2.4G Spektrum Radios Spektrum 2.4 Gigahertz Radios and Technology |
11-28-2007, 11:32 PM | #1 (permalink) |
Quad bearing upgrade for the DX7 gimbals by G-Force
For some time now the gimbals on my DX7 seem worn out and I have noticed some play. So I opened up the radio to check the tension springs. To my discovery, each gimbal only had a single ball bearing and a bronze bushing supporting it.
I have since replace all four bronze bushings with ball bearings. The radio now has quad bearings for each stick, two ball bearings for each axis. It took me at least half an hour for each gimbal to be taken apart and reassembled. If you decide to do this, work very slow and carefully. There are a lot of wires to be aware of and don’t lose any screws or springs during the process. All I can say is; it’s amazing how the sticks on the DX7 now feel more precise and smoother than it was new. Garf Last edited by G-Force Heli; 11-29-2007 at 12:51 AM.. |
11-28-2007, 11:54 PM | #2 (permalink) |
Nice, may have to try this someday. Got a bearing size for us? (OD x ID x Width)
Thanks for the info, -Fog
This heli stuff is a pretty deep Rabbit hole, you just have to decide how deep you are willing to go... |
11-29-2007, 11:42 AM | #3 (permalink) |
Bearing part numbers would be nice
-Kevin No helicopters were harmed in the creation of this post. AMA CD # 7309, Turbine Waiver# RW 890 Click Here For Bergen Intrepid Turbine Build Videos |
11-29-2007, 11:52 AM | #4 (permalink) |
Curious as to how long you had been using the TX for when the slop started to develop?
11-30-2007, 04:01 PM | #6 (permalink) |
Bearings/
I guess I'm going to have to break out the Micrometer tonight and work on that.
I have dang near ever size bearing out there with as many crashes as I've had in my first 5 months of flight. I'm sure I can get something to work out. I had a bad orientation problem last night,, But I guess that's good,, 30 flights and one Unplanned landing. :o It was kinda dark out. Heli was about 100 feet away I though it was coming down Head first, when I moved the stick in what I though was the right way, I was very dissappointed 3 seconds later. |
11-30-2007, 08:31 PM | #7 (permalink) |
The radio is a year old and gets heavy usage almost everyday. The sticks always felt loose since it was new. The bushing fit very loose on the gimbals so there no friction on the gimbals. The bearings fit snug onto the gimbals but are very smooth in operation, you can feel the difference.
Garf |
11-30-2007, 08:42 PM | #9 (permalink) | |
Thanks, John
Logo 600 3D V-Bar, Jazz 55-10-32, Tango 45-7, 0.7/13T, BLS451/BLS251, JR R921, Maniac623 Logo 500 3D V-Bar, Jive 100+LV, Scorpion HK-4020-1100, 0.7/15T, S9452/S9256, AR7000, RT560 T-Rex 600 CF, Jazz 80-6-18, Neu 1515/2.5D/F/H, 11T, S9451, ds760/S9254, AR7000, Radix600 T-Rex 500 CF, stock ESC/motor/rotors, 13T, HS-5245MG, ds760/S9254, JR R921 |
11-30-2007, 08:50 PM | #10 (permalink) |
John,
I am here to share with everyone my discovery how well the quad bearing upgrade works on the DX7. Keep in mind this has to be the most popular radio on the planet by now. This simple upgrade is probably the best thing you can do for the DX7. The bearings can be bought from any hobby store. We are not a hobby store. Garf |
11-30-2007, 09:16 PM | #11 (permalink) | |
Any chance at all you could share the bearing size used so we can all go find some? Thank you, John
11-30-2007, 09:22 PM | #12 (permalink) |
The bearing size is M4 x 7 x 2mm . I am sure any store selling micro helis would have this size. Some ball bearing servos use this size.
Garf Last edited by G-Force Heli; 12-02-2007 at 08:39 PM.. |
11-30-2007, 10:01 PM | #13 (permalink) |
M4x7x2 is kind of a weird size. M4x7x2.5mm is the trex 600 flybar seesaw bearing is it too wide to fit?
12-01-2007, 06:54 AM | #14 (permalink) |
Has anyone found out the correct bearing size/part number needed yet?
12-01-2007, 08:14 AM | #15 (permalink) | |
Would G-Force be marketing those in a complete set with step by step instructions to do the conversion? I would buy such a set without thinking.
Jeroen - Just fly it! |
12-01-2007, 03:00 PM | #17 (permalink) |
I see those are 4x7x2 bearings. My local HS has 4x7x2.5 size ones for half that price. Anyone know if they would fit?
12-01-2007, 03:02 PM | #18 (permalink) |
Those are open. I haven't found a source for a sealed 4x7x2's yet. I might try the 4x7x2.5 the next time my Trex head is apart.
