Go Back   HeliFreak > R/C Helicopters > Newbies: Tips and Information
Newbies: Tips and Information Section of HF, specifically for Passing along info to newcomers to the hobby. Setup, tweaking, orientation practice, etc.
Old 08-24-2015, 10:48 PM   #1 (permalink)
Default 3gx tail returns off center
Hello
I am working on my first setup of a 450 pro fbl with the 3gx. I have a dx 8 transmitter. After take off, if the tail starts at 6 o'clock, it moves to 4 o'clock. When I move rudder to move the tail back to 6 o'clock it will go back to 4 o'clock after a few seconds.
I am using the 3gx as the receiver with satellite, no sub trim on rotor servo. Set to 90 degree, went through rudder setup. I experimented with gain from +30 to +80 and didn't see much difference.
Turbo0411 is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 02:29 PM   #2 (permalink)
Set it up to hold a stable hover in rate mode using the linkages then it will be fine
jgiannakas is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 02:39 PM   #3 (permalink)
Could also be vibrations.
Craig
T-Rex 600N | T-Rex 500 ESP | T-Rex 500 GF | T-Rex 250 (Love this little bird) | 22 year old Shuttle ZXX
Ozz58 is offline        Reply With Quote Quick reply to this message
Old 08-25-2015, 03:11 PM   #4 (permalink)
Check this out
3GX Setup Guide Part 3 Rudder, Delay & Anti Torque Compensation (6 min 33 sec)
Ron
Petrolia Ontario Canada.
Electric, MCPX-BL,450X, Trex 550E Nitro Hirobo SCEADU Evolution 50
Imzzaudae is offline        Reply With Quote Quick reply to this message
Old 08-26-2015, 05:44 AM   #5 (permalink)
Thank you for the replies. I've watched the videos but still have the issue. I noticed when I increase throttle/pitch the helicopter might even move farther to say 3 o'clock and come back to 4.
I think this might be a setup issue as mentioned. Even though everything looks close to 90 degrees, in rate mode the helicopte does rotate on the ground. Ive adjusted the link but just cant get the helicopter not to rotate. If I go to take off it looks like it might tip? Any additional pointers? I can minimize the rotation ssignificantly with subtrim but everythng i see says don't use subtrim on rudder. Please advise
Old 08-26-2015, 05:30 PM   #6 (permalink)
What are your pitch and throttle curves ?
Please post them for me.
Ron
Old 08-27-2015, 01:00 AM   #7 (permalink)
Had same problem with gpro. Align put resolution on 3gx faq and all it is is to reduce the length of the push rod ... Just give a few turn to the linkage, adjust limits and try again ... It will be good
fean07 is offline        Reply With Quote Quick reply to this message
