| Main Forum - Helicopter Talk R/C Helicopters and the people who fly them. VENDOR TOPICS DO NOT GO HERE. Full Scale Heli threads go in OT please |
sorry to take space on the main for this dumb question
Outrage Fusion 50 FBL / Beastx / Futaba 7C .. nice ship, wish I could fly the darn thing To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Depends on the brand
Gaui does tip to tip I think edge does hole to tip
Compass 7HV, El Brute, Ice2 120HV, TracX fbl Compass Atom 500, Ice 100, TracX fbl TX: Futaba 7C w/ Fr-Sky DHT, Soon to be Taranis Old Models: X2, X5, TREX(250, 450, 600ESP), WARP 360, 6HV, 450X, bl CO5M MCPX, Genius CP |
#3 |
The Edges I had were overall length. The overwhelming majority lists overall length. The only brands I know which advertise bolt hole to tip are E-Flite (Blade), ThunderPower and Rail Blades.
Fusion 50: V-BAR+6HV Head, Quantum 4125-560, CC ICE2 HV80, WR SBEC, Align DS610s/650 Blade: 450 3D, 130x, mCPX, 120SR Spektrum DX8 |
#4 |
All blades I've ever bought measure from center of bolt hole to tip of blade, i.e. as advertised :
- Several sets of old and new version SAB 620mm and 710mm, also a set of 705mm FAI's - Several sets of GCT/ Mavrikk 620mm and 710mm. - Rotortech F3C 720mm - Radix FBL 710mm - OEM Henseleit "Rigid" 710mm - Vario Helicopter 725mm I have limited experience with shorter blades, but have noticed that some blades advertised as 325mm actually measures 315mm. Measured correctly... ![]() The total length is of little significance, it's the effective length that makes a difference, and that is from bolt hole to tip.
minicopter Diabolo, Henseleit TDR, MA Spectra-G, Raptor 50T Futaba 2.4 GHz Last edited by Dumbthumb75; 06-01-2012 at 03:29 PM.. Reason: typo... |
#5 |
Exactly. Unfortunately, advertisers strive to Deceive, Inveigle, and Obfuscate.
Rick
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Last edited by rdlohr; 06-01-2012 at 02:04 PM.. |
#6 |
IMHO, the proper way is from the center of the bolt hole to the outer tip of the blade - that is what the working length of the blade is.
Leisure-Tech Rep |
#7 | |
Is this a great hobby or what? Not only am I learning to fly expensive toys, but I am also learning new words. Thanks Rick! Maybe we can start a new thread that posts a "Word of the Day." Roger |
#8 | |
I've had Edge, Radix and SAB "325"s which only measured ~315 bolt-hole to tip. This is why I only use ThunderPower 325s on my B450 now. I really think the extra 10mm makes a difference. Still deciding which to use on my Fusion 50...
#9 | |
I have the 335mm "pro 3d" white carbon blades. They actually measure 325 from bolt-hole. I like them a lot over the fakes that are 315.
FBL clone 250 + 450's - with CX-3X1000 FBL GAUI Hurricane 425 EP with ZYX-s -=- GAUI Hurricane 520mm - bell/hiller mixed paddled stabilization Quote:
#10 | |
Rick
Helifreak, the place to be! Rush 750,Logo 400SE 600SE, TREX 450SE, 500, 600, Blade mCPX,130X My products, flown by top pilots around the world, like you! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#11 |
wow.. thanks all, did not expect so many replies. More confused now but seem to think the larger blades are measured hole-to-tip, while the small blades tip-tp-tip
I asked because I'm running a 600 class on 6s power and the motor is cooler with the 550mm blades. The 600mm blades will be my cool weather blades, and I like the "floaty" way the heli feels, like it's weightless
#12 |
I knew it ! I was going to post "Thanks Scully"
AMA # 865413 Mikado Logo 600SE. Align T-Rex 600 ESP Airwolf. DJI flamewheel 550. |
#13 |
