Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
06-23-2015, 12:05 AM | #21 (permalink) | |
For your castle settings: i use 80-120-80 and castle spool rate is set on 6. Works great on all castle setups i have tried. Just in case you still need a fix.
2 X X7 | Scorpion 4525 Ultimate 4+6T YY / Xnove 4530 525 | scorpion Tribunus 200II ESC | Edge 713 | Logo 690SX | Pyro 440 7+8T YY | Castle 120HV | X3 | 4S | HW 50A V2 ESC | Scorpion 2221 2050KV 9T D | SK540 / Brain2 | Mks |
06-23-2015, 06:59 PM | #22 (permalink) |
See guys, just another reminder that others are just searching through setup figures without any real understanding as to why?
Today I spent a countless hours trying to sort my gov hand off on my 800 gob. Went from heli slow to med, then to fast. Got the gov to hand off only one time, then never again. YGE 160 and Sk720B. I continually dropped my low/high figures until they bottomed out at 10/10, and I still have a vertical gov ramp? How is this even possible?
If it can be done wrong, I will find a way to excel at it. |
06-23-2015, 10:35 PM | #23 (permalink) |
Because its the ss from the esc. I will check the log later.
06-23-2015, 11:04 PM | #24 (permalink) |
Just a bit to add...
With my new 40-40-50 numbers and a smooth spoolup... Every once in a while, I still get my huge overspeed at the start. I was going to delete the current settings in the SK then re-load the settings back into it just to see if it works. Seems weird that it will overspeed about 10% of the time. Also, my overspeed is huge. Well above IU2 HS which is like 300RPM more than normal mode. I'd guess I'm pushing about 2500RPM overspeed with a 1800- 2100 programmed RPM. Now, I haven't tried it yet... But it seems like it still reads the old numbers when it overspeeds. I'm just guessing that erasing it the. Reloading it may clear it out??? I'll let you know. |
06-24-2015, 04:12 AM | #25 (permalink) |
=] looks like you have a sensor issue there Randy? maybe wiring or something? try an external HW see how that goes?!
06-24-2015, 11:59 AM | #26 (permalink) |
Thanks Georgi, it is running the HW sensor, but I will check it all out. Mucho appreciated! Back to basics here? Odd, it does hand over when double spooled though. Then locks in tight. Just checked it since it is still on the table, rpm sensor toggle is clean and showing. Interesting, it is a black dot now instead of the blue, must be the software change?
Omerco, it is on fast spool? Tried all three esc ramps in all the various settings along with virtually every gov setting from top to bottom. Spent numerous days on this one, and packs, missed a few outings due to this. On this 800, the heli spins on the pad and does a 180 during this spool at times it hits hard. Those big blades take some torque and it is impossible to get a quicker hs ramp without biffing gears. So I limit this to heli fast at 4%, but may try auto out of sheer desperation. This isn't my issue I feel? The gov ramps vertical no matter what settings I push here?
06-24-2015, 12:45 PM | #27 (permalink) |
Another question? Since I am curious with no answer. When does the hand off occur? Low or high?
Next, a pilot with a Gasser Gob 700 just emailed me and is curious as to why his Sk540 gov only shows it hitting the magnet every other revolution? Done on view looking for the rpm sig toggle light.
06-24-2015, 01:19 PM | #28 (permalink) | |
Low is where the phase sensor signal takes over, and what allows it to take over we will look at this in detail, please see the ramp in play here, SK don't approve of their internal data on display, so I may have to remove this! the pipe has come in now 4 strokes require half the signal compared to 2 strokes. They need to fire every 720 degrees instead of 360, hence the SK adjusts for this....
06-24-2015, 04:23 PM | #29 (permalink) |
Georgi
I had similar RPM anomaly after updating my logo to rev 4.07? I will check again tomorrow what i get. Randy I'm sorry but I lost you somewhere - I thought you had fair results with the 80 low 120 high and heli fast? what is your setting now?
06-24-2015, 04:52 PM | #30 (permalink) |
=] Omer hi, you are seeing an RPM reading on zero throttle as LMH is in his log? Thanks!
06-24-2015, 05:32 PM | #31 (permalink) |
Hey Guys ,
This is just a little bit of info on LMH question on the Gasser sensor. It is on a Whiplash Gasser with a Zenoah RC290 with gear ratio of 6.88. Running a Sk540 with an Align sensor (Black and Red wires reversed ) Magnet is mounted in the Main Gear with a gear Ratio at 1.00 . What I am seeing is the Magnet passes the sensor . The light stays on for one complete revolution . The magnet passes the sensor a second time the light goes out for one revolution . So one complete turn with it on , One complete turn with it off . Not just a blink as the magnet passes each time . Low Ramp is at 40 High Ramp is at 120 Override is at 0 Gov. Gain is at 28 Thanks Karl Last edited by USA_1_INK; 06-24-2015 at 06:52 PM.. Reason: Added info |
06-24-2015, 06:25 PM | #32 (permalink) | |
Edit, called Karl and it is a two stroke. What is odd is the Sk gov is working on another heli with an OS91 (17,500 or so), which is also a two stroke, but it runs at a much higher rpm? Where the Zenoa RC290, runs at about third less the rpm. (12,200rpm) So his question now is how do we adjust the SK gov to compensate for the two stroke? Change the gear ratio values?
06-24-2015, 10:41 PM | #33 (permalink) |
What is your electrical setup on the 800?
06-25-2015, 12:59 AM | #34 (permalink) |
There is no need to compensate for a 2 or 4 stroke engine... ( you would only need to do that if you were getting the tach from pulses through the spark plug wire ) With an 8.66 - 1 gear ratio, set the SK gear ratio at 1.00 because the magnet is on the main gear. If the sensor was on the fan or even a backplate sensor, the ratio would need to be set at 8.66.
Only possible problem I see is low resolution using the main gear. I don't know your HS... But at 1500RPM, the SK sees 1500/60 = 25 magnet passes per second. Bog down 100 RPM to 1400 and there are 23.333 passes per second. On the fan, you'd have 216.5 per second at 1500HS And 202 per sec at 1400. I haven't run any GOV off the main gear so I can't say if it works well or not. What I mentioned above is just how it looks on paper. Nothing to do with how it would actually fly and hold HS. Last edited by dcope17; 06-25-2015 at 08:25 AM.. |
06-25-2015, 02:28 PM | #35 (permalink) |
Gryphon 7075 running off 2200 3s 45c pack at 8.4v. (same one I run on my Gob 700).
Dual leads up to the controller. Yge 160 esc on 14s. Torq 9180s on cyclic and 9088 on the tail. KDE 455kv gen 3 motor. Sk720B/ Jeti rx. HW phase sensor tied right into the Yge motor output wire poles. Which puts me right at the signal source and alleviates any bad connection issues.
06-25-2015, 04:05 PM | #36 (permalink) |
Which firmware rev? 4.07? if not than you have to start with that phase sensor issue. I also think you got lost there with the 10/10 low/high...
go back to 80/120 and we need to try again from there. EDIT: checked the logs on my 4.07: there is no anomaly. this means your phase sensor is bad or badly connected - as Georgi already wrote.
06-25-2015, 06:54 PM | #38 (permalink) | |
I'll just mention, My 540 is on a gasser as well with the sensor on the main gear but it has three magnets. I bought the heli already built so this was done by someone else but it seems to work pretty good so far.
I have not changed the ramps or overdrive values. Quote:
HD Cell 750, RJX Vector, TDR, TDSF, Kasama Dune and Faifa, Minicopter Triabolo 700, Beam Avantgarde, JR E8 leggero, Suzi Laos, Shape 9, Shape S8, Rave 450, TRex 500, Raptor E700, Compass Warp, Steam 700, Spirit, Spartan, Jeti. |
06-25-2015, 09:04 PM | #39 (permalink) |
And what are your ramps? It might help
06-26-2015, 11:50 AM | #40 (permalink) |
Mine are 100/150/100 but I just updated the firmware to 4.07 and have not flown it yet so we'll see how this works now. On my last flights I was getting a hint of overspeeding when the head was unloaded. Now that I have the gain on the TX I can see if upping the gain makes it better or worse.
