Old 08-02-2012, 10:11 PM   #1
Troy003
Default Frame Flex=Broken Main Shaft?
I do not own a 300x but have been looking at adding one to my fleet. One of my concerns is hearing about the main shaft breaking during flight. I have also heard that the frame might flex during hard collect/direction change causing stress on the spinning shaft. Defective main shaft/frame or combination both??? Please share you experiences with these issues. Is the 300x worth it? Thanks.
While driving my girlfriend always asks "Wait, this looks like we're on the way to the hobbystore"...I casually change the subject. Ive been winning this game since 2009.
Troy003 is offline        Reply With Quote
Old 08-02-2012, 10:35 PM   #2
Drivinfast247
Wrong section buddy.
Drivinfast247 is offline        Reply With Quote
Old 08-02-2012, 10:53 PM   #3
ChrisH
Moved to 300X forum.
Edge Rotorblades
Thor/Voltz Batteries
450 Pro V-Bar
130X
ChrisH is offline        Reply With Quote
Old 08-02-2012, 11:13 PM   #4
branmuffin
Very small number of defective main shafts. There is some frame flex in some models but havent noticed it myself. I fly mild 3d and pretty often mash the sticks and have not noticed any ill effects yet after 50+ flights. No rubbing or breakage.
Synergy E7
MSH Mini Prôtos FBL Stretch 6s
MSH Prôtos CF FBL Sretch
branmuffin is offline        Reply With Quote
Old 08-03-2012, 01:33 AM   #5
stevebaker
The frame flex is a poor design.
If you don't mind stiffening it up then it's still a nice heli worth having. It really needs stiffening as it causes / amplifies vibes, rubs the servo link and stresses the main shaft
Blade MCPX - C05M, XP-7A,
Blade MCPX BL
Blade 300X
Parkmaster 3D, Funjet, Sbach 3D, DX8, Pheonix Sim
stevebaker is offline        Reply With Quote
Old 08-03-2012, 09:07 AM   #6
ahahn
I think this is an oversimplification of the problem.
It is the vibration that one needs to fix.
I've been flying mine, nothing extreme, but flips, circuits,....smooth as silk. I admit I am lucky everything is so smooth.
No rubbing or such.
ahahn is offline        Reply With Quote
Old 08-03-2012, 09:52 AM   #7
GSPI
These issues are a result of airframe stiffness or lack of stiffness that would cause this shaft failure. I have been delving into this problem and I can relate this to airframe stiffness problems which seems to be related to possibly inconsistent manufacturing practices. I have a very long thread here on my assessment:
http://www.helifreak.com/showthread.php?t=438478
There are many here noticing the issue but others not so it relates back to the consistency of the airframe molding and possibly the design.
Beating the air into submission... one Blade® at a time!
Lynx Heli Innovations Team Pilot
SilentDRC.net -The Order of Brushless Witnesses
GSPI is offline        Reply With Quote
Old 08-03-2012, 10:17 AM   #8
kvandenbroucke
I can add to this statement, my 300X has no vibes at all and i can spoil it up on the floor in the house without vibes, even light on the skids there were no vibes.
Still in flight during the 3rd battery the main shaft snapped.
The tower of the mainframe moves around when you give ail/cycl/pitch,
this makes the shaft bend at the bolt above the main gear, just a little but enough to cause metal fatigue. The hole for the bolt is 2mm, the shaft only 4mm. So you have only 1mm metal to handle all the force. This might be enough for stiff tower but not for my flexible tower though.
You can calculate the hardness of a shaft based on torsion forces, but when the shaft also bends this is a whole other scenario and you calculations is wrong.
Conclusion: we need a stiffer frame from another material like the 450X has.
DX6i, blade 450 3D, mcpx c05m, mcpx v2 stock. 2 x blade 300X. Started with a solo pro 2 years ago.
kvandenbroucke is offline        Reply With Quote
Old 08-03-2012, 12:40 PM   #9
CousinLarry
Yep - that's it. I replaced the frame in mine because that tower broke off in a crash. The new frame I got is about one step above rubber on the hardness scale
I could twist it and bend it any which way. Feels almost like soft nylon or something. If it was just rigid hard plastic it would be so much better. Pretty crappy if you ask me.
And the second I un-boxed mine, my first thought was "Damn that mainshaft looks thin."
Hope a solution is found soon or I'm not sure how long I'll keep the 300X.
Edge 540QQ • ASbach3X • HT-FPV Quad • Concept Pro EDF • MCPX BL • UMX GeeBee • Mini Vapor & Ladybird Micro Quad for living room fun
CousinLarry is online now        Reply With Quote
Old 08-03-2012, 01:01 PM   #10
mixfisto
Its a shame they made this heli with such a weak frame... I personally love this heli and will just wait until someone starts making a stiffer frame or a solid stiffining fix.
mixfisto is offline        Reply With Quote
Old 08-03-2012, 02:57 PM   #11
ahahn
Well you will miss a lot of flying!
Old 08-03-2012, 04:34 PM   #12
mixfisto
Oh contrare, mufrare... I will be flying A LOT!!
Just saying that I'll be among the first in line to upgrade the frame
Old 08-04-2012, 06:53 PM   #13
Eric_heli
my 300x frame doesnt flex nor does the servo arm . link touch the motor. however while i was on my 4th battery and 4th flight my main shaft snapped. all i was doing was fliping her around and snap.
Eric_heli is offline        Reply With Quote
