Old 12-07-2014, 03:25 PM   #1 (permalink)
Default DX7S switch to mix ?
I had hoped I could easily assign a switch to create a simple mix to boost the throttle for the effect of a 2nd idle-up but I'm finding it not as straightforward or flexible as I had hoped.
I have at the moment acheived what I wanted but at the expense of the aux-2 channel which is now effectively un-usuable for anything else.
On some helis this won't be a problem but with some I am using all the channels.
Soooooo, why the heck can we not create a mix that simply allows a switch to add or subtract to a channel (in this case throttle) without having to first assign a channel to the switch and then select that channel in the mix, if you see what I'm saying.
HD Cell 750, RJX Vector, TDR, TDSF, Kasama Dune and Faifa, Minicopter Triabolo 700, Beam Avantgarde, JR E8 leggero, Suzi Laos, Shape 9, Shape S8, Rave 450, TRex 500, Raptor E700, Compass Warp, Steam 700, Spirit, Spartan, Jeti.
trillian is online now        Reply With Quote Quick reply to this message
Old 12-07-2014, 05:44 PM   #2 (permalink)
Mix Thr>Thr. No reason to use a ghost channel.
Too many helis & Too many planks
Lots of DX radios & A couple Futaba 72mhz radios
AMA member & Full scale plank driver
HELIFREAK !!!
aerocal is offline        Reply With Quote Quick reply to this message
Old 12-07-2014, 06:48 PM   #3 (permalink)
Thanks for your reply.
That would be nice but I sure can't figure out how to do it. In the switch select menu the only option it gives me for ANY switch is aux2 and when I go to Mixes I do not have 'mix-thr' available as an option.
So if this is possible it must be some other setting required that is very well hidden :-(
Old 12-07-2014, 07:29 PM   #4 (permalink)
Ok. I kind of wasnt thinking back to DX7s and 8. Been awhile since I used it. When setting up a Free/Programmable Mix on the 7s and 8 the only switch options you have are FModes and Mix switch. In Heli mode the Mix switch is the top-left rear switch. The same one that would be Gear in Acro mode.
Setup a Mix of Thr<Thr and in the row of Boxes at the bottom of the menu make the box with M black. Add % in the upper Rate selection.
Just remember that this boost in Thr will apply in all FModes except Hold.
HELIFREAK !!!
Old 12-07-2014, 07:49 PM   #5 (permalink)
Yep, that works! :-) It's ideal really because of the location of the gear/mix switch.
Many thanks!
