Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Atom 6HV, 6HVU and 550 Ultimate
Atom 6HV, 6HVU and 550 Ultimate Compass Atom 6HV, 6HVU and 550 Ultimate Model Helicopter Discussion
Old 09-18-2014, 08:41 PM   #1 (permalink)
Default 550 ultimate no boom supports
Im about to start a 550 ultimate build and in the manual it talks about not using the boom supports. I like the look of not having the boom supports but im wondering how much of a risk is it? I tend to fly my helis as hard as I can and dont want to risk a boom strike. Was the 550U tested flying hard 3d without the supports? anyone know? Thanks
dominator is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 09:02 PM   #2 (permalink)
It will not add risk to boom strike. But the extra length and torque will flex the boom more.
You might induce 9ft lb or more of torque. Hang 18 lb of weight at the tail rotor and see how much it flexes sideways.
Sent from my GT-I9100T using Tapatalk
rallyant is offline        Reply With Quote Quick reply to this message
Old 09-18-2014, 09:06 PM   #3 (permalink)
yeah somtimes I "think" I can see my 7hv flexing on hard stops but will it have any negative impacts on how it flies
Old 09-19-2014, 07:58 PM   #4 (permalink)
I'm thinking you might not be able to get the tail gain quite as high without supports. The little bit of extra flex might induce oscillations at a lower gain compared to running the supports. It is a pretty monster boom for a 550 so maybe its just fine. If it says not to run them in the manual I'm sure its fine
quinn is offline        Reply With Quote Quick reply to this message
Old 09-22-2014, 08:07 AM   #5 (permalink)
I'd say if you do a lot of piro stuff with hard stops and reversals it's probably a good idea just to reduce wear and tear.
Sport and smooth 3D stuff I can't see it will flex much and should be ok.
The kit comes setup to try both ways so I guess run w/o and see if anything get's loose or sloppy.
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 09-22-2014, 08:12 AM   #6 (permalink)
Yeah I have about 10 flights on it now some soft some hard but everything seems to be holding up fine without boom supports
Old 01-06-2015, 03:38 PM   #7 (permalink)
I am considering a new 550U and would prefer to run it without the boom supports. Have you flown it much since this report and how is it holding up? Has it been a solid heli without many issues?
vburge is online now        Reply With Quote Quick reply to this message
Old 01-06-2015, 09:16 PM   #8 (permalink)
Reduce the flex with a carbon boom. Make from 25mm od 100% carbon tube.
= Rb43 =
Rob43 is online now        Reply With Quote Quick reply to this message
Old 01-06-2015, 09:26 PM   #9 (permalink)
I've been flying it pretty hard with no boom supports and it's just fine. At least 50 flights and no signs of any flex or wear. It works fine without them and looks great
Old 01-06-2015, 09:32 PM   #10 (permalink)
It's a very solid heli. Best one I've ever had actually. I've adjusted belt tension one time after it broke in and that's it. This heli will take everything you can throw at it. The only thing I will recommend is not to use the plastic compass servo horns. They were flexing in flight for me and causing wobbles cause the gyro was trying to constantly correct for the flex. Switched to metal and it's perfect now. I would defiantly buy this heli again if I were in the market for a 550 or 600. And it's easy to swap between the two
Old 01-06-2015, 11:58 PM   #11 (permalink)
Thanks, that is great to hear. I really like the look of my Mostro without the boom supports and he needs a little brother. The 550 size seems like a good next step for me since I have owned almost every other size and now have plenty of 5000mah batteries to share with one. I have never owned a compass but have heard some great things about their quality and performance. If I don't own one by then, hopefully I will see some at the Birmingham fun-fly in March.
Old 01-12-2015, 07:27 AM   #12 (permalink)
I did probably 150 flights without the struts and had no issues or excessive wear at all. The setup is exactly the same with or without the boom supports, I couldn´t get any different results.
Here is a Video from me without the boom supports:
Compass Model - MTTEC - MKS - Spartan RC
My Compass online store: www.helicoach-shop.de
Keven Schauz is offline        Reply With Quote Quick reply to this message
Old 01-13-2015, 06:10 PM   #13 (permalink)
Also been running mine without supports. Its solid. Saves about 50 grams I think.
Old 02-05-2015, 05:09 AM   #14 (permalink)
@Keven Shauz: What tail blades are you using on your 550U? I like that they match the red on the canopy. Way better than the yellow ones.
The future of setup... now! Soko Heli Toolbox app for a next generation setup experience.
ONE tool for ALL setups of ALL sizes and ALL brands of helis
www.soko-heli-tools.com
soko is offline        Reply With Quote Quick reply to this message
Old 02-05-2015, 05:14 AM   #15 (permalink)
I run mine with out supports, it seems fine as the boom is rigid, and its what attracted me to the Atom 500 and 5.5 originally.
Compass 550 ULT, Eznov Neuron | Thunder Tiger e700 Mini Vbar | Thunder Tiger G4 e820 SPARTAN (Committed suicide)| DX8 #286
Stevewashere is offline        Reply With Quote Quick reply to this message
Old 02-06-2015, 02:26 PM   #16 (permalink)
Hi soko
I use the orange 96mm KBDD Tailblades. They work perfectly for me, great performance on low and high rpm at the same time. I think there is no need for CF Blades on a 550 sized heli, I get the same performance with the KBDDs.
Old 02-06-2015, 02:45 PM   #17 (permalink)
thx.
i was looking for red ones but there are only the orange.
u cant tell the difference in your vid tough.
Old 02-06-2015, 03:02 PM   #18 (permalink)
Well the difference is more visible in real life, but I still think these tailblades fit the look of the 550U canopy really nice.
Old 02-06-2015, 04:04 PM   #19 (permalink)
I run the orange KBDD as well, Almost like they were made for each other. LOL
TSA 700E Platiunm-----Compass 550U-----Gaui X4II-----BX-----Castle Creations-----Savox-----RJX-----Pulse Ultra-----DX9-----And other flying things!
FlyBri3 is offline        Reply With Quote Quick reply to this message
Old 02-07-2015, 04:32 PM   #20 (permalink)
Andi soko when are you getting the 550U
