)
The nice 700 size blade sound is gone.
I don't like it quiet and I don't like Formel1 race car sound with high HS :-(
I purchased now the Goblin 700 Competition Yellow Carbon Edition :-)
Old 07-02-2015, 03:01 AM   #11 (permalink)
ah ok!!!
Old 07-02-2015, 12:30 PM   #12 (permalink)
Buy an additional HPS2 head setup and HAVE BOTH !
Old 07-02-2015, 09:00 PM   #13 (permalink)
Seems best idea!
Old 07-02-2015, 10:37 PM   #14 (permalink)
Absolutely :-D
This was my order, but cancelled.
Some HPS2 parts and blades was also not available at the moment.
If some else have the same idea, here is what you need for the best deal and Heli :-D
1 x SG709 SAB GOBLIN 700 Comp. 3-Blatt - KYLE STACY Edition
1 x H0428-K SAB HPS2 2 Blatt Rotorkopf - GOBLIN 630 / 700 / 770 / Speed / Urukay
1 x HC116-S Spezialinbusschraube M5x35mm (2 Stück)
1 x BL690-3D-Y SAB Blackline 690 3D CFK Hauptrotorblätter - GELB
1 x H0324-S Competition Heckrotor Set mit Dämpfung - Goblin 630 / 700 / 770
1 x H0408-S Präzisions Heckschiebehülse (Set) - Goblin 630 / 700 / 770 / Competition / Speed / Urukay
1 x HC079-S Schaftschraube Inbuss M3x18 (2 Stück) - Goblin 630 / 700 Comp.
1 x BY5115 SAB 115mm CFK Heckrotorblätter Gelb
1 x KO-4816 Kontronik Kosmik 160 HV
1 x KON-9311 KONTRONIK ProgUNIT
1 x KO-27514 Kontronik Pyro 800-48
3 x BK BLS-8002 HV Ultra Speed Taumelscheibenservo
1 x BK BLS-8005 HV Ultra Speed Heckservo
Old 07-02-2015, 11:30 PM   #15 (permalink)
where was your order placed at?
For SAB stuffs,you can order directly from : sabitaly.it
For Kontronik and BK servos stuffs,i think HD has them : helidirect.com
Or maybe you can go direct to : bkservo.com
Old 07-02-2015, 11:36 PM   #16 (permalink)
CC Edge 160A HV ESC, CC BEC Pro, Ikon w/2 dsmxdsmx sats, KDE 700XF G3 505kv, BK 8002 cyclics andand 8005 tail. About 75%e complete on the build. Ran out of connectors so won't be finishing or flying until next week.
pvolcko is offline        Reply With Quote Quick reply to this message
Old 07-03-2015, 12:28 AM   #17 (permalink)
I had ordered all parts together by my small local dealer here in Germany.
Now I'm happy with 2-blade 700C Y/C Carbon, Kosmic 160, Pyro 800-48, MKS 950/980, Spirit
Old 07-03-2015, 09:05 AM   #18 (permalink)
Way don't you try the MKS 599 they look amazing and the stats are crazy...
Jeti DS-14 Edition
Old 07-03-2015, 12:50 PM   #19 (permalink)
That's right, really amazing.
I purchased all together in a Combo and I hadn't the choice.
If I had...yes,I would buy the 599 :-)
Old 07-10-2015, 04:09 PM   #20 (permalink)
Still torn on motor choice..do not want a Scorpion at all...I have a KDE 535kv but that is too high...thinking maybe a 505, but then the canopy will need to be cut?!
raptorz499 is offline        Reply With Quote Quick reply to this message
