Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 05-22-2010, 05:42 AM   #1 (permalink)
Default Straightening out the center hub?
I thought i read on here the other day that one of our forum users here had luck with taking the wobble out of the center hub? My SR came shipped from the factory with a decent wobble but i just dealt with it for 3 months.
Well i finally shredded that center hub and I install a brand spanking new one and its twice as bad as the original was, wtf !
Anyone have any tips or do i just live with it? I couldnt imagine seeing my SR's head spin true at low rpms.
Joseph T. is offline        Reply With Quote Quick reply to this message
Old 05-22-2010, 01:10 PM   #2 (permalink)
Here's what I do since each hub I put on seems to wobble worse than the one before. I take the whole head assembly off and leave just the hub. Then I tape an Allen wrench to the antirotation bracket to where the short end of the wrench is closest to the top of the hub without touching it. After that I spin the main gear slowly to see where it's bent, give it a little heat from a hairdryer, and carefully bend it until when you spin the main gear and the Allen wrench stays a roughly equal distance to the top of the hub all the way around. It probably will take a couple of tries and, wa-la! It's as close as a piece of molded plastic's gonna get to being true. Hope that helps
-Goblin 700: Crashed but re-building, still needing electronics
-Goblin 630: CC Ice 120HV, vBar
scoti333 is offline        Reply With Quote Quick reply to this message
Old 05-22-2010, 06:11 PM   #3 (permalink)
S, That is very interesting....I'm going to have to try that......thank, john
John Shipley is offline        Reply With Quote Quick reply to this message
Old 05-22-2010, 08:53 PM   #4 (permalink)
Nice scoti, thats some real good info. I'm gonna try that next time i gotta re-build the head.
THANKS
Old 05-22-2010, 09:43 PM   #5 (permalink)
No prob!
Old 05-23-2010, 06:42 AM   #6 (permalink)
I wish that someone would come out with an aluminum hub so we wont have to worry about this. Mine has the darn wobble to it too.
E-fanatic is offline        Reply With Quote Quick reply to this message
Old 05-23-2010, 07:36 AM   #7 (permalink)
+100. Hurry up E-flite, then get back to work on my MCP! Been flying my dad's Novus 125CP and it's getting harder to talk myself into waiting for an E-flite one. If only the novus didn't have such a crappy Tx, no TH and IU is on the wrong side! That could end badly.
THIS IS MY SIGNATURE. THERE ARE MANY LIKE IT BUT THIS ONE IS MINE.
Mojappa is offline        Reply With Quote Quick reply to this message
Old 05-23-2010, 03:53 PM   #8 (permalink)
Lmao! No joke!! "Ok, coming in for a landing, touch down in 12 inches. Engage throttle hold... correction, compensating for unanticipated rpm increase and changing shorts!"
+1 to the wobbly head, what gives on these things? Waited a month and a half for my new parts and took my precious time rebuilding. Spool up and at the low rpm sweet spot got a vibe that dances the heli from side to side. A little more juice and she's smooth as silk... annoying. I'm gonna try that allen key thing scotti, thx for the idea!
DKS_ONE is offline        Reply With Quote Quick reply to this message
Old 05-24-2010, 12:17 PM   #9 (permalink)
Just payin it forward! Glad I could help.
Old 05-24-2010, 12:36 PM   #10 (permalink)
Default Tight Jesus
The last head rebuild I did on my SR, I didn't tighten the jesus bolt down all the way. I just screwed it in until the bottom of the allen head bottomed on the hub. I didn't want to deform the base of the hub and it seemed to help as I didn't need to straighten this one. I've had 2 wobbly hubs before this one and the only thing I did differently on my current hub was not torque down the jesus bolt. Coincidence?
BrandonB is offline        Reply With Quote Quick reply to this message
Old 05-24-2010, 12:41 PM   #11 (permalink)
I did this as well. Seems if you tighten it down, it will deform the shape. I just left mine a little loose, (but in though), and it helped.
Nuke
Spektrum DX6i
E flite SR
Trex 500 ESP
nuke is offline        Reply With Quote Quick reply to this message
Old 05-24-2010, 12:41 PM   #12 (permalink)
That's a likely possibility. The plastic used with these parts is easy to deform when you over tighten the screws.
- 6S TREX 450 Pro FBL - µBeast, MKS, Castle Creations
- Goblin 500 - Kontronik Pyro 600-12, Jive 100lv, iKon, BK servos
- TBS Discovery - Pixhawk
- Spektrum DX7
SeanM is offline        Reply With Quote Quick reply to this message
Old 05-24-2010, 02:18 PM   #13 (permalink)
I definitely noticed this, too. That, along with checking and correcting how bent (or not bent because they're all different) it is will take most or all the wobble out of your hub. Can't wait for a cnc hub!
Old 05-24-2010, 05:54 PM   #14 (permalink)
Default Main gear will also deform
The main gear will also deform if you tighten the lock nut / bolt down too much. I just let the lock nut do its job and leave it practically loose. Doesn't look like it will ever vibrate free cause of the nylon in the nut.
Old 07-03-2014, 12:21 PM   #15 (permalink)
Microheli has CNC aluminum center hubs. However, you will also need to buy the aluminum flybar system as well since the original system won't fit on the CNC hub (sounds like a money grab to me).
Hutch76 is offline        Reply With Quote Quick reply to this message
Old 07-04-2014, 10:30 PM   #16 (permalink)
Thread is over 4 years old
Dwayne
DX8, DX6i, 200QX, 180QX FPV , Nano QX x2, ProtoX x 2, Cheerson CX-10 x3, Blade SR, MCX2, mSR, mCPX v2, Nano CP X BL
Dubbin1 is offline        Reply With Quote Quick reply to this message
Old 07-05-2014, 04:17 AM   #17 (permalink)
Thats ok, some of us still messing with the SR......
Blade: Nano QX, SR, 230s, 400 3D
Walkera: V120D02s
Align: 450L Dominator, 450 Pro DFC,
500 Pro DFC
nighttrain06 is offline        Reply With Quote Quick reply to this message
Old 11-09-2014, 01:21 AM   #18 (permalink)
Yup.. still messing with it... It's like the energizer bunny.
Spek iX12 | DX7G2 | NANO CPX | NANO S2 | MCPX BL2 | 120SR | Fusion 270 | AH64 Apache (450) | D380TBR | 450X | OXY 4 "360" | Goblin 420 | 500X | 550X | AGILE 5.5 | OXY 5 | AMA# 1157132
therick04pp is offline        Reply With Quote Quick reply to this message
