Go Back   HeliFreak > R/C Helicopter Support > Gasser Helicopters
Gasser Helicopters Gasser Specific Discussion
Old 09-07-2014, 12:06 AM   #1 (permalink)
Default Anyone using an Ikon on your Gasser?
Anyone has the Ikon on your gasser? Have you used the Self Level? How do you have the Ikon mounted?
Thanks!
gta18 is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 08:07 AM   #2 (permalink)
Yes I am , another guy in my field is too
No have not tried the self level on this bird
It's mounted using the "Milton" method . Zeal tape, fuel tubing and zip ties . Works well.
Goblin Gasser TRM VX310TT Align MJ Design DTS 700N 91 HZ-R 3D Blackout Extreme Gasser #4 MCPX BL 2 iX12
Gaba
Rahulgaba is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 12:58 PM   #3 (permalink)
Got mine with one layer of 3m. Works great
ID:	534561   Click image for larger version
-JOHN-
Doomsday12valve is offline        Reply With Quote Quick reply to this message
Old 09-07-2014, 03:05 PM   #4 (permalink)
Nice setup! Looks like self level will not work with just a layer of tape like that. Are you using the gov with gassergator?
Old 09-07-2014, 03:06 PM   #5 (permalink)
It'll be nice to find out up high though if the
self level would work using that Milton mod.
Do you use the internal gov? Gassergator?
Old 09-07-2014, 03:14 PM   #6 (permalink)
I am using internal governor with no issues what so ever !
Gaba
Old 09-07-2014, 09:05 PM   #7 (permalink)
I believe the OP is trying to figure out if self level will work with his gasser. Besides the self level, everything on the ikon work flawlessly. If your trying to find a unit with a reliable bailout feature I'd look into the Bavarian demon, although I don't know how well that works on gassers either.
XL Power 700v2 Nitro NME - OS 105HZR - Power Tune - Rail 716/106 - Brain2 HD
Sowa is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 02:54 AM   #8 (permalink)
I haven't tried SL on my Zenoah powered heli but it works on my GT15HZ heli.
Suat
Trex 700 Gasser
FBL | HeliBug HB7-RC 17T | Silverline V-Bar| TRM VX290TT | SG | RJX Gas muffler (modded)
Trex 600 Gasser FBL | HeliXHeli conv. | OS GT15HZ | iKon | Homemade onboard generator
Azalin is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 05:50 AM   #9 (permalink)
I'd be curious to know how you have the sensor placed, I've spent hours trying to get it to work with no luck.
Trex 600 N DFC, Trex 600 Nitro Pro converted to DFC, Trex 700N DFC
& 3 IKON FBL UNITS
Brian0371 is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 07:53 AM   #10 (permalink)
Two Magnets drilled into the main gear on opposite ends with an align pick up sensor. Simple, reliable.. Gear ratio of 1.0
If you see in the ikon thread, I did have a wierd issue, that my sensor was "too close" to the magnets , so sensor would pick up south on both.. Giving double rpm readings, and I just spaced it a bit, and that fixed my issue. THATS IT. It is tried and tested in so many other models, so it works well here too.
Gaba
Old 09-08-2014, 08:27 AM   #11 (permalink)
Do you have the Milton mod mount on the Gt15Hz?
Old 09-08-2014, 08:28 AM   #12 (permalink)
I have the Bavarian demon, but would like to use the internal gov on the ikon.
Old 09-08-2014, 08:30 AM   #13 (permalink)
No, just a single layer of 3M tape.
Sent from my GT-I9300 using Tapatalk 2
Suat
Trex 700 Gasser
Old 09-08-2014, 09:58 AM   #14 (permalink)
if you are looking for a good SL and rescue, forget the ikon and use the BD. bite the bullet and use an external gov, the SL and rescue on the BD will work on the gasser hands down, no questions asked. (provided you don't have a horrible vibration or a motor with bad balance or something....) the ikon does work well for a gasser, but I don't know about the SL function. I have never tried it with a gasser. I had a scary incident a year or so ago with an electric I tried it on, so I don't trust it. I still fly one on my night rig, but I don't use SL at all....
Gasser Mike
Team KDE Direct, TRM Power, Byron Fuels, MKS Servos
LoveToFly1 is offline        Reply With Quote Quick reply to this message
Old 09-08-2014, 10:15 AM   #15 (permalink)
Hey LoveToFly1,
I know you are talking to the op but,
I understand what you mean. If a unit is needed with the best rescue then BD should be used. As you are saying an external governor is needed as well but you know an external receiver is needed too. For me simplicity is more important than SL/rescue. I use the ikon (and V-Bar on my other heli) standalone. No external governor and no receiver so I save lots of room for my generator stuff.
On the other hand, I find iKon governor works better than GV-1.
Suat
Trex 700 Gasser
Old 09-08-2014, 01:35 PM   #16 (permalink)
Hey LoveToFly1,
yup, I was. and I do see your point too. if you don't want/need the rescue function, I would tell you use the IKon all day long. with its internal gov, that cuts down on the complexity a lot. I personally cant say how they fly on a gasser, but I like they way it flys on the electric I have it on.
Gasser Mike
Old 09-08-2014, 02:17 PM   #17 (permalink)
I like simple and I need rescue. So do you guys think that even with the Milton mount the self level on the ikon would still be unreliable?
Old 09-08-2014, 03:22 PM   #18 (permalink)
It depends on the heli and the motor you are using I believe.
Suat
Trex 700 Gasser
Old 09-08-2014, 04:41 PM   #19 (permalink)
also, Ikon doesn't have rescue....it only has SL. it will not snap level inverted and add pitch. it will only roll to upright, its up to you to add pitch...
Gasser Mike
Old 09-08-2014, 10:14 PM   #20 (permalink)
Going level would be enough for me. My bd3sx taught me how to fly.
I want to use the ikon because of the gov and SL.
@azalin
I think the engine on my r90 is a g126 with the Hanson mod. I bought the heli used a couple of months ago and I haven't fired it up yet.
Do you think that engine has a lot of vibration?
