Go Back   HeliFreak > R/C Helicopters > Helicopter Safety
Helicopter Safety R/C Helicopter Safety
Old 08-14-2012, 12:31 AM   #1 (permalink)
Default Small Heli's are dangerous too.
I was flying my Nine Eagles Solo Pro 125 when I had a bad crash. Tail rotor split in half and the tail-boom nearly broke completely off right at the base (and split along about half it's length...).
So I pick the heli up, and I'm thinking "Wonder if the main shaft or anything got bent?" and throttle up while holding it in my hand at face height. Like an idiot I'm standing there looking at the now furiously spinning rotor head right in front of my face, checking for any vibrations.
Then it happens. One of the screws holding the blade holder to the feathering shaft comes loose.
By some stroke of miracle luck, I do not have 110mm worth of plastic rotor blade sticking out of my eye right now. They both missed and flew of into different corners of the room.
JoacimJ is offline        Reply With Quote Quick reply to this message
Old 08-14-2012, 01:57 AM   #2 (permalink)
Hardly a miracle, there is likely a less than 1/20 chance that the blade would have been pointing at your eye when it let go.
I have been hit in the face with the 120mm foam (CF core) blades WK uses... and TBH I have cut myself worse shaving. It is unlikely you would have done any permanent damage to your eye (it would have hurt like a bitch though).
Still, not the most sensible thing to do.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 08-15-2012, 02:20 PM   #3 (permalink)
Totally agree. I often have to remind myself of the headspeed on my MCPX.
Roto-tilling, grass mowing, hedge cutting. Gardening when you least expect it...
Franken MCPx, Franken 450 pro, RC Explorer tricopter v2.5, ST Blaze glider, Heli-x.net sim, Dx6i, JR 9303H 35mhz/2.4ghz,
trondareo is offline        Reply With Quote Quick reply to this message
Old 08-31-2012, 04:18 PM   #4 (permalink)
It always pays to be careful lest you get bitten! Fortunately, I've only had blood drawn a few times from being stupid.
Oh yes, don't fly drunk and naked. LOL
mCPx BL, 130X, 130XRedBull, Trex 450 Pro, Mini Titan e325
+ a few more on the want list, of course!
FlyingRadioWaves is offline        Reply With Quote Quick reply to this message
Old 09-02-2012, 03:46 PM   #5 (permalink)
Is it worse to fly drunk or naked?
CrashNburn420 is offline        Reply With Quote Quick reply to this message
Old 10-01-2012, 10:03 AM   #6 (permalink)
I would think naked. If drunk you might hurt someone, if you're naked you will hurt all bystanders.
giiba is offline        Reply With Quote Quick reply to this message
Old 10-01-2012, 10:32 AM   #7 (permalink)
I think mCPX head spins at somewhere near 4000 rpm. I have a Genius CP and it is somewhere in that range as well. My GCP has thin, sharp plastic main blades. Once when flying it got a little too close to my face for comfort and so I swatted it away with my hand. Ended up with a nice slice in two fingers and it hurt for days. (So different than the mSR that I was used to.)
Took the heli once to fly in one of our large indoor conference rooms. A couple of times the blades hit the wall and left a nice gouge. Also have accidentally chopped the heck out of a couple of young trees in our backyard when lost control doing 3D practice. Fortunately I'm at least smart enough not to fly near any expensive equipment and haven't destroyed any flat screen TVs like some folks have reported.
Yes, small helis can be dangerous! I've learned and am much more respectful and careful now.
rojack is offline        Reply With Quote Quick reply to this message
Old 10-11-2012, 11:54 PM   #8 (permalink)
I vote that small helicopters CAN be dangerous.
I had my Blade 130x spun up - stunt mode 1 (full rotor speed, 0 degree pitch).
Sliced my finger - drew blood, and left a flappy piece of skin around 1/4 inch diam.
I now have respect for it's bite.
I had to learn that lesson the hard way.
I hope others can learn it the easy way - from other's mistakes.
Blade mSRx
Blade 130x
Spektrum DX7s
Align Trex 450S
Old_tech is offline        Reply With Quote Quick reply to this message
Old 11-28-2012, 04:26 PM   #9 (permalink)
I was just going to ask - at what point these micro helis can get dangerous. Your post about the 130X is good to know.
So is it reasonable to say that > 250 size is where you can seriously get hurt?
helifred is offline        Reply With Quote Quick reply to this message
Old 11-28-2012, 04:47 PM   #10 (permalink)
My mCP-x will draw blood (has on me twice).
130X could probably require stitches.
450 will likely require a trip to the emergency room.
600 and up, they call the coroner.
T-Rex 600N FBL iKon | YS .60SR | KDE Upgrades
Goblin 500 w/ iKon and KDE Power | T-Rex 550E FBL 3GX
DJI F450 Quad | Graupner props
Futaba 8FG Super | Spektrum DX6i
drdrums is offline        Reply With Quote Quick reply to this message
Old 11-28-2012, 06:18 PM   #11 (permalink)
you can still hurt people flying naked , you make people go blind.!
Warp, 6HV LED,6HV, Alien 450 MR, 250 mini Quad racer(4s monster) FPV rules the roost!
Airworks is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 12:56 AM   #12 (permalink)
This is exactly right - my mcpx drew blood on my knuckle when I was a newbie.
And 450 size is getting up there in size enough to be called a "flying lawnmower blade"
Finally, the bigger size can definately kill - I read a story that happened here in Texas nearly 10 years ago, apparently a Nitro heli hit someone who was learning how to fly in the jugular vein and killed him.
XL Power 520 / Spektrum DX6
PcChip is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 05:32 PM   #13 (permalink)
Hit myself in the neck and chest with my nano only got a welt on the neck with it. when my mcpx came after me I really move out of the way. I swear they have heat seeking electronics in them.
Fooferdoggie is offline        Reply With Quote Quick reply to this message
Old 11-29-2012, 06:20 PM   #14 (permalink)
HF MR Support
Tangentially, I notice that in instructions about blade tracking, I seldom ever see a mention of putting on eye protection when hovering the chopper close by at eye level. Or is it too obvious to be worth mentioning? I think for a bigger chopper I'd want maybe even a fencing mask!
3 years cancer free! Woot!! ~ Cancer can kiss my grits! Ainokea!
If you never crash, you're not having enough fun!
Pilot, Team Lavaquad
Big Island Guy is offline        Reply With Quote Quick reply to this message
Old 11-30-2012, 03:55 AM   #15 (permalink)
I always mention it. Only time I wear them though.
Do it at a reasonable distance and the chance of a blade actually hitting you is pretty small, considering the amount of area the blades could go and not come anywhere near you. Common sense applies here, if the heli is sounding/behaving strange get it out of that area level with your head.
There really is no other way to confirm tracking than a brief moment at eye level (you can setup the heli so it should be perfect but should still check, the blades themselves can occasionally be slightly out).
-DX8
Old 11-30-2012, 08:59 AM   #16 (permalink)
Checking tracking is the one activity that always makes me nervous, as I'm always envisioning having my eyeball impaled
Old 11-30-2012, 02:59 PM   #17 (permalink)
Just close one eye, atleast you'll save one
Old 12-01-2012, 05:06 AM   #18 (permalink)
And I really believe that an eyelid will stop a main blade at terminal velocity. NOT!
Blade mSRx
Blade 130x
Spektrum DX7s
Align Trex 450S
Old 12-01-2012, 05:42 AM   #19 (permalink)
I sliced a lemon off the tree in our backyard with a nano. No damage to onlookers or heli though.
sosman is offline        Reply With Quote Quick reply to this message
Old 12-02-2012, 01:43 AM   #20 (permalink)
If the blade is only doing terminal velocity, it would not damage your eye seriously (eyes are much tougher than they look, considerably harder to cut than skin). Terminal velocity of a blade is slow, they are not aerodynamically stable so will tumble in flight and so have a low terminal velocity.
Not really an issue though, the blades will leave the heli at a much higher velocity than they could obtain simply from gravity. This is why you dont want to be close to the bigger helis, the blades will slow down fast after they leave the heli, but if you are close and get hit, its gonna hurt.
That said, the chances of getting a blade in BOTH eyes is 0 unless you have homing blades (or the blade smashes your skull, in which case you have bigger problems).
-DX8
