Old 09-26-2011, 06:45 PM   #41 (permalink)
I didn't get pictures today... tomorrow. I forgot the new tail gear box won't be here until then. On another note, the only original parts (not counting electronics) on my 500 now are the battery tray, motor mount/pinion/motor, and the tail fin.
Scott
KBDD Team Pilot ):>
Old 09-27-2011, 04:03 PM   #42 (permalink)
Here's the pictures of mine...
Scott
Name:	Label scrape.jpg
ID:	256574   Click image for larger version
Name:	Max Throw.jpg
ID:	256575   Click image for larger version
Name:	Other Servo.jpg
KBDD Team Pilot ):>
Old 09-28-2011, 03:11 AM   #43 (permalink)
Scott
Nice!
It really shows why you hit BLUE and I hit RED.
My servos are making some freaking noise when I do that. (Plastic gears.)
I leave it as it is for now.
TSH Gaui X5 FES, Spirit, S.Bus, HW100A V3, Formula swash/head
TSH Gaui X3, Spirit, 6S, S.Bus, HW50A V3
Futaba T7C (I admit, also a Spektrum DX8 and some planks.) ;-)
Phoenix R/C v5
helidude71 is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 04:13 AM   #44 (permalink)
Good deal! As long as you're happy, bro. I think this thread has been very useful for all of us with 500's using microbeasts. It has really made us look closely at our setups. For example, since I never got singing servos, I never really looked at the elevator to see that it was lightly touching both the tail drive gear box at the lower extreme and lightly touching my antirotation bracket at the upper extreme. Each is easily addressed with a dremel and a couple of minutes, but interesting to me, nonetheless.
I think it's odd that one servo rubs just enough to take off the plastic from the label and the other doesn't even do that, but you can see on the plastic where it does touch just enough to leave a mark. Fun stuff.
Scott
KBDD Team Pilot ):>
Old 09-28-2011, 04:41 AM   #45 (permalink)
Yep, I've seen as well if you want the most of it, the elevator starts hitting the tail drive gear box.
The antirotation bracket will flex a bit I guess, but the tail drive gear box sure doesn't.
Thx for the discussion, it cleared up my understanding as well.
Phoenix R/C v5
Old 09-28-2011, 05:12 AM   #46 (permalink)
LOL! After breaking two ARB's in consecutive crashes, I decided to go with the KDE ARB. I do have a plastic one as a spare in the event I decide I don't want to break frames anymore.
Scott
KBDD Team Pilot ):>
Old 09-28-2011, 05:25 AM   #47 (permalink)
Originally Posted by labmaster View Post
The original T-Rex500 is not very optimal at the overall geometry of the swashplate control.
The problem is that the swashplate inner ring to outer ring ratio is not too good.
As this ratio defines the collective to cyclic ratio you will have problems maxing out the pitch ranges and not violating the cyclic resolution restrictions of a flybarless system.
You have to modify the swashplate ratio to get more collective and less cyclic deflection on the same servo travel, as this would allow you to move the ball on the servo outside a little bit and still achive blue at 6° (means, no lost cyclic resolution) . With the ball out a little bit on the servo you then are able to get a higher collective range on the bladegrips with less servo travel and this on the other hand will save you some servo travel for getting more cyclics before running into any binding.
To modify the swashplate ratio you have to make the outer ring of the swashplate wider or the inner ring of the swashplate smaller. At the original Align FBL conversions you get shorter inner ball to make the inner ring smaller, this helps but could not fix the problem completely (depending on the collective and cyclic values you want to go)
Another problem on this heli is the limited room for the servo horns, as especially on the elevator servo the servo is not able to do its full range without touching parts of the frame.
For this i modified a servodisk so that it looks like a servohorn with a curve in it where it is going around the binding place a bit, every millimeter could be of help here.
best regards,
Walter
After re-reading this post it looks I can give it a try to put the balls on the servo arms one more out (16 mm hole) and use the shorter balls on the inner swash ring.
All this with the stock swashplate and Align FBL head.
Anyone with this exact same setup care to comment?
Will Step J and L be BLUE with +/-12* at step K?
Phoenix R/C v5
Old 09-28-2011, 02:13 PM   #48 (permalink)
I don't, but I had wondered why someone hadn't given Walter's suggestions a go until now. If anyone will know, he will. If going from 13mm to 16mm on the arm is too much to make back up by going shorter on the inner swash, you can always go longer on the outer swash as well, which I think Walter also mentions. I think I mentioned before that I would have like to stay at the recommmended 13mm, but I guess what you lose there by going to 16mm, you simply get back by changing the other ratios.
Interested to hear how you get on in the end, even though I don't have a 500. I imagine those that do will be even more keen to find out exactly what can be achieved with the right choice of balls, and perhaps a little work on the AR bracket. Interesting that Walter explained that the 500 has poor geometry wtih the standard swash, this must be why I have a completely different experience with my 250, 450, and 550.
Good luck.
Cheers
Sutty
Regards, Sutty
sutty is offline        Reply With Quote Quick reply to this message
Old 09-28-2011, 06:56 PM   #49 (permalink)
Helidude, use the 2nd hole from the outside of the arm
Trex250 Super Combo/ EXI 250 Super combo with Align F3C fuse/ HK450V2 FBL w/ BEAST X/ EXI 500 FBL w/ BEASTX/ COMPASS 7HV w/ AR7200BX/ MKS HV Servos/ YEP120HV/ Turnigy SK3 HelidriveKBDD on everything
DVUSHELI is offline        Reply With Quote Quick reply to this message
Old 09-29-2011, 04:02 AM   #50 (permalink)
OK, to make sure we talk about at the same thing a picture.
You mean the hole with the arrow?
Phoenix R/C v5
Old 09-29-2011, 06:01 AM   #51 (permalink)
Just as an FYI, I took a look at 500FL Pro pictures and saw Align has modified the tail drive gearbox and the antirotation bracket for better elevator linkage clearance. I don't see much in the way of the pitch and aileron servo clearance being different as it is still a DS510, but it's a DS510M. So, maybe they're ignoring the slight hit at extremes for these servos as well?
Scott
KBDD Team Pilot ):>
Old 09-29-2011, 01:49 PM   #52 (permalink)
Scott
Haha! I know you like that idea.
You triggered me to look inside the 500EFL manual.
They use the D6FF Metal Servo Horns and tell you to use the most outer hole.
There is no info about how much mm this hole is.
I asked a fellow freak and will post it here as soon as I know.
Phoenix R/C v5
Old 09-29-2011, 03:04 PM   #53 (permalink)
Using the outer hole may be because the frames are narrower, but the reality is, the only thing I see less width doing is making the swash to servo geometry a bit odd. I could be wrong, though. The swashplate in the pictures I've seen definitely have balls with standoffs; one larger than the other.
Scott
KBDD Team Pilot ):>
Old 09-29-2011, 03:10 PM   #54 (permalink)
This one from rotaryguy?
The number on the swashplate is completely different I see on my 500ESP swash.
I do see the inner swash has the two shorter balls.
More I can't tell without seeing them next to each other.
Phoenix R/C v5
Old 09-29-2011, 04:16 PM   #55 (permalink)
Yep. That's the picture. I'm helping a friend build a V2 550 and it has a similar ball/swash setup.
Did you check out the metal servo arms on the 500E? Overkill for a smaller helicopter given the torque needed to move the blades and trouble in hard crashes because the servos can be totally destroyed instead of having a broken arm. In the three years I've had my ESP, I can't tell you how many servo arms I've broken in crashes.
Scott
KBDD Team Pilot ):>
Old 09-29-2011, 05:41 PM   #56 (permalink)
I listed the specs on this product page. My measurements were 18mm and 21mm. I hate that align does not put this info anywhere on there specs so I measured myself and did it for them..
Hope this helps.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 09-30-2011, 10:08 AM   #57 (permalink)
Correct sir!! The second hole from the outer most hole. Then put short balls on the inner swash ONLY for the links, NOT the mixing arm links. Sorry for the late reply. I've been out having WAY too much fun with my 500
Old 09-30-2011, 12:36 PM   #58 (permalink)
Originally Posted by akamullen View Post
... My measurements were 18mm and 21mm. I hate that align does not put this info anywhere on there specs so I measured myself and did it for them..
Hope this helps.
Yes it helps!
Got the same info from a fellow freak.
Thx.
Phoenix R/C v5
Old 09-30-2011, 12:37 PM   #59 (permalink)
Scott
Good point for not going with the metal arms.
Phoenix R/C v5
Old 09-30-2011, 12:47 PM   #60 (permalink)
I believe you do!
Align always gives you mm measured from the inside out.
To prevent confusion I wanted to make sure, thx.
You are now on the 16 mm hole.
I think this looks like the best answer to the problem.
Even the metal horns don't have 13 mm holes. (But and 18 mm and 21 mm.)
So, use the 16 mm holes on the plastic horns and the shorter balls on the inner swash ring.
I have to verify this myself but hitting blue/blue on Step J and L must be possible.
Problem now is, this weekend it's great weather in The Netherlands so I follow DVUSHELI and fly the out of it.
Wrenching we do afterwards.
Please chime in if you have the original Align FBL head and swash and already use the above suggestions.
Phoenix R/C v5
