Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mCP X Brushless Mods
mCP X Brushless Mods Blade Micro CPx Brushless Mods and Conversions
Like Tree2Likes
Old 01-11-2016, 10:37 AM   #3561 (permalink)
I thought you went back to 3.4?
For the most recent Revision of BlHeli Setup see my blog.
4712 is offline        Reply With Quote Quick reply to this message
Old 01-11-2016, 10:53 AM   #3562 (permalink)
I've been there and back several times. I'm desperate, I'm trying anything and everything. I'm not sure exactly where I ended up last.
mcpx, nano cpx, nano cps, 130X, mcpx bl, 120sr, 120s, nano qx, 180qx, 200qx, 350 qx
megasmicros is offline        Reply With Quote Quick reply to this message
Old 01-11-2016, 11:06 AM   #3563 (permalink)
So again, you did not answer to the post: Do you have a XP-3A and flashes the DP-3A firmware or vice versa?
Old 01-11-2016, 03:45 PM   #3564 (permalink)
I'm trying to flash an XP-3A and it seems to be flashing XP-3A. After flashing it I disconnect and reconnect and it reads XP-3A.
Old 01-11-2016, 04:01 PM   #3565 (permalink)
This does not mean, that it really is an XP-3A.
If it is a DP-3A and you flash it with XP-3A it will respond as XP-3A, but will not react to any input over the servo line, because it has a different pin mapping.
Other reason could be a lost solder joint at the input pin.
Do you have an HighRes image?
Old 01-11-2016, 04:03 PM   #3566 (permalink)
Let me try and get one.
Old 01-11-2016, 04:17 PM   #3567 (permalink)
Didn't get a very good picture but I did verify the path between the signal input and the mcu is good, using a multimeter.
Old 01-11-2016, 04:19 PM   #3568 (permalink)
OK, is this the only ESC with problems?
Old 01-11-2016, 04:22 PM   #3569 (permalink)
No I have tried several XP3As and DP3As. I got a 3.5 to work properly. I can redo any of it if it helps us troubleshoot. I've got plenty of escs, flashing tools etc.
Old 01-11-2016, 04:27 PM   #3570 (permalink)
If flashing went OK, then there is nothing to reflash.
Pleas do a scope sreenshot of the input signals.
Old 01-11-2016, 05:12 PM   #3571 (permalink)
996 Hz
1.004 ms
Old 01-11-2016, 05:24 PM   #3572 (permalink)
Looks fine, is it negative PWM?
This works for me with nanoCP-X...
File Type: txt BLHeli_EAZY 3AV2 2-FET_160104.txt (804 Bytes, 191 views)
Old 01-11-2016, 05:26 PM   #3573 (permalink)
Let me try once more with those exact settings. Yes Negative PW
Old 01-11-2016, 05:36 PM   #3574 (permalink)
No such luck.
Old 01-11-2016, 05:46 PM   #3575 (permalink)
I am using 14.3.0.1 I noticed you have 14.3.0.2, I'm not sure if that will make a differnece.
Old 01-12-2016, 03:49 AM   #3576 (permalink)
No. That doesn't make any difference.
Old 01-15-2016, 09:08 AM   #3577 (permalink)
Default 14.3 didn't work on an XP3A maybe others
Achim,
Sorry to be so long to get back to you. I have been very busy.
I just updated an XP3A, that had Blheli version 12.? to 14.3. I imported the settings, too.
It didn't work. But back to 13.2 and it works fine.
Last week or two I was working with some ESCs and I thought it was me! I am not that good at soldering. And I let the smoke out of one. But I have had lots of practice lately. I can see and solder better than I could last year due to vitamins D3 and K2.
I will re-check an XP12, an XP7A and an MX3 that I couldn't make work in these last couple of weeks. I had frustration and lots of soldering practice swapping ESCs and motors.
be well,
Dave
Good luck and happy landings.
daveapplemotors is offline        Reply With Quote Quick reply to this message
Old 01-15-2016, 09:25 AM   #3578 (permalink)
Originally Posted by daveapplemotors View Post
Achim,
I just updated an XP3A, that had Blheli version 12.? to 14.0. I imported the settings, too.
be well,
Dave
Thanks a lot Dave.
There must be something, I still do not understand. I will do some check with different revisions and setups when there is time left.
cheers
Achim
Old 01-19-2016, 07:35 AM   #3579 (permalink)
I'll take a good picture of a 3A tonight so you can check the mapping on it. Thanks for all your help.
Old 02-09-2016, 08:12 PM   #3580 (permalink)
OMG! I still can not get any esc to arm! I've done it dozens of times before but I can't seem to get anything to work. I really need some help folks. What info is needed so I can get over this issue. I have plenty of people waiting on me to get this resolved.
