Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Compass 7HV, 7HVU and Chronos
Compass 7HV, 7HVU and Chronos Compass Compass 7HV, 7HVU and Chronos Model Helicopter Discussion
Old 07-03-2015, 12:43 AM   #1 (permalink)
Default Notchy head on 7HVU
So I recently finished building my 7HVU and am having an issue where I can't tighten the main grips down all the way without getting a very notchy head. I loosened them a little and trusted the loctite to hold them, but after 3-4 minutes in the air, thankfully I checked and they had loosened up quite a bit. Suggestions?
Compass 7HV (SK720BE w/GPS1)
Oxy4 (Spirit 2) / Oxy3 (SK720 Blue)
JR 11X
Shabill is offline        Reply With Quote Quick reply to this message
Old 07-03-2015, 05:47 AM   #2 (permalink)
Tighten them up good with loctite! They will feel notchy when they're static but if you pull out on them while rotating, it will put the load on the thrust bearings, instead of the radial bearings, and they will turn smooth as butter. Same thing in the air.
eskoskimo is offline        Reply With Quote Quick reply to this message
Old 07-03-2015, 08:47 AM   #3 (permalink)
I concur. When the dampers are fresh, they impart a great preload. Once they have broken-in a bit, it will be fine. They will always be tight, however.
= Rb43 =
Rob43 is online now        Reply With Quote Quick reply to this message
Old 07-03-2015, 09:36 AM   #4 (permalink)
Red loctite and make sure you degrease all the threads.
squeely531 is offline        Reply With Quote Quick reply to this message
Old 07-04-2015, 09:31 AM   #5 (permalink)
And make sure you tighten them on any 700 I've seen them come off in flight and it's not fun
Your is my Bread and Butter.
Compass Field Rep/KBDD Team pilot/Experiencrc.com
sewerfly is offline        Reply With Quote Quick reply to this message
Old 07-04-2015, 03:52 PM   #6 (permalink)
After 7 years of flying, I had that happen with my X3 last week, and even with 360mm blades, it's pretty spectacular. Glad no one was in the trajectory of the blades (I was the only one at the field, so I guess I'm extra glad about that).
So years in the hobby and red loctite is one of my least used tools, but after an unsuccessful maiden of my 7HV last week due to a slipping pinion, I got comfortable using it on the grub screw in the pinion. So with a 3mm hex head, do you still have to heat up red loctite if you ever have to remove it?
JR 11X
Old 07-04-2015, 06:11 PM   #7 (permalink)
Yes, expect to use heat. Depending on how much you used, and how clean the threads...could be difficult if you don't. I've broken several wrench tips on those set screws.
= Rb43 =
