Go Back   HeliFreak > R/C Electronics Support > Scorpion ESC and Motor Support
Scorpion ESC and Motor Support Scorpion Power Systems ESC and Motor Factory Support Forum
Old 12-02-2014, 08:22 AM   #1 (permalink)
Default I think my squeak is a motor bearing?
Back story :
Purchased a used T-rex 500 with a Scorpion 3026-1600 (older)
I've been chasing a high pitch occasional squeak/squeel for some time now. I've pretty much replaced every bearing EXCEPT for the motor. I was looking at a 3226-1600 (newer) But my current motor has all the power I'll need.
Should I replace the bearings in my current motor or the motor all together.
I've tried lubrication (hehe) and the problem still persists. I DO have another align motor I could try and see if the problem goes away?
Thanks.
*LINKS*
* G700c BRAIN2 * T-rex 500 *308DUO *450x #429
Relisys190 is offline        Reply With Quote Quick reply to this message
Old 12-03-2014, 09:09 PM   #2 (permalink)
It could be bearings, but a squeal/chatter can also come from improper governor gains if you are running a gov.
I would recommend trying your other motor first. If the squeal persists, it's probably something else.
Bearing change would be a good start though. The 3226 is a nice motor, and they really are worth the cash. If it were me, I would get the 3226, and keep the 3026 as a backup after changing the bearings.
SoXoS Strike 7.1 (x2) | Miniature Aircraft Whiplash Nitro NII | Miniature Aircraft Fury 57 | Blackout Mods : ??????
Teams: Aero Panda, Heli-Professional, SoXoS USA, 1ST RC, Xpert RC USA, Pulse Battery, iKon Flybarless, Blackout Mods USA
PowerDyne is offline        Reply With Quote Quick reply to this message
Old 12-04-2014, 09:00 AM   #3 (permalink)
Thanks very much for the reply. I'm running a gov gain of 22 in my castle settings. All my motor timing's and such are default.
I think i'll get a 3226 and keep the older version as a spare as you've said. So many options and it's christmas time!
*LINKS*
Old 12-04-2014, 09:18 AM   #4 (permalink)
It is fairly easy to replace the bearings in the 3026. Mine took out a few sets of bearings.
The 3226 is a nice upgrade not only in power but also in smoothness. I have yet to replace the bearings in it.
Tom
TRM Power
CAUTION - my posts are based on my experiences, yours may be different.
fastflyer20 is offline        Reply With Quote Quick reply to this message
Old 12-04-2014, 09:29 AM   #5 (permalink)
There's even a step by step tutorial for the bearing change.
How to change Bearings in a Scorpion Motor by Innov8tive Designs (14 min 30 sec)
And if you have a stuck bearing
How to Remove a Stuck Bearing from a Motor by Innov8tive Designs (4 min 48 sec)
Old 01-29-2015, 07:29 AM   #6 (permalink)
Thank you for posting the video's PowerDyne.
I just ordered and received some Abec 7 bearings from Boca Bearings for my 3026 motor. I've got the motor all apart BUT i do not own an arbor press.
What's a surefire way to remove them without a press?
Also, when re-installing, is green loctite required to retain them?
Thanks alot guys.
*LINKS*
Old 01-29-2015, 11:59 AM   #7 (permalink)
I don't think there's a sure fire way to replace bearing in a motor without a press, before I had an arbor press I would use my drill press.
vebbyson is offline        Reply With Quote Quick reply to this message
Old 01-29-2015, 02:15 PM   #8 (permalink)
I'm going to borrow a small bench vise from work. That will certainly help.
Thank you.
*LINKS*
Old 01-30-2015, 12:59 PM   #9 (permalink)
For those familiar with the 3026-1600 motor.
How many washers/shims under the inside bearing? When I pulled mine apart, there was none. The shaft was even with the bottom of the can. I can see metal flakes where the inner bearing was rubbing on the can itself at the shaft insertion point.
This is my squeak/whine sound for sure. Both bearings are smooth and in good shape, the inner bearing is worn unusually from rubbing on metal. I went ahead and replaced them both with the orange seal bearings I got from Boca.
Thanks.
*LINKS*
Old 10-22-2015, 11:28 AM   #10 (permalink)
Realize this is a dated post however, I had one shim in mine.
P 700 EVO, XLP Nimbus 550, P 380 EVO, Futaba ,YGE-T, neXt and Heli-X
Loud, sudden noises in a helicopter, WILL get your undivided attention
mlp3028 is offline        Reply With Quote Quick reply to this message
