Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
08-17-2010, 07:17 PM | #1 (permalink) |
Installing 3G Link. I got a weird error window.
Here is a pic of what it said. I havent a clue what it means. This happens as soon as I open the program and happens through out the program. I have not yet updated the unit on the heli because of this problem. If I click continue or quit it reappears. I have to click quit many times quickly to quit the program or to continue. If I continue it reappears as soon as I open or change something.
08-17-2010, 07:34 PM | #2 (permalink) |
I would start by uninstalling and reinstalling the 3G software. If that does not work you can open my computer. Open drive C. Create a Folder named 'My_setting'. Open the 'My_setting' folder. Create a folder named 'ALIGN_sys' inside of the 'My_setting' folder. Run the 3G software and see what happens. You may be prompted for administrator access when creating the folder in the root of drive C.
Odd problem, hopefully the reinstall will fix it.
700N LE - 3G, 91HZ-R, SB-20FH-2, AR7100R, Edge 693FBL 600NSP - 3G, 55HZ, B320, 8717, 8900G, AR7100, Edge 603FBL 450 Pro & 450 SEv2 Stock Setups 450 SEv2 - SK360, MiniG, HKII-2221-6, CC 60, Edge 325FBL 250 SE - GY520, 290G & 250 Orig Stock Setup ---- JR 12x/Spek DX7se |
08-17-2010, 07:49 PM | #3 (permalink) |
I forgot to say that I already tried to reinstall. I am to tired and pissed at the computer to continue tonight. I will try tomorrow.
Thanks FrozenOne |
08-17-2010, 11:56 PM | #4 (permalink) |
Download & install Microsoft .NET Framework 4.
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro | JR DSX9 Limited Team RCBits | Team Lynx |
08-24-2010, 06:14 PM | #5 (permalink) |
I have installed what HiroboFreak said and reinstalled the 3G program. I was able to update the sensor and controller with seeing the same window pop up once.
I am still getting the same message in the configuration program for any setting, function, or anything I try to click on or change. Can someone please help. I really want to tune the heli to my personal flying style. Will the 3G unit still fly with out doing any of the minor adjustments in the program? I mean can I just use the V2.1 updated unit as I did the original version unit? |
08-24-2010, 06:41 PM | #6 (permalink) |
Have you tryed someone elses pc?
Compass 6HV, TotalG, BLS251, DX7S. Kasama Srimok, Scorpion HK-4525-520KV, TotalG, BLS251, DX7S. ...and the rest... |
08-24-2010, 07:33 PM | #7 (permalink) |
Not yet. I havent had access to one but I was thinking to find someone with one to let me try.
08-24-2010, 09:14 PM | #8 (permalink) |
Was just a thought. Might help you eliminate either your pc or the software.
08-25-2010, 09:28 AM | #9 (permalink) | |
KASAMA SRIMOK FAIFA SKOOKUM TREX450 BEAST X |
08-25-2010, 05:19 PM | #10 (permalink) |
Honestly I dont even really know what the program is. I downloaded and installed the link. If another computer doesnt work, should I try 3.5 and remove 4?
08-25-2010, 05:21 PM | #11 (permalink) |
hey. got the same error with my pc. seems like it's some kind of font issue. tried it on my mac with bootcamp and it worked fine. running windows7 64 on the pc and the 32 on the mac.
MA Fury 55 FBL Cgy 750 Next D Rave 450 Futaba 520 Align 450 Pro FBL Microbeast Futaba 8FGS |
08-25-2010, 06:10 PM | #12 (permalink) |
I am running Vista 32 bit
09-05-2010, 09:00 PM | #13 (permalink) |
v4 is obviously the new version.
I'm running the 3G software under .NET framework v4 with no issues. Sorry for the late reply.
09-18-2010, 04:05 PM | #14 (permalink) |
I've managed to fix my problem. I just had to install the "Arial Narrow" font and things were working fine.
09-21-2010, 09:11 PM | #15 (permalink) |
Where do I get the "arial narrow" font to install it?
